| Home » Eclipse Projects » EclipseLink » ORA-03137 error while using eclipselink 1.1.1(ORA-03137 error while using eclipselink 1.1.1)
 Goto Forum:|
| ORA-03137 error while using eclipselink 1.1.1 [message #512129] | Wed, 03 February 2010 23:42  |  |
| Eclipse User  |  |  |  |  | Has anyone ever seen the following error while using eclipselink 1.1.1?
 ORA-03137: TTC protocol internal error : 12333 [4] 195 99] [ ] [ []
 Our Oracle version is:
 Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
 PL/SQL Release 11.2.0.1.0 - Production
 CORE
 11.2.0.1.0 Production
 TNS for Linux: Version 11.2.0.1.0 - Production
 NLSRTL Version 11.2.0.1.0 - Production
 I assume that Oracle's bug 7390077 was also merged from 11.1.7 to 11.2.0.1. Am I wrong?
 Thanks in advance,
 Otto
| Re: ORA-03137 error while using eclipselink 1.1.1 [message #512418 is a reply to message #512259] | Thu, 04 February 2010 20:48   |  |
 20:48:04,065 INFO  [ServerImpl] Starting JBoss (Microcontainer)...
 20:48:04,066 INFO  [ServerImpl] Release ID: JBoss [The Oracle] 5.1.0.GA (build: SVNTag=JBoss_5_1_0_GA date=200905221634)
 20:48:04,067 INFO  [ServerImpl] Bootstrap URL: null
 20:48:04,067 INFO  [ServerImpl] Home Dir: /mnt/OD_DOC/jboss-4.2.2.GA
 20:48:04,067 INFO  [ServerImpl] Home URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/
 20:48:04,067 INFO  [ServerImpl] Library URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/lib/
 20:48:04,067 INFO  [ServerImpl] Patch URL: null
 20:48:04,067 INFO  [ServerImpl] Common Base URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/common/
 20:48:04,067 INFO  [ServerImpl] Common Library URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/common/lib/
 20:48:04,067 INFO  [ServerImpl] Server Name: node2
 20:48:04,067 INFO  [ServerImpl] Server Base Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server
 20:48:04,068 INFO  [ServerImpl] Server Base URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/
 20:48:04,068 INFO  [ServerImpl] Server Config URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/conf/
 20:48:04,068 INFO  [ServerImpl] Server Home Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2
 20:48:04,068 INFO  [ServerImpl] Server Home URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/
 20:48:04,068 INFO  [ServerImpl] Server Data Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/data
 20:48:04,068 INFO  [ServerImpl] Server Library URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/lib/
 20:48:04,068 INFO  [ServerImpl] Server Log Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/log
 20:48:04,068 INFO  [ServerImpl] Server Native Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp/native
 20:48:04,068 INFO  [ServerImpl] Server Temp Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp
 20:48:04,068 INFO  [ServerImpl] Server Temp Deploy Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp/deploy
 20:48:05,048 INFO  [ServerImpl] Starting Microcontainer,  bootstrapURL=file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/co nf/bootstrap.xml
 20:48:05,841 INFO  [VFSCacheFactory] Initializing VFSCache [org.jboss.virtual.plugins.cache.CombinedVFSCache]
 20:48:05,843 INFO  [VFSCacheFactory] Using VFSCache [CombinedVFSCache[real-cache: null]]
 20:48:06,431 INFO  [CopyMechanism] VFS temp dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp
 20:48:06,454 INFO  [ZipEntryContext] VFS force nested jars copy-mode is enabled.
 20:48:07,764 INFO  [ServerInfo] Java version: 1.6.0_16,Sun Microsystems Inc.
 20:48:07,764 INFO  [ServerInfo] Java Runtime: Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
 20:48:07,765 INFO  [ServerInfo] Java VM: Java HotSpot(TM) 64-Bit Server VM 14.2-b01,Sun Microsystems Inc.
 20:48:07,765 INFO  [ServerInfo] OS-System: Linux 2.6.18-92.1.22.el5,amd64
 20:48:07,766 INFO  [ServerInfo] VM arguments: -Xms10g -Xmx12g -XX:MaxPermSize=512m -XX:NewRatio=1 -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djava.net.preferIPv4Stack=true -Djboss.messaging.ServerPeerID=2 -Djboss.partition.name=tempOD -Djava.endorsed.dirs=/mnt/OD_DOC/clusterJBoss/lib/endorsed
 20:48:07,804 INFO  [JMXKernel] Legacy JMX core initialized
 20:48:09,784 INFO  [ProfileServiceBootstrap] Loading profile: ProfileKey@14cef147[domain=default, server=default, name=node2]
 20:48:16,299 INFO  [WebService] Using RMI server codebase: http://10.1.1.2:8083/
 20:48:21,459 INFO  [NativeServerConfig] JBoss Web Services - Stack Native Core
 20:48:21,459 INFO  [NativeServerConfig] 3.1.2.GA
 20:48:22,312 INFO  [LogNotificationListener] Adding notification listener for logging mbean "jboss.system:service=Logging,type=Log4jService" to server org.jboss.mx.server.MBeanServerImpl@4969dd64[ defaultDomain='jboss' ]
 20:48:52,442 INFO  [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@540200319 {vfsfile:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/prof ileservice-secured.jar/}
 20:48:52,443 INFO  [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@540200319 {vfsfile:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/prof ileservice-secured.jar/}
 20:48:52,446 INFO  [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@109331363 {vfsfile:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/redr ock.ear/redrock-ejb.jar/}
 20:48:54,554 INFO  [JMXConnectorServerService] JMX Connector server:  service:jmx:rmi://10.1.1.2/jndi/rmi://10.1.1.2:1090/jmxconne ctor
 20:48:54,670 INFO  [MailService] Mail Service bound to java:/Mail
 20:48:56,682 INFO  [tempOD] Initializing partition tempOD
 20:48:56,771 INFO  [STDOUT]
 GMS: address is 10.1.1.2:54112 (cluster=tempOD)
 20:48:56,845 INFO  [PlatformMBeanServerRegistration] JBossCache MBeans were successfully registered to the platform mbean server.
