Home » Eclipse Projects » Mylyn » Unable to create query on Trac repository
Unable to create query on Trac repository [message #513981] Thu, 11 February 2010 16:42 Go to next message
I have a very fresh installation of Eclipse, and I installed the Mylyn connectors for Trac. I was able to successfully connect to the repositories, but when I attempt to create any queries for tasks, the following error occurs.
Query Synchronization Failed
'no such column: t.max' while executing 'ticket.query()'
It's something on the Eclipse side because the rest of my team has no problems, and my old Eclipse client had no problems either.
Was hoping someone had seen this error and had a solution.
[Updated on: Thu, 11 February 2010 16:43] by Moderator
Re: Unable to create query on Trac repository [message #513986 is a reply to message #513981] Thu, 11 February 2010 16:54 Go to previous message
Steve, please file a bug and include information about the Trac version,
version of the Trac XmlRpcPlugin and the Mylyn version you are using:
http://eclipse.org/mylyn/support
Steffen
> following errors occurs.
> It's some on the Eclipse side because the rest of my team has no problems,
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Previous Topic:Java API for OSLC CM 1.0
Next Topic:Trim Widget to Graduate?
Current Time: Fri Aug 01 22:29:31 EDT 2025
Powered by FUDForum. Page generated in 0.03793 seconds
