[Accelo]use of @code-explicit [message #512301] |
Thu, 04 February 2010 15:40 |
Originally posted by: koos.waytostay.com
Hi All,
I have to generate code from UML getting the following result for c-sharp
like
[ServiceContract]
public interface IBookingService
[OperationContract]
BookingContract getBookingContract();
I tried using @code-explicit according the standard but this does not work.
Is this not implemented and if not is there another way to generate the []
maybe using an excape character?
Koos
Re: [Accelo]use of @code-explicit [message #512450 is a reply to message #512309] |
Fri, 05 February 2010 08:25 |
--------------070208020100060409090801
Hi Sebastien, Koos,
Sebastien's answer is exactly right, just wanted to mention that the
closing bracket ']' doesn't need to be escaped.
Laurent Goubet
Obeo
Sebastien Roy wrote:
> According to Accelo documentation, the code explicit syntax is not
> implemented yet.
> But you can escape bracket characters like that :
> ['['/]ServiceContract[']'/]
> ['['/]OperationContract[']'/]
> Regards
> Sebastien
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------070208020100060409090801--
FUDForum. Page generated in 0.03258 seconds