 20:48:56,895 INFO  [STDOUT]
 GMS: address is 10.1.1.2:54112 (cluster=tempOD-HAPartitionCache)
 20:48:56,934 INFO  [tempOD] Number of cluster members: 2
 20:48:56,935 INFO  [tempOD] Other members: 1
 20:48:56,967 INFO  [RPCManagerImpl] Received new cluster view: [10.1.1.1:60924|1] [10.1.1.1:60924, 10.1.1.2:54112]
 20:48:57,014 INFO  [LegacyStateTransferIntegrator] Using version 4096
 20:48:57,022 INFO  [RPCManagerImpl] Cache local address is 10.1.1.2:54112
 20:48:57,023 INFO  [RPCManagerImpl] state was retrieved successfully (in 136 milliseconds)
 20:48:57,034 INFO  [ComponentRegistry] JBoss Cache version: JBossCache 'Cascabel' 3.1.0.GA
 20:48:57,036 INFO  [tempOD] Fetching serviceState (will wait for 30000 milliseconds):
 20:48:57,105 INFO  [tempOD] serviceState was retrieved successfully (in 69 milliseconds)
 20:48:57,214 INFO  [HANamingService] Started HAJNDI bootstrap; jnpPort=1100, backlog=50, bindAddress=/10.1.1.2
 20:48:57,229 INFO  [DetachedHANamingService$AutomaticDiscovery] Listening on /10.1.1.2:1102, group=230.0.0.4, HA-JNDI address=10.1.1.2:1100
 20:48:57,695 INFO  [UnifiedInvokerHA] Service name is jboss:service=invoker,type=unifiedha
 20:48:58,163 WARN  [AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent
 20:48:58,265 WARN  [AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent
 20:48:58,345 INFO  [TransactionManagerService] JBossTS Transaction Service (JTA version - tag:JBOSSTS_4_6_1_GA) - JBoss Inc.
 20:48:58,345 INFO  [TransactionManagerService] Setting up property manager MBean and JMX layer
 20:48:58,586 INFO  [TransactionManagerService] Initializing recovery manager
 20:48:58,835 INFO  [TransactionManagerService] Recovery manager configured
 20:48:58,835 INFO  [TransactionManagerService] Binding TransactionManager JNDI Reference
 20:48:58,856 INFO  [TransactionManagerService] Starting transaction recovery manager
 20:48:59,136 INFO  [AprLifecycleListener] The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path:  /usr/java/jdk1.6.0_16/jre/lib/amd64/server:/usr/java/jdk1.6. 0_16/jre/lib/amd64:/usr/java/jdk1.6.0_16/jre/../lib/amd64:/u sr/java/packages/lib/amd64:/lib:/usr/lib
 20:48:59,173 INFO  [Http11Protocol] Initializing Coyote HTTP/1.1 on http-10.1.1.2-8080
 20:48:59,186 INFO  [StandardService] Starting service jboss.web
 20:48:59,188 INFO  [StandardEngine] Starting Servlet Engine: JBoss Web/2.1.3.GA
 20:48:59,217 INFO  [Catalina] Server startup in 44 ms
 20:48:59,231 INFO  [TomcatDeployment] deploy, ctxPath=/invoker
 20:48:59,694 INFO  [TomcatDeployment] deploy, ctxPath=/jbossws
 20:48:59,797 INFO  [RARDeployment] Required license terms exist, view  vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/jboss- local-jdbc.rar/META-INF/ra.xml
 20:48:59,807 INFO  [RARDeployment] Required license terms exist, view  vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/jboss- xa-jdbc.rar/META-INF/ra.xml
 20:48:59,821 INFO  [RARDeployment] Required license terms exist, view  vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/jms-ra .rar/META-INF/ra.xml
 20:48:59,833 INFO  [RARDeployment] Required license terms exist, view  vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/mail-r a.rar/META-INF/ra.xml
 20:48:59,846 INFO  [RARDeployment] Required license terms exist, view  vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/quartz -ra.rar/META-INF/ra.xml
 20:48:59,913 INFO  [SimpleThreadPool] Job execution threads will use class loader of thread: main
 20:48:59,932 INFO  [QuartzScheduler] Quartz Scheduler v.1.5.2 created.
