Home » Eclipse Projects » Remote Application Platform (RAP) » problem with context menu
problem with context menu [message #515090] Wed, 17 February 2010 11:56 Go to next message
Hello all,
I have this code with creates a context menu for a Text widget.
        final Text text = new Text(parent, SWT.MULTI);
        text.setText("Seconds away");
        final MenuManager menuManager = new MenuManager();
        menuManager.add(new Action()
            public String getId()
                return "test";
            public String getText()
                return "text";
            public void run()
                new MessageBox(parent.getShell(), SWT.OK).open();
        final Menu menu = menuManager.createContextMenu(text);
        text.setMenu(menu);
- when I do right-click on Text widget the context menu appears.
- when I left-click on Text widget the context menu remains opened until I choose one of the options or until I do a click outside the Text widget.
In RCP(using JFace/SWT) when I click on Text widget the context menu closes.
I am using RAP1.2 and Firefox 3.5.7.
I saw the qooxdoo 0.7 has a autoHide property for menus.
Am I doing something wrong ? Or is it a limitation of RAP ?
Thank you.
Tommy
Re: problem with context menu [message #515107 is a reply to message #515090] Wed, 17 February 2010 12:37 Go to previous message
This was a known problem and is fixed in the 1.3 development stream. See
here for details:
287314: [Menu] Context-menu does not always close on click
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287314
Rüdiger Herrmann
http://eclipsesource.com
> @Override
> return "test";
> @Override
> return "text";
> @Override
> public void run()
> text.setMenu(menu);
Previous Topic:SWT Layout resizable
Next Topic:Is there any documentation for the JavaScript org.eclipse.swt.Request-Object?
Current Time: Tue Oct 28 03:36:16 EDT 2025
Powered by FUDForum. Page generated in 0.04268 seconds
