Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Layout size adjusted to its controls prefered size
Layout size adjusted to its controls prefered size [message #515925] Mon, 22 February 2010 04:23 Go to next message
Hi all,
I'm wondering if there is a layout which size is automatically adjusted to the prefered size of it's children.
In details, what I need to do is a new composite on which I add a new StyledText widget. I want the StyledText to automatically adapt it's size to it's text content. (that's to say always adjusting to it's prefered size). The FillLayout doesn't fill my needs because the StyledText is always resized to the parent composite's size.
So does such a layout exists, or do I need to make my own?
Thanks...
Re: Layout size adjusted to its controls prefered size [message #515932 is a reply to message #515925] Mon, 22 February 2010 04:43 Go to previous messageGo to next message
all other layouts apart from FillLayout does that only i suppose....
Try GridLayout on youy composite and Griddata on your StyledText..
Note: But in case of Text and StyledText controls instead of having a prefered size, the size should be fixed and scrollbars should be there to show the content.
[Updated on: Mon, 22 February 2010 04:45] by Moderator
Re: Layout size adjusted to its controls prefered size [message #515964 is a reply to message #515932] Mon, 22 February 2010 06:26 Go to previous messageGo to next message
First of all, thanks for your replay... But I still don't manage to do what I need to do...
Here is a piece of code :
package org.eclipse.swt.snippets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class TestLayoutStyledText {
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
//ScrolledComposite placed on the Shell with a FillLayout
ScrolledComposite oScrolledComposite = new ScrolledComposite(shell, SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL);
oScrolledComposite.setLayout(new FillLayout());
oScrolledComposite.setExpandHorizontal(true);
oScrolledComposite.setExpandVertical(true);
//Composite containing StyledText controls and placed on the ScrolledComposite
Composite oControlsComposite = new Composite(oScrolledComposite, SWT.NONE);
oControlsComposite.setBackground(new Color(null,0,255,255));
//Affects the ContolsComposite with a GridLayout of 1 column
GridLayout oGridLayout = new GridLayout();
oGridLayout.numColumns = 1;
oControlsComposite.setLayout(oGridLayout);
//StyledText 1 placed in the ControlsComposite with a GridLayout
StyledText oStyledText1 = new StyledText(oControlsComposite,SWT.NONE);
GridData oGridData1 = new GridData(GridData.FILL_BOTH);
oGridData1.grabExcessHorizontalSpace = true;
oGridData1.grabExcessVerticalSpace = true;
oGridData1.minimumHeight = 10;
oGridData1.minimumWidth = 10;
oStyledText1.setLayoutData(oGridData1);
//StyledText 2 placed under StyledText 1 in the ControlsComposite with a GridLayout
StyledText oStyledText2 = new StyledText(oControlsComposite,SWT.NONE);
GridData oGridData2 = new GridData(GridData.FILL_BOTH);
oGridData2.grabExcessHorizontalSpace = true;
oGridData2.grabExcessVerticalSpace = true;
oGridData2.minimumHeight = 10;
oGridData2.minimumWidth = 10;
oStyledText2.setLayoutData(oGridData2);
//Affects the content of the ScrolledComposite with the composite containing Controls
oScrolledComposite.setContent(oControlsComposite);
shell.setSize(200, 100);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
The behavior I expect is that when the first StyledText is filled up with text which is greater than the StyledText's size, I want to StyledText to grow so that all the text can still be visible. Then I want the second StyledText to move down.
I'm trying to use the ScrolledComposite so that if the size of each StyledText is greater then the shell size, then ScrollBars would appear.
Hope my example is more explicit.