 20:48:59,933 INFO  [RAMJobStore] RAMJobStore initialized.
 20:48:59,933 INFO  [StdSchedulerFactory] Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource file in Quartz package: 'quartz.properties'
 20:48:59,934 INFO  [StdSchedulerFactory] Quartz scheduler version: 1.5.2
 20:48:59,934 INFO  [QuartzScheduler] Scheduler DefaultQuartzScheduler_$_NON_CLUSTERED started.
 20:49:00,083 INFO  [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=DefaultDS' to JNDI name 'java:DefaultDS'
 20:49:00,853 INFO  [ServerPeer] JBoss Messaging 1.4.3.GA server [2] started
 20:49:00,997 INFO  [STDOUT]
 GMS: address is 10.1.1.2:54112 (cluster=MessagingPostOffice-CTRL)
 20:49:01,063 INFO  [GroupMember] org.jboss.messaging.core.impl.postoffice.GroupMember$ControlMembershipListener@6ac7bf5b got new view [10.1.1.1:60924|1] [10.1.1.1:60924, 10.1.1.2:54112], old view is null
 20:49:01,063 INFO  [GroupMember] I am (10.1.1.2:54112)
 20:49:01,063 INFO  [GroupMember] New Members : 2 ([10.1.1.1:60924, 10.1.1.2:54112])
 20:49:01,063 INFO  [GroupMember] All Members : 2 ([10.1.1.1:60924, 10.1.1.2:54112])
 20:49:01,178 INFO  [STDOUT]
 GMS: address is 10.1.1.2:7900 (cluster=MessagingPostOffice-DATA)
 20:49:01,313 INFO  [QueueService] Queue[/queue/DLQ] started, fullSize=200000, pageSize=2000, downCacheSize=2000
 20:49:02,175 INFO  [ConnectionFactory] Connector bisocket://10.1.1.2:4457 has leasing enabled, lease period 10000 milliseconds
 20:49:02,175 INFO  [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@1604dd0d started
 20:49:02,178 INFO  [TopicService] Topic[/topic/cacheSynchronization] started, fullSize=200000, pageSize=2000, downCacheSize=2000
 20:49:02,205 INFO  [ConnectionFactory] Connector bisocket://10.1.1.2:4457 has leasing enabled, lease period 10000 milliseconds
 20:49:02,206 INFO  [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@40819d8c started
 20:49:02,208 INFO  [QueueService] Queue[/queue/externalEventQueue] started, fullSize=200000, pageSize=2000, downCacheSize=2000
 20:49:02,216 INFO  [ConnectionFactory] Connector bisocket://10.1.1.2:4457 has leasing enabled, lease period 10000 milliseconds
 20:49:02,216 INFO  [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@4b9ac7f5 started
 20:49:02,218 INFO  [QueueService] Queue[/queue/ExpiryQueue] started, fullSize=200000, pageSize=2000, downCacheSize=2000
 20:49:02,219 INFO  [TopicService] Topic[/topic/toplinkSynchronization] started, fullSize=200000, pageSize=2000, downCacheSize=2000
 20:49:02,221 INFO  [QueueService] Queue[/queue/applicationEvent] started, fullSize=200000, pageSize=2000, downCacheSize=2000
 20:49:02,224 INFO  [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=ConnectionFactoryBinding,name=JmsXA' to JNDI name 'java:JmsXA'
 20:49:02,602 INFO  [JBossASKernel] Created KernelDeployment for: profileservice-secured.jar
 20:49:02,605 INFO  [JBossASKernel] installing bean:  jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfile Service,service=EJB3
 20:49:02,605 INFO  [JBossASKernel]   with dependencies:
 20:49:02,605 INFO  [JBossASKernel]   and demands:
 20:49:02,605 INFO  [JBossASKernel]          jndi:SecureManagementView/remote-org.jboss.deployers.spi.man agement.ManagementView
 20:49:02,605 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:02,605 INFO  [JBossASKernel]   and supplies:
 20:49:02,605 INFO  [JBossASKernel]         Class:org.jboss.profileservice.spi.ProfileService
 20:49:02,605 INFO  [JBossASKernel]         jndi:SecureProfileService/remote
 20:49:02,605 INFO  [JBossASKernel]          jndi:SecureProfileService/remote-org.jboss.profileservice.sp i.ProfileService
 20:49:02,605 INFO  [JBossASKernel] Added  bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecurePr ofileService,service=EJB3) to KernelDeployment of: profileservice-secured.jar
 20:49:02,606 INFO  [JBossASKernel] installing bean:  jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploym entManager,service=EJB3
 20:49:02,606 INFO  [JBossASKernel]   with dependencies:
 20:49:02,606 INFO  [JBossASKernel]   and demands:
 20:49:02,606 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:02,606 INFO  [JBossASKernel]   and supplies:
 20:49:02,606 INFO  [JBossASKernel]          jndi:SecureDeploymentManager/remote-org.jboss.deployers.spi. management.deploy.DeploymentManager
 20:49:02,606 INFO  [JBossASKernel]          Class:org.jboss.deployers.spi.management.deploy.DeploymentMa nager
 20:49:02,607 INFO  [JBossASKernel] Added  bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureDe ploymentManager,service=EJB3) to KernelDeployment of: profileservice-secured.jar
