Home » Eclipse Projects » Subversive » Cannot merge(Always says, "Merge: no changes found")
Cannot merge [message #512556] Fri, 05 February 2010 08:38 Go to next message
I have 2 branches A and B.
I have a workspace that contains the checkouts from branch A, and
I try to merge from B to A by clicking "team"->"merge"->"URL" and entering the URL to one of the subfolder in the branch B and the revision #.
I am sure that under that revision #, I added tons of files to branch B, and so I can't believe that subversive keeps telling me, "Merge: no changes found".
Did I do anything stupid?
Thanks in advance.
Re: Cannot merge [message #512881 is a reply to message #512556] Mon, 08 February 2010 04:39 Go to previous messageGo to next message
If you call Merge action on project folder, then you need to specify merge
url to not any of the subfolder of branch B but to corresponding to it
folder in branch B.
Also you can check with what actual parameters Merge action is called by
pressing Preview button in Merge dialog (after you specified url and
revision), it will output parameters in Console View(if you don't have
anything in Console View after pressing Preview button you need to enable
writing in Console in preferences: Windows/Preferences/Team/SVN/Console
select 'On output' option in Show Console automatically section).
> changes found".
> Thanks in advance.
Re: Cannot merge [message #515222 is a reply to message #512556] Thu, 18 February 2010 04:02 Go to previous messageGo to next message
Thanks for your reply, Igor.
I have tried to use the URL pointing to the corresponding folder in branch B. But it still says "Merge: no changes found".
Let me try to be a little bit specific:
I checked out svn://localhost:12345/bbb/branches/A as a project to workspace#1.
I checked out svn://localhost:12345/bbb/branches/B as a project to another workspace, say #2.
Then, I highlighted a folder in the project in workspace #1, say "project/x/y/z" and hit "team->merge"->URL: svn://localhost:12345/bbb/branches/B/x/y/z
Then, I clicked "preview", but there is nothing (besides the header).
Any idea?
Thanks in advance.
[Updated on: Thu, 18 February 2010 04:05] by Moderator
Re: Cannot merge [message #515912 is a reply to message #515222] Mon, 22 February 2010 03:41 Go to previous messageGo to next message
It's difficult to say what the problem could be, please, try the following:
- try to make merge not on specific folder but on project root and see the
results. Note that you can always revert changes after merge so it's not
dangerous operation.
- please, see output in SVN Console view (I described in my previous comment
how to customize it) and verify whether there were real changes in those
revision range at interested folder
> I checked out svn://localhost:12345/zodiac/branches/A as a project to
> workspace#1.
> I checked out svn://localhost:12345/zodiac/branches/B as a project to
> svn://localhost:12345/zodiac/branches/B/x/y/z
> Any idea?
> Thanks in advance.
Re: Cannot merge [message #518836 is a reply to message #512556] Fri, 05 March 2010 04:13 Go to previous messageGo to next message
No Real Name wrote on Fri, 05 February 2010 08:38
Thanks in advance.
This may or may not be the same issue I am seeing. I use the PDT version of Eclipse and the Subversive SVNKit 1.2.2 (SVN 1.5.5) r5428 connector.
Merge tracking for merging up from trunk to my branch has recently stopped working for me since Eclipse auto-upgraded my plugin and version of PDT. (Can't remember what version number Subversive was before this update).
If I try and merge up from trunk to my branch I now always get 'No changes' when I know full well there are changes in trunk.
When I check out my branch from the command line svn client and try a merge up from trunk using the command-line and not Eclipse/Subversive I see the changes coming in.
Something has gone amiss in Subversive over the last week for me - now using SVNKit 1.2.2 r5428.
Any ideas?
Re: Cannot merge [message #519550 is a reply to message #518836] Tue, 09 March 2010 04:58 Go to previous message
Hello Andrew,
Does it show changes if you specify revisions to merge explicitly by
specifying them in Revisions input field? Also you can see ouput of the
merge command in SVN Console View which shows what actual revisions were
used in merging.
>> I have a workspace that contains the checkouts from branch A, and I try
>> changes found".
>> Thanks in advance.
> Any ideas?
Previous Topic:Unselected items are updated
Next Topic:subclipse to ant build, with directory hierarchy dependencies
Current Time: Wed Sep 24 19:15:03 EDT 2025
Powered by FUDForum. Page generated in 0.03954 seconds