Re: Layout size adjusted to its controls prefered size [message #515987 is a reply to message #515964] Mon, 22 February 2010 07:05 Go to previous messageGo to next message
Why can not the same thing done like this...
    public static void main(String[] args)
        // ScrolledComposite placed on the Shell with a FillLayout
        // Composite containing StyledText controls and placed on the ScrolledComposite
        oControlsComposite.setBackground(new Color(null, 0, 255, 255));
        // Affects the ContolsComposite with a GridLayout of 1 column
        // StyledText 1 placed in the ControlsComposite with a GridLayout
        StyledText oStyledText1 = new StyledText(oControlsComposite, SWT.H_SCROLL | SWT.V_SCROLL);
        // StyledText 2 placed under StyledText 1 in the ControlsComposite with a GridLayout
        StyledText oStyledText2 = new StyledText(oControlsComposite, SWT.H_SCROLL | SWT.V_SCROLL);
        // Affects the content of the ScrolledComposite with the composite containing Controls
        shell.setSize(400, 300);
        shell.open();
            if (!display.readAndDispatch()) display.sleep();
        display.dispose();
or do you want exactly what you specified....
[Updated on: Mon, 22 February 2010 07:06] by Moderator
Re: Layout size adjusted to its controls prefered size [message #515992 is a reply to message #515987] Mon, 22 February 2010 07:25 Go to previous messageGo to next message
You owe me one...
import org.eclipse.swt.events.ModifyEvent;
import org.eclipse.swt.events.ModifyListener;
import org.eclipse.swt.graphics.Point;
    private static GridData oGridData2;
    private static ScrolledComposite oScrolledComposite;
    private static Composite oControlsComposite;
    private static StyledText oStyledText1;
    private static GridData oGridData1;
        oStyledText1 = new StyledText(oControlsComposite, SWT.None);
        oStyledText1.addModifyListener(new ModifyListener()
            public void modifyText(ModifyEvent e)
                Point computeSize = oStyledText1.computeSize(SWT.DEFAULT, SWT.DEFAULT, true);
                oGridData1.minimumHeight = computeSize.y;
                oGridData1.minimumWidth = computeSize.x;
                oControlsComposite.layout();
                oScrolledComposite.setMinSize(oControlsComposite.computeSize(SWT.DEFAULT,
                        SWT.DEFAULT));
        final StyledText oStyledText2 = new StyledText(oControlsComposite, SWT.None);
        oStyledText2.addModifyListener(new ModifyListener()
                Point computeSize = oStyledText2.computeSize(SWT.DEFAULT, SWT.DEFAULT, true);
                oGridData2.minimumHeight = computeSize.y;
                oGridData2.minimumWidth = computeSize.x;
                        SWT.DEFAULT));
        shell.open();
        display.dispose();
Re: Layout size adjusted to its controls prefered size [message #516043 is a reply to message #515992] Mon, 22 February 2010 10:11 Go to previous messageGo to next message
Thanks a lot, you're right I owe you one!!!
Your solution is working fine... You're doing a trick with the text change listener, and adjusting the StyledText size on Text change, but I thought choosing a good Layout and/or good DataLayout would do it automatically. Why the DataLayout doesn't call automatically the computeSize method on StyledText Text change? Maybe the StyledText doen't perform any query of size change when its text is modified.
Anyway, thanks a lot for your replies!
Re: Layout size adjusted to its controls prefered size [message #525599 is a reply to message #515992] Tue, 06 April 2010 21:30 Go to previous message
Hi Vijay,
Could you please fixed the width of StyledText, only adjust the height?
Do you have a good idea?
John
On 02/22/2010 08:25 PM, vijay wrote:
> You owe me one...
> import org.eclipse.swt.widgets.Display;
> ScrolledComposite
> @Override
> SWT.DEFAULT, true);
> oScrolledComposite.setMinSize(oControlsComposite.computeSize (SWT.DEFAULT,
> SWT.DEFAULT));
> @Override
> SWT.DEFAULT, true);
> SWT.DEFAULT));
> shell.open();
> display.dispose();
Previous Topic:SWT applet. I don't see anything. Please help!
Next Topic:Checkbox on table header
Current Time: Sun Oct 26 04:43:57 EDT 2025
Powered by FUDForum. Page generated in 0.03546 seconds
