Home » Language IDEs » PHP Development Tools (PDT) » Mac+MAMP+EclipsePDT > Mysql connection problem
Mac+MAMP+EclipsePDT > Mysql connection problem [message #51986] Sat, 15 September 2007 04:34 Go to next message
Originally posted by: nova67f.yahoo.de
Hi all,
I'm a new eclipse user, having used textwrangler for my php editing
needs up to now ;)
my configuration is like this :
Mac Os X 10.4.10,
MAMP 1.7 with Apache on port 80 and mysql on port 3306.
Php version 5.2.3
Eclipse 3.3.0 with debugger from Zend
http://downloads.zend.com/pdt/all-in-one/
Everything works, also the debugging, except the mysql connection.
I can connect to mysqlwith cocoa using this unix socket
/Applications/MAMP/tmp/mysql/mysql.sock
In php however, when my code hits
@mysql_connect($this->server, $this->user, $sqlpassword, $new_link);
i get thrown into my error exception
General Error
SQL ERROR [ mysql4 ]
Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
[2002]
An sql error occurred while fetching this page. Please contact an
administrator if this problem persists.
Obviously the socket is wrong but i don't know how to correct this in
eclipse.
This is my phpinfo concerning mysql : you can see that the socket is
different.
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version 5.0.41
MYSQL_MODULE_TYPE external
MYSQL_SOCKET /Applications/MAMP/tmp/mysql/mysql.sock
MYSQL_INCLUDE -I/Applications/MAMP/Library/include/mysql
MYSQL_LIBS -L/Applications/MAMP/Library/lib/mysql -lmysqlclient
Directive Local Value Master Value
mysql.allow_persistent On On
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket /Applications/MAMP/tmp/mysql/mysql.sock
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
So how do i put Eclipse in the right direction ?
Many thanks in advance!
Andy
(sorry for crossposting this i didn't find the right group)
Re: Mac+MAMP+EclipsePDT > Mysql connection problem [message #52333 is a reply to message #51986] Mon, 17 September 2007 15:00 Go to previous message
Originally posted by: dserodio.gmail.com
I'm not a Mac user, but in XAMP (I'm guessing it's the MAMP equivalent
on Windows) there are separate configuration files (php.ini) for running
PHP under Apache and "CLI" (command-line).
Maybe your two php.ini files are different regarding MySQL configuration?
HTH,
Daniel Serodio
Andy Vandenberghe wrote:
> Hi all,
> needs up to now ;)
> Mac Os X 10.4.10,
> Php version 5.2.3
> General Error
> [2002]
> eclipse.
> different.
> Active Links 0
> Andy
Previous Topic:XDebug versus ZendDebugger
Next Topic:failed openning '../include.inc.php'
Current Time: Wed Nov 05 19:58:42 EST 2025
Powered by FUDForum. Page generated in 0.03254 seconds
