Re: Question about the org.eclipse.rap.flexdraw2d bundle and the Innoopract Informationssysteme GmbH [message #514007 is a reply to message #513854] |
Fri, 12 February 2010 03:41 |
tingel christian Messages: 46 Registered: December 2009 |
Member |
Thanks a lot, Jochen.
I will send you a mail later today:)
Best Regards
Tingel Christian
Jochen Krause wrote on Thu, 11 February 2010 09:10 | Hi Christian,
org.eclipse.rap.flexdraw2d was a proof of concept implementation that we (Innoopract, now EclipseSource) jointly developed with the technical university of Sofia. The code has never been publicly released, but we did provide it to some interested parties, we can do the same for you. The code base was intended as a proof that it can be done. If you have changes to this code base that you plan to release to third parties you need to make the changes available to us (EclipseSource) to comply with the EPL. It would be great if you could get in touch with us directly (jkrause _at_ eclipsesource *dot* com).
The code which was developed for the proof of concept is certainly not fit for wide scale adoption / production use. But if you / others would be interested in creating and maintaining a draw2d implementation for RAP that would be great!
Cheers, Jochen
[Updated on: Fri, 12 February 2010 03:42] Report message to a moderator
FUDForum. Page generated in 0.03347 seconds