 20:49:02,607 INFO  [JBossASKernel] installing bean:  jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagem entView,service=EJB3
 20:49:02,607 INFO  [JBossASKernel]   with dependencies:
 20:49:02,607 INFO  [JBossASKernel]   and demands:
 20:49:02,607 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:02,607 INFO  [JBossASKernel]   and supplies:
 20:49:02,607 INFO  [JBossASKernel]          jndi:SecureManagementView/remote-org.jboss.deployers.spi.man agement.ManagementView
 20:49:02,607 INFO  [JBossASKernel]         Class:org.jboss.deployers.spi.management.ManagementView
 20:49:02,607 INFO  [JBossASKernel] Added  bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureMa nagementView,service=EJB3) to KernelDeployment of: profileservice-secured.jar
 20:49:02,612 INFO  [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@21efcaaf {name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureP rofileService,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
 20:49:02,612 INFO  [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@296a3a9c {name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureD eploymentManager,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
 20:49:02,612 INFO  [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@52231cdb {name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureM anagementView,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
 20:49:02,683 INFO  [SessionSpecContainer] Starting  jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploym entManager,service=EJB3
 20:49:02,691 INFO  [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureDeploymentManager ejbName: SecureDeploymentManager
 20:49:02,723 INFO  [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
 SecureDeploymentManager/remote - EJB3.x Default Remote Business Interface
 SecureDeploymentManager/remote-org.jboss.deployers.spi.manag ement.deploy.DeploymentManager - EJB3.x Remote Business Interface
 20:49:02,772 INFO  [SessionSpecContainer] Starting  jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagem entView,service=EJB3
 20:49:02,772 INFO  [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureManagementView ejbName: SecureManagementView
 20:49:02,782 INFO  [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
 SecureManagementView/remote - EJB3.x Default Remote Business Interface
 SecureManagementView/remote-org.jboss.deployers.spi.manageme nt.ManagementView - EJB3.x Remote Business Interface
 20:49:02,820 INFO  [SessionSpecContainer] Starting  jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfile Service,service=EJB3
 20:49:02,821 INFO  [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureProfileServiceBean ejbName: SecureProfileService
 20:49:02,830 INFO  [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
 SecureProfileService/remote - EJB3.x Default Remote Business Interface
 SecureProfileService/remote-org.jboss.profileservice.spi.Pro fileService - EJB3.x Remote Business Interface
 20:49:02,919 INFO  [TomcatDeployment] deploy, ctxPath=/
 20:49:02,967 INFO  [TomcatDeployment] deploy, ctxPath=/jmx-console
 20:49:09,315 INFO  [JBossASKernel] Created KernelDeployment for: redrock-ejb.jar
 20:49:09,315 INFO  [JBossASKernel] installing bean:  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=PagedLis tAPIImpl,service=EJB3
 20:49:09,315 INFO  [JBossASKernel]   with dependencies:
 20:49:09,315 INFO  [JBossASKernel]   and demands:
 20:49:09,315 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:09,315 INFO  [JBossASKernel]   and supplies:
 20:49:09,315 INFO  [JBossASKernel]          jndi:redrock/PagedListAPIImpl/local-com.attask.api.PagedList APILocal
 20:49:09,315 INFO  [JBossASKernel]         jndi:redrock/PagedListAPIImpl/remote
 20:49:09,316 INFO  [JBossASKernel]          jndi:redrock/PagedListAPIImpl/remote-com.attask.api.PagedLis tAPIRemote
 20:49:09,316 INFO  [JBossASKernel]         Class:com.attask.api.PagedListAPILocal
 20:49:09,316 INFO  [JBossASKernel]         Class:com.attask.api.PagedListAPIRemote
 20:49:09,316 INFO  [JBossASKernel]         jndi:redrock/PagedListAPIImpl/local
 20:49:09,316 INFO  [JBossASKernel] Added  bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Pag edListAPIImpl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
 20:49:09,316 INFO  [JBossASKernel] installing bean:  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJAXAPII mpl,service=EJB3
 20:49:09,316 INFO  [JBossASKernel]   with dependencies:
 20:49:09,317 INFO  [JBossASKernel]   and demands:
 20:49:09,317 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:09,317 INFO  [JBossASKernel]   and supplies:
