Home » Modeling » M2T (model-to-text transformation) » [XPAND] XPand and Partitioning Ecore is possible ?(With a multiple ecore file metamodel, non-root class are not found)
icon5.gif  [XPAND] XPand and Partitioning Ecore is possible ? [message #513530] Wed, 10 February 2010 08:59 Go to next message
Hi everyone,
I have a problem to generate files with XPand when my metamodel is a multiple ecore files.
To have a clear metamodel for my EMF editor, i made a 'partitioned' one.
A problem appears when i try to generate files with Xpand. It doesn't find the Class which are not in the root Ecore file, and i can't define the functions...
But, if i call them by hierarchy (and make an horrible single DEFINE function it works...) everything is OK he finds all the classes i call.
I checked the dependencies in the MANIFEST.MF and everything is OK.
The problem seems to come from my definition but i have no idea to do it in an other way.
Or maybe it is impossible to associate Xpand with a multiple file metamodel ?
If anybody already had this problem, or if you know the possibility (or impossibility Sad ) to do this, it will be really helpfull...
Thanks !
Florine
Simple Example:
The root Ecore file has the Procedure Class.
An other Ecore file has the RobotTask Class.
The Class Procedure has EReference to a List of RobotTask.
.xpt file code :
«IMPORT procedure »
«IMPORT robot »
«DEFINE RobotDef FOR RobotTask»
	Bla bla...
«ENDDEFINE»
«DEFINE Root FOR Procedure»
		«EXPAND RobotDef FOREACH hasTaskRobot»
«ENDDEFINE»
Error detected :
SEVERE: Error in Component generator of type org.openarchitectureware.xpand2.Generator:
	EvaluationException : No Definition 'RobotDef for robot::RobotTask' found!
	templates::Root.xpt[206,36] on line 15 'EXPAND RobotDef FOREACH hasTaskRobot'
	[23,38] on line 1 'EXPAND templates::Root::Root FOR model'
[Updated on: Wed, 10 February 2010 09:02] by Moderator
Re: [XPAND] XPand and Partitioning Ecore is possible ? [message #513539 is a reply to message #513530] Wed, 10 February 2010 09:22 Go to previous messageGo to next message
Splitting models or metamodels is no problem. Make sure that you always use platform resource URIs. Make sure that you declare every metamodel package in the StandaloneSetup.
HTH,
~Karsten
Re: [XPAND] XPand and Partitioning Ecore is possible [message #513582 is a reply to message #513530] Wed, 10 February 2010 05:54 Go to previous messageGo to next message
--------------050606010808040007000704
Content-Type: text/plain; charset=UTF-8; format=flowed
florine,
this should work. redview (http://redview.org) uses always some ecore files
register them all:
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value=".." />
<registerEcoreFile value="${redview.mm.dir.uri}binding.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}datatypes.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}elements.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}layout.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}styles.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}validation.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}converter.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}visibility.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}dnd.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}events.ecore"/>
<registerEcoreFile value="${redview.mm.ext.riena.dir.uri}validators.ecore"/>
<registerEcoreFile value="${redview.mm.ext.riena.dir.uri}converters.ecore"/>
</bean>
as karsten said - use URIs - not Pathes
ekke
Am 10.02.10 14:59, schrieb Florine Boudin:
> Hi everyone,
> it in an other way.
> metamodel ?
> (or impossibility :( ) to do this, it will be really helpfull...
> Thanks !
> Florine
> Simple Example:
> xpt file code :
> «IMPORT procedure »
> «IMPORT robot »
> Bla bla...
