Home » Eclipse Projects » Rich Client Platform (RCP) » project setup and layout questions
project setup and layout questions [message #515833] |
Sun, 21 February 2010 15:32 |
Originally posted by: jann.schneider.googlemail.com
I'm new to RCP and therefore have some 'beginner' questions. I've read
some tutorials showing how to use RCP and stuff .. But some questions
are not quite clear to me now since they are just showing how to create
a product with just one plugin.
For better understanding my problems here some detaills of what i want
to do: I've an application which i want to turn into a multi plugin rCP
app now. It consists of some model packages, some GUI packages, some for
datamanagement and a view more. Now i am wondering how to setup my
project so, that i can build up several plugins for the told things.
In my understanding i need to setup a product project which puts things
together later on. But i am just confused how to setup the single plugin
projects now.
First of all, I guess the plugins just have to be kinda OSGi bundles and
i don't have to check 'build a rcp application' when creating them. Only
the main Plugin holding the application will have to be an RCP
application, right?
Lets say i create a plugin org.example.model and anotherone
org.example.datamanagement which should use some stuff from the model one.
In the product it's clear to me how to pput them together later on. But
i am wondering how to avoid retundand references between the single
plugins and the product then. Should org.example.datamanagement then
import-package org.example.model and the product needs to import both of
them?
Another question is about testing the application then: I'd guess i have
to create a folder in my product project and export all plugins to this
folder and let the product refer to the plugins in this folder then. Is
it that way or do i just miss something here?
I mean if i wanna create run configurations to check the application is
it necessary to export all plugins before to the folder then?
Sorry for such beginner stuff, but i am hopeful this is the right place
to ask :-)
Could you please give me some hints or links for further reading of how
to acheave such things?
Any help is greatly appriciated!
Thanks in advance,
Jann
Re: project setup and layout questions [message #515857 is a reply to message #515833] |
Sun, 21 February 2010 20:18 |
Charlie Kelly Messages: 276 Registered: July 2009 |
Hi Jann,
Assuming that you are using the new plugin wizard to create your
plugins, each plugin will contain a META-INF folder with a MANIFEST.MF file.
The eclipse IDE contains a manifest editor. It helps to manage
dependencies among plugins (all plugins are OSGI bundles).
On the "Dependencies" tab of the manifest editor you can list the
dependencies among your plugins.
From you description, your rcp plugin will depend upon both your
data-management plugin and your model plugin. If the datamanagement
depends upon the model, you can specify this in the manifest of the
datamanagement plugin.
You are correct that only your rcp plugin should be built with the
"build an rcp application" option.
Hope this helps.
Charlie
Jann S. wrote:
> Hello,
> projects now.
> application, right?
> them?
> to ask :-)
> Thanks in advance,
> Jann
Re: project setup and layout questions [message #515867 is a reply to message #515857] |
Sun, 21 February 2010 22:34 |
Hi charlie,
thanks! This helped me to get my application working basically. The
classes from the several plugins are found and loaded fine now!
Only thing that doesn't work currently is loading of resources like xml
files or other files included in the plugins.
I have achieved to export my plugins and can see, the datamanagement
plugin included the data folder with the according xml files. How can i
load such files from the plugin containing them at runtime?
I guess i need to get it via the bundle activator or some such?
Currently it just throws up an IOException .. So in the project folder
of the plugin i have a data/ folder containing xml files which have to
be loaded at runtime. When i export my plugins on the build tab i added
this folder and if i open the resulting jar it looks like the files are
included.
Thanks in advance!
regards Jann
Am 21.02.2010 21:18, schrieb exquisitus:
> Hi Jann,
> file.
> Hope this helps.
> Charlie
> Jann S. wrote:
>> Hello,
>> create a product with just one plugin.
>> rCP app now. It consists of some model packages, some GUI packages,
>> some for datamanagement and a view more. Now i am wondering how to
>> setup my project so, that i can build up several plugins for the told
>> things.
>> things together later on. But i am just confused how to setup the
>> single plugin projects now.
>> and i don't have to check 'build a rcp application' when creating
>> them. Only the main Plugin holding the application will have to be an
>> RCP application, right?
>> one.
>> But i am wondering how to avoid retundand references between the
>> single plugins and the product then. Should org.example.datamanagement
>> then import-package org.example.model and the product needs to import
>> both of them?
>> have to create a folder in my product project and export all plugins
>> to this folder and let the product refer to the plugins in this folder
>> then. Is it that way or do i just miss something here?
>> is it necessary to export all plugins before to the folder then?
>> place to ask :-)
>> how to acheave such things?
>> Thanks in advance,
>> Jann
Re: project setup and layout questions [message #515874 is a reply to message #515867] |
Sun, 21 February 2010 23:59 |
Hi Jenn,
If you double-click on the build.properties file in you plugin,
a "Build Properties Editor" will open the file.
Under "Binary Build" check the folder that includes your XML files.
Then see FileLocator() to acquire the files at run time.
Charlie
Jann S. wrote:
> Hi charlie,
> included.
> Thanks in advance!
> regards Jann
>> Hi Jann,
>> file.
>> Hope this helps.
>> Charlie
>> Jann S. wrote:
>>> Hello,
>>> things.
>>> one.
>>> both of them?
>>> place to ask :-)
>>> Thanks in advance,
>>> Jann
Re: project setup and layout questions [message #516073 is a reply to message #515867] |
Mon, 22 February 2010 16:51 |
THX Charlie! This works fine for me. I am no able to find my xml files
via the FileLocator class:
InputStream is = FileLocator.openStream(bundle, file, false);
And got the data correctly!
Regards Jann!
Current Time: Sat Apr 27 04:56:30 GMT 2024
Powered by FUDForum. Page generated in 0.03977 seconds