 20:49:09,317 INFO  [JBossASKernel]         jndi:redrock/AJAXAPIImpl/local
 20:49:09,317 INFO  [JBossASKernel]         jndi:redrock/AJAXAPIImpl/local-com.attask.api.APILocal
 20:49:09,317 INFO  [JBossASKernel]         Class:com.attask.api.APILocal
 20:49:09,317 INFO  [JBossASKernel]         jndi:redrock/AJAXAPIImpl/remote
 20:49:09,317 INFO  [JBossASKernel] Added  bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJA XAPIImpl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
 20:49:09,317 INFO  [JBossASKernel] installing bean:  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=APIImpl, service=EJB3
 20:49:09,317 INFO  [JBossASKernel]   with dependencies:
 20:49:09,317 INFO  [JBossASKernel]         jndi:redrock/APIImpl/remote-com.attask.api.APIRemote
 20:49:09,317 INFO  [JBossASKernel]         Class:com.attask.api.APIRemote
 20:49:09,318 INFO  [JBossASKernel]         Class:com.attask.api.APILocal
 20:49:09,318 INFO  [JBossASKernel]         jndi:redrock/APIImpl/local
 20:49:09,318 INFO  [JBossASKernel]         jndi:redrock/APIImpl/local-com.attask.api.APILocal
 20:49:09,318 INFO  [JBossASKernel] Added  bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=API Impl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
 20:49:09,318 INFO  [JBossASKernel] installing bean:  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=FlashAPI Impl,service=EJB3
 20:49:09,318 INFO  [JBossASKernel]   with dependencies:
 20:49:09,318 INFO  [JBossASKernel]   and demands:
 20:49:09,318 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:09,318 INFO  [JBossASKernel]   and supplies:
 20:49:09,318 INFO  [JBossASKernel]          jndi:redrock/FlashAPIImpl/remote-com.attask.api.FlashAPIRemo te
 20:49:09,318 INFO  [JBossASKernel]         Class:com.attask.api.FlashAPIRemote
 20:49:09,318 INFO  [JBossASKernel]         Class:com.attask.api.FlashAPILocal
 20:49:09,318 INFO  [JBossASKernel]         jndi:redrock/FlashAPIImpl/local
 20:49:09,318 INFO  [JBossASKernel]          jndi:redrock/FlashAPIImpl/local-com.attask.api.FlashAPILocal
 20:49:09,319 INFO  [JBossASKernel] Added  bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Fla shAPIImpl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
 20:49:09,319 INFO  [JBossASKernel] installing bean:  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Applicat ionEventMDB,service=EJB3
 20:49:09,319 INFO  [JBossASKernel]   with dependencies:
 20:49:09,319 INFO  [JBossASKernel]   and demands:
 20:49:09,319 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:09,319 INFO  [JBossASKernel]   and supplies:
 20:49:09,319 INFO  [JBossASKernel]         jndi:null
 20:49:09,319 INFO  [JBossASKernel]         Class:javax.jms.MessageListener
 20:49:09,319 INFO  [JBossASKernel] Added  bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=App licationEventMDB,service=EJB3) to KernelDeployment of: redrock-ejb.jar
 20:49:09,320 INFO  [JBossASKernel] installing bean:  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=CacheSyn chronizationMessageBean,service=EJB3
 20:49:09,320 INFO  [JBossASKernel]   with dependencies:
 20:49:09,320 INFO  [JBossASKernel]   and demands:
 20:49:09,320 INFO  [JBossASKernel]         jboss.ejb:service=EJBTimerService
 20:49:09,320 INFO  [JBossASKernel]   and supplies:
 20:49:09,320 INFO  [JBossASKernel]         jndi:null
 20:49:09,320 INFO  [JBossASKernel]         Class:javax.jms.MessageListener
 20:49:09,320 INFO  [JBossASKernel] Added  bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Cac heSynchronizationMessageBean,service=EJB3) to KernelDeployment of: redrock-ejb.jar
 20:49:09,322 INFO  [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@2a435561 {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AP IImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
 20:49:09,323 INFO  [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@7f608105 {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJ AXAPIImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
 20:49:09,323 INFO  [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@203d7d5 {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Fl ashAPIImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
 20:49:09,323 INFO  [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@d64bda {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Pa gedListAPIImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
 20:49:09,375 INFO  [SessionSpecContainer] Starting  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=PagedLis tAPIImpl,service=EJB3