> «ENDDEFINE»
> «ENDDEFINE»
> Error detected :
> org.openarchitectureware.xpand2.Generator: EvaluationException :
> hasTaskRobot'
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
florine,<br>
<br>
this should work. redview (<a class="moz-txt-link-freetext" href="http://redview.org">http://redview.org</a>) uses always some ecore
files<br>
<br>
register them all:<br>
<br>
    &lt;bean class="org.eclipse.emf.mwe.utils.StandaloneSetup"&gt;<br >
        &lt;platformUri value=".." /&gt;   <br>
        &lt;registerEcoreFile
value="${redview.mm.dir.uri}binding.ecore"/&gt;<br>
value="${redview.mm.dir.uri}datatypes.ecore"/&gt;<br>
value="${redview.mm.dir.uri}elements.ecore"/&gt;<br>
value="${redview.mm.dir.uri}layout.ecore"/&gt;    <br>
value="${redview.mm.dir.uri}styles.ecore"/&gt;<br>
value="${redview.mm.dir.uri}validation.ecore"/&gt;<br >
value="${redview.mm.dir.uri}converter.ecore"/&gt;<br>
value="${redview.mm.dir.uri}visibility.ecore"/&gt;<br >
value="${redview.mm.dir.uri}dnd.ecore"/&gt;<br>
value="${redview.mm.dir.uri}events.ecore"/&gt;<br>
        <br>
value="${redview.mm.ext.riena.dir.uri}validators.ecore"/&gt; <br>
value="${redview.mm.ext.riena.dir.uri}converters.ecore"/&gt; <br>
    &lt;/bean&gt;<br>
<br>
as karsten said - use URIs - not Pathes<br>
<br>
ekke<br>
<br>
<blockquote cite="mid:hkue46$2gr$1@build.eclipse.org" type="cite">Hi
everyone,
<br>
<br>
<br>
<br>
one.
<br>
the functions...
<br>
<br>
<br>
<br>
<br>
<br>
it in an other way.
<br>
metamodel ?
<br>
<br>
<br>
<br>
Thanks !
<br>
<br>
Florine
<br>
<br>
<br>
Simple Example:
<br>
<br>
<br>
The Class Procedure has EReference to a List of RobotTask. <br>
xpt file code :
<br>
<br>
«IMPORT procedure »
<br>
«IMPORT robot »
<br>
<br>
<br>
    Bla bla...
<br>
«ENDDEFINE»
<br>
<br>
<br>
<br>
«ENDDEFINE»
<br>
<br>
<br>
Error detected :
<br>
<br>
org.openarchitectureware.xpand2.Generator:     EvaluationException : No
<br>
hasTaskRobot'
<br>
    [23,38] on line 1 'EXPAND templates::Root::Root FOR model'     <br>
</blockquote>
<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------050606010808040007000704--
icon3.gif  Re: [XPAND] XPand and Partitioning Ecore is possible [message #513613 is a reply to message #513582] Wed, 10 February 2010 12:10 Go to previous messageGo to next message
Thank you ekke and Karsten !
You reassured me about the feasibility of it.
Right now it doesn't work. But i think i need to understand all the step of the workflow to make it work, for the moment new errors appeared...
I will post my solution. I hope as soon as possible Rolling Eyes .
Maybe i will ask other questions.
Thanks again !
Florine
Re: [XPAND] XPand and Partitioning Ecore is possible [message #531314 is a reply to message #513613] Tue, 04 May 2010 10:28 Go to previous message
Hi everyone,
I managed few days after my last message and i think it's a good idea to share my solution with you.
With a partitioning ecore, when i use XPand, i modified the worflow.oaw file.
The ecore file 'procedure' uses classes of the 'task.ecore' file, which uses classes of the 'module.ecore' file.
In the Generator defined in the oaw file, I call all each one of them in a metamodel :
<component id="generator"
    class="org.openarchitectureware.xpand2.Generator">
     <metaModel id="mm"
      class="org.openarchitectureware.type.emf.EmfMetaModel">
       <metaModelPackage value="procedure.ProcedurePackage"/>
    </metaModel>
     <metaModel id="mm2"
       <metaModelPackage value="task.TaskPackage"/>
    </metaModel>
    <metaModel id="mm3"
       <metaModelPackage value="module.ModulePackage"/>
    </metaModel>
</component>
Now, in the xpt file, the imports are recognized ! ! No more errors Smile
«IMPORT procedure »
«IMPORT tache »
«IMPORT module »
Thanks again for your help !
Florine
Previous Topic:[XPand dev] Tracing model access
Next Topic:EMF, oAW and "Code Composer Studio 4" (CCS4)
Current Time: Sat Nov 08 22:06:09 EST 2025
Powered by FUDForum. Page generated in 0.03292 seconds
