Home » Modeling » M2T (model-to-text transformation) » Running an algorithm on expressions before code generation
Running an algorithm on expressions before code generation [message #513553] Wed, 10 February 2010 09:48 Go to next message
Hello everybody,
Here is my problem: I have an Xtext grammar file, which includes the possibility to define a field that looks more like a program than a model description. I explain with an example: I can write something like that
computation {
a = 1;
b = a + 5;
c = a*b;
Let's say (it will be simpler) I have a "Computation" definition which has a "program" field in it and this program field is a reference to an Expression object.
Here is the beginning of the definition of "Expression" in my xtext file:
Expression :
	OrExpression;
OrExpression returns Expression:
	AndExpression ({BooleanOperation.left=current} operator="||" right=AndExpression)*;
AndExpression returns Expression:
	RelationalExpression ({BooleanOperation.left=current} operator="&&" right=RelationalExpression)*;
My problem is: I generate some Java codes with Xpand according to a model description following the grammar rules, but for Expression it's more difficult to generate something only with Xpand because I need to analyze the AST of the expression in order to optimize it before generating codes.
Let's say it's more a compilation work (traditional AST analyze, with inherited and synthesized attributes) than a simple generation, and Xpand seems not to be enough.
So is it a way to take my instance of Expression (which seems to be the root of an AST), use it as a parameter for a (Java ?) algorithm, then use the result of the algorithm to generate something with Xpand ?
I heard about Xtend, is it that tool I need ?
I hope my explanations are clear enough (I'm a French student, my English must be quiet imperfect...).
Thanks !
Re: Running an algorithm on expressions before code generation [message #513586 is a reply to message #513553] Wed, 10 February 2010 11:00 Go to previous messageGo to next message
What kind of optimizations do you want to do?
You can modify your model with Xtend, if that is the question.
Sven
Matthieu schrieb:
> Hello everybody,
> that
> computation {
> a = 1;
> b = a + 5;
> c = a*b;
> Expression object.
> Expression : OrExpression;
> generating codes.
> Thanks !
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: Running an algorithm on expressions before code generation [message #514351 is a reply to message #513553] Sun, 14 February 2010 17:50 Go to previous message
If I understood correct you want to compute your result in Java based with the AST as argument and use that result in Xpand to generate code. If the answer is yes, then Xtend is right here. Write a Java extension which is called from your Xpand code.
~Karsten
Previous Topic:[JET] Protected Areas
Next Topic:Topcased UML Profiles and Spring Cartridge
Current Time: Thu Sep 25 08:22:38 EDT 2025
Powered by FUDForum. Page generated in 0.04144 seconds