 20:49:09,376 INFO  [EJBContainer] STARTED EJB: com.attask.api.PagedListAPIImpl ejbName: PagedListAPIImpl
 20:49:09,405 INFO  [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
 redrock/PagedListAPIImpl/remote - EJB3.x Default Remote Business Interface
 redrock/PagedListAPIImpl/remote-com.attask.api.PagedListAPIR emote - EJB3.x Remote Business Interface
 redrock/PagedListAPIImpl/local - EJB3.x Default Local Business Interface
 redrock/PagedListAPIImpl/local-com.attask.api.PagedListAPILo cal - EJB3.x Local Business Interface
 20:49:09,444 INFO  [SessionSpecContainer] Starting  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJAXAPII mpl,service=EJB3
 20:49:09,445 INFO  [EJBContainer] STARTED EJB: com.attask.api.AJAXAPIImpl ejbName: AJAXAPIImpl
 20:49:09,523 INFO  [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
 redrock/AJAXAPIImpl/local - EJB3.x Default Local Business Interface
 redrock/AJAXAPIImpl/local-com.attask.api.APILocal - EJB3.x Local Business Interface
 20:49:09,554 INFO  [SessionSpecContainer] Starting  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=APIImpl, service=EJB3
 20:49:09,555 INFO  [EJBContainer] STARTED EJB: com.attask.api.EJBAPIImpl ejbName: APIImpl
 20:49:09,641 INFO  [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
 redrock/APIImpl/remote - EJB3.x Default Remote Business Interface
 redrock/APIImpl/remote-com.attask.api.APIRemote - EJB3.x Remote Business Interface
 redrock/APIImpl/local - EJB3.x Default Local Business Interface
 redrock/APIImpl/local-com.attask.api.APILocal - EJB3.x Local Business Interface
 20:49:09,672 INFO  [SessionSpecContainer] Starting  jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=FlashAPI Impl,service=EJB3
 20:49:09,673 INFO  [EJBContainer] STARTED EJB: com.attask.api.FlashAPIImpl ejbName: FlashAPIImpl
 20:49:09,789 INFO  [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
 redrock/FlashAPIImpl/remote - EJB3.x Default Remote Business Interface
 redrock/FlashAPIImpl/remote-com.attask.api.FlashAPIRemote - EJB3.x Remote Business Interface
 redrock/FlashAPIImpl/local - EJB3.x Default Local Business Interface
 redrock/FlashAPIImpl/local-com.attask.api.FlashAPILocal - EJB3.x Local Business Interface
 20:49:09,829 INFO  [EJBContainer] STARTED EJB: com.attask.biz.event.ApplicationEventMessageBean ejbName: ApplicationEventMDB
 20:49:09,921 INFO  [EJBContainer] STARTED EJB: com.attask.util.cache.CacheSynchronizationMessageBean ejbName: CacheSynchronizationMessageBean
 20:49:10,125 INFO  [DefaultEndpointRegistry] register: jboss.ws:context=attaskWS,endpoint=APIImpl
 20:49:13,910 INFO  [WSDLFilePublisher] WSDL published to:  file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/data/wsdl/redro ck.ear/redrock-ejb.jar/API.wsdl
 20:49:26,663 INFO  [FiveMinuteTimerEvent] Five Minute Timer Event service created
 20:49:26,698 INFO  [HourlyTimerEvent] Hourly Timer Event service created
 20:49:26,705 INFO  [DailyTimerEvent] Daily Timer Event service created
 20:49:26,764 INFO  [AtTaskStats] AtTaskStats default constructor
 20:49:26,815 INFO  [RedRockApplication] Starting @task 4.0 R12 redrock/branches/version4r12 (build: 760-27784)...
 20:49:27,280 INFO  [Environment] ATTASK_DOC_HOME:/mnt/OD_DOC/attaskHome
| Re: ORA-03137 error while using eclipselink 1.1.1 [message #512581 is a reply to message #512418] | Fri, 05 February 2010 09:46   |  |
| Eclipse User  |  |  |  |  | This is the latest threadstack
 Fri, Feb 5, 2010 6:23 AM
 UpTime: 44:47:18
 http://app01.prod.ut.us.attask-ondemand.com:8080/attask/test /threadStack.jsp
 Free Memory: 5432 MB
 Total Memory: 9895 MB
 Total Threads: 431
 Large Identity Maps
 com.attask.model.RKOpTask	29593
 com.attask.model.RKAssignment	67500
 com.attask.model.RKParameterValue	91899
 com.attask.model.RKPredecessor	19213
 com.attask.model.RKHour	112755
 com.attask.model.RKNote	16155
 com.attask.model.RKUserPrefValue	18226
 com.attask.model.RKTask	29128
 com.attask.model.RKProjectUser	12018
 com.attask.model.RKParameterOption	26001
 Query For Object Locks
 (1310) http-10.1.1.1-8080-34
 RUNNABLE
 5
 java.lang.Thread.dumpThreads(Native Method)
 java.lang.Thread.getAllStackTraces(Thread.java:1487)
 org.apache.jsp.test.threadStack_jsp._jspService(threadStack_ jsp.java:84)
 org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:70)
 javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
 org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
 org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
 org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
 org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
 org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:235)
