Home » Modeling » Epsilon » problem with creation of phantom nodes
problem with creation of phantom nodes [message #513015] Mon, 08 February 2010 10:27 Go to next message
hi
i tried to use phantom nodes as shown in the eugenia example.
http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-phan tom-nodes/
but for some reason, the resulting editor does not create the model as expected.
the problem is, when i add a contained node and connect it to a containing node (in one step, without saving in between), the node is not really added as a containment but is put directly in the resource (and only a link is created).
for example, it looks like this:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:testing="http://www.fokus.fraunhofer.de/testing/testing.ecore">
  <testing:DataPool xmi:id="_S_9dIBS_Ed-tb5U5tmCMAw">
    <ownedPartition xsi:type="testing:PrimitiveType" xmi:id="_UUkfoBS_Ed-tb5U5tmCMAw">
      <value href="#_637wYBTCEd-Ag7GywjYsiQ"/>
    </ownedPartition>
  </testing:DataPool>
  <testing:PartitionValue xmi:id="_637wYBTCEd-Ag7GywjYsiQ"/>
</xmi:XMI>
but it should look like this:
      <value xmi:id="_637wYBTCEd-Ag7GywjYsiQ"/>
    </ownedPartition>
  </testing:DataPool>
</xmi:XMI>
DataPool is the diagram root, PrimitiveType in this case is the containing node, and PartitionValue the contained node.
as you can see, instead of putting the partition value as a containment, it is created outside the diagram root and only linked.
of course, the way it is now, the tree editor shows both partition values.
has anyone an idea why it is working this way?
thanks in advance
marco
Re: problem with creation of phantom nodes [message #513031 is a reply to message #513015] Mon, 08 February 2010 10:43 Go to previous message
Hi Marco,
Could you possibly send me your annotated metamodel (dskolovos - gmail -
com) so that I can have a look at this?
Dimitris
Marco.Kranz@fokus.fraunhofer.de wrote:
> hi
> expected.
> </ownedPartition>
> </testing:DataPool>
> </xmi:XMI>
> </ownedPartition>
> </testing:DataPool>
> </xmi:XMI>
> thanks in advance
> marco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Previous Topic:[EOL, Ecore2GMF.eol] How duplicate GmfMap!NodeMapping?
Next Topic:problem with creation of phantom nodes
Current Time: Sat Sep 06 19:22:24 EDT 2025
Powered by FUDForum. Page generated in 0.03743 seconds