 org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
 org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:190)
 org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:92)
 org.jboss.web.tomcat.security.SecurityContextEstablishmentVa lve.process(SecurityContextEstablishmentValve.java:126)
 org.jboss.web.tomcat.security.SecurityContextEstablishmentVa lve.invoke(SecurityContextEstablishmentValve.java:70)
 org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
 org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
 org.jboss.web.tomcat.service.jca.CachedConnectionValve.invok e(CachedConnectionValve.java:158)
 org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
 org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:330)
 org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:829)
 org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:598)
 org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
 java.lang.Thread.run(Thread.java:619)
 (2) Reference Handler
 WAITING
 10
 java.lang.Object.wait(Native Method)
 java.lang.Object.wait(Object.java:485)
 java.lang.ref.Reference$ReferenceHandler.run(Reference.java: 116)
 (3) Finalizer
 WAITING
 8
 java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:118)
 java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:134)
 java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:1 59)
 (4) Signal Dispatcher
 RUNNABLE
 9
 (9) DestroyJavaVM
 RUNNABLE
 5
 (12) Timer-0
 TIMED_WAITING
 5
 java.util.TimerThread.mainLoop(Timer.java:509)
 java.util.TimerThread.run(Timer.java:462)
 (14) Timer-Log4jService
 TIMED_WAITING
 5
 (15) JBoss System Threads(1)-1
 RUNNABLE
 5
 java.net.PlainSocketImpl.socketAccept(Native Method)
 java.net.PlainSocketImpl.accept(PlainSocketImpl.java:390)
 java.net.ServerSocket.implAccept(ServerSocket.java:453)
 java.net.ServerSocket.accept(ServerSocket.java:421)
 org.jboss.web.WebServer.run(WebServer.java:320)
 org.jboss.util.threadpool.RunnableTaskWrapper.run(RunnableTa skWrapper.java:147)
 java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
 java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
 (16) RMI TCP Accept-1098
 RUNNABLE
 5
 sun.rmi.transport.tcp.TCPTransport$AcceptLoop.executeAcceptL oop(TCPTransport.java:369)
 sun.rmi.transport.tcp.TCPTransport$AcceptLoop.run(TCPTranspo rt.java:341)
 (17) RMI Reaper
 WAITING
 5
 sun.rmi.transport.ObjectTable$Reaper.run(ObjectTable.java:33 3)
 (18) GC Daemon
 TIMED_WAITING
 2
 sun.misc.GC$Daemon.run(GC.java:100)
 (19) JBoss System Threads(1)-2
 RUNNABLE
 5
 org.jnp.server.Main$AcceptHandler.run(Main.java:597)
 (20) SubscriptionWatchDog
 TIMED_WAITING
 5
 java.lang.Thread.sleep(Native Method)
 org.jboss.ws.extensions.eventing.mgmt.SubscriptionManager$Wa tchDog.run(SubscriptionManager.java:653)
 (21) JBoss System Threads(1)-3
 WAITING
 5
 sun.misc.Unsafe.park(Native Method)
 java.util.concurrent.locks.LockSupport.park(LockSupport.java :158)
 java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject.await(AbstractQueuedSynchronizer.java:1925)
 java.util.concurrent.LinkedBlockingQueue.take(LinkedBlocking Queue.java:358)
 java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolEx ecutor.java:947)
 java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
 (23) RMI Scheduler(0)
 TIMED_WAITING
 5
 java.util.concurrent.locks.LockSupport.parkNanos(LockSupport .java:198)
 java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject.awaitNanos(AbstractQueuedSynchronizer.java:1963)
 java.util.concurrent.DelayQueue.take(DelayQueue.java:164)
 java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:583)
 java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:576)
 (24) JBoss System Threads(1)-4
 WAITING
 5
 (25) RMI TCP Accept-1090
 RUNNABLE
 5
 (26) RMI TCP Accept-0
 RUNNABLE
 5
 (27) RMI RenewClean-[10.1.1.1:34154]
 TIMED_WAITING
 5
 sun.rmi.transport.DGCClient$EndpointEntry$RenewCleanThread.r un(DGCClient.java:516)
 (29) ServerSocketRefresh
 WAITING
 5
 org.jboss.remoting.transport.socket.SocketServerInvoker$Serv erSocketRefresh.run(SocketServerInvoker.java:844)
 (30)  AcceptorThread[ServerSocket[addr=/10.1.1.1,port=0,localport= 4457]]
 RUNNABLE
 5
 org.jboss.remoting.transport.socket.SocketServerInvoker.acce pt(SocketServerInvoker.java:1109)
 org.jboss.remoting.transport.socket.SocketServerInvoker.acce ss$200(SocketServerInvoker.java:70)
 org.jboss.remoting.transport.socket.SocketServerInvoker$Acce ptThread.run(SocketServerInvoker.java:1020)
 (31) secondaryServerSocketThread[0]
 RUNNABLE
 5
 org.jboss.remoting.transport.bisocket.BisocketServerInvoker$ SecondaryServerSocketThread$1.run(BisocketServerInvoker.java :1110)
 java.security.AccessController.doPrivileged(Native Method)
 org.jboss.remoting.transport.bisocket.BisocketServerInvoker$ SecondaryServerSocketThread.run(BisocketServerInvoker.java:1 106)
 (32) ServerSocketRefresh
 WAITING
 5
 (33)  AcceptorThread[ServerSocket[addr=/10.1.1.1,port=0,localport= 3873]]
 RUNNABLE
 5
 (35) JBoss System Threads(1)-5
 WAITING
 5
 (36) Timer-1,10.1.1.1:47891
 TIMED_WAITING
 5
 (37) FD_SOCK server socket acceptor,null
 RUNNABLE
 5
 org.jgroups.protocols.FD_SOCK$ServerSocketHandler.run(FD_SOC K.java:1022)
 (38) DiagnosticsHandler,10.1.1.1:47891
 RUNNABLE
 5
 java.net.PlainDatagramSocketImpl.receive0(Native Method)
 java.net.PlainDatagramSocketImpl.receive(PlainDatagramSocket Impl.java:136)
 java.net.DatagramSocket.receive(DatagramSocket.java:712)
 org.jgroups.protocols.TP$DiagnosticsHandler.run(TP.java:2199 )
 (39) UDP ucast,10.1.1.1:47891
 RUNNABLE
 5
 org.jgroups.protocols.UDP$UcastReceiver.run(UDP.java:946)
 (40) UDP mcast,10.1.1.1:47891
 RUNNABLE
 10
 org.jgroups.protocols.UDP.run(UDP.java:262)
 (41) Timer-2,10.1.1.1:47891
 TIMED_WAITING
 5
 (45) Timer-3,10.1.1.1:47891
 TIMED_WAITING
 5
 (47) Incoming-1,10.1.1.1:47891
 WAITING
 10
 (48) Incoming-2,10.1.1.1:47891
 WAITING
 10
 (49) Timer-4,10.1.1.1:47891
 TIMED_WAITING
 5
 (50) FD_SOCK server socket acceptor,10.1.1.1:47891
 RUNNABLE
 5
 (51) Timer-5,10.1.1.1:47891
 TIMED_WAITING
 5
 (52) Timer-6,10.1.1.1:47891
 TIMED_WAITING
 5
 (53) Incoming-3,10.1.1.1:47891
 WAITING
 10
 (54) Incoming-4,10.1.1.1:47891
 WAITING
 5
 (55) Incoming-5,10.1.1.1:47891
 WAITING
 10
 (56) Timer-7,10.1.1.1:47891
 TIMED_WAITING
 5
 (57) FD_SOCK pinger,tempOD,10.1.1.1:47891
 RUNNABLE
 5
 java.net.SocketInputStream.socketRead0(Native Method)
 java.net.SocketInputStream.read(SocketInputStream.java:129)
 java.net.SocketInputStream.read(SocketInputStream.java:182)
 org.jgroups.protocols.FD_SOCK.run(FD_SOCK.java:425)
 (58) Timer-8,10.1.1.1:47891
 TIMED_WAITING
 5
 (60) Timer-9,10.1.1.1:47891
 TIMED_WAITING
 5
 (61) Incoming-6,10.1.1.1:47891
 WAITING
 10
 (62) Incoming-7,10.1.1.1:47891
 WAITING
 5
 (63) Timer-10,10.1.1.1:47891
 TIMED_WAITING
 5
 (64) FD_SOCK pinger,tempOD-HAPartitionCache,10.1.1.1:47891
 RUNNABLE
 5
 (65) Timer-11,10.1.1.1:47891
 TIMED_WAITING
 5
 (66) Timer-12,10.1.1.1:47891
 TIMED_WAITING
 5
 (68) Incoming-8,10.1.1.1:47891
 WAITING
 5
 (69) Incoming-9,10.1.1.1:47891
 WAITING
 5
 (70) Incoming-10,10.1.1.1:47891
 WAITING
 10
 (71) Incoming-11,10.1.1.1:47891
 WAITING
 5
 (72) Incoming-12,10.1.1.1:47891
 WAITING
 10
 (73) Incoming-13,10.1.1.1:47891
 WAITING
 5
 (74) Incoming-14,10.1.1.1:47891
 WAITING
 5
 (75) Incoming-15,10.1.1.1:47891
 WAITING
 5
 (76) Incoming-16,10.1.1.1:47891
 WAITING
 5
 (77) RMI RenewClean-[10.1.1.3:1101]
 TIMED_WAITING
 5
 (78) RMI RenewClean-[10.1.1.2:1101]
 TIMED_WAITING
 5
 (80) Incoming-17,10.1.1.1:47891
 WAITING
 5
 (81) Incoming-18,10.1.1.1:47891
 WAITING
 10
 (82) AsynchKeyChangeHandler Thread
 WAITING
 5
 org.jboss.ha.framework.server.AsynchEventHandler.run(AsynchE ventHandler.java:103)
 (83) AsynchViewChangeHandler Thread
 WAITING
 5
 (84) RMI TCP Accept-1101
 RUNNABLE
 5
 (85) Incoming-19,10.1.1.1:47891
 WAITING
 5
 (86) Incoming-20,10.1.1.1:47891
 WAITING
 10
 (89) JBoss System Threads(1)-6
 RUNNABLE
 5
 org.jboss.ha.jndi.DetachedHANamingService$AcceptHandler.run( DetachedHANamingService.java:821)
 (90) JBoss System Threads(1)-7
 RUNNABLE
 5
 org.jboss.ha.jndi.DetachedHANamingService$AutomaticDiscovery .run(DetachedHANamingService.java:640)
 (91) HDScanner
 TIMED_WAITING
 5
 (92) ServerSocketRefresh
 WAITING
 5
 (93)  AcceptorThread[ServerSocket[addr=/10.1.1.1,port=0,localport= 4446]]
 RUNNABLE
 5
 (94) Listener:4713
 RUNNABLE
 5
 com.arjuna.ats.internal.arjuna.recovery.Listener.run(Listene r.java:118)
 (96) Thread-9
 TIMED_WAITING
 5
 com.arjuna.ats.internal.arjuna.coordinator.ReaperThread.run( ReaperThread.java:98)
 (97) Thread-10
 WAITING
 5
 com.arjuna.ats.arjuna.coordinator.TransactionReaper.waitForC ancellations(TransactionReaper.java:504)
 com.arjuna.ats.internal.arjuna.coordinator.ReaperWorkerThrea d.run(ReaperWorkerThread.java:74)
 (98) Thread-11
 TIMED_WAITING
 5
 com.arjuna.ats.internal.arjuna.recovery.ExpiredEntryMonitor. run(ExpiredEntryMonitor.java:237)
 (99) Thread-12
 TIMED_WAITING
 5
 com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.doB ackoffWait(PeriodicRecovery.java:660)
 com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.doW orkInternal(PeriodicRecovery.java:765)
 com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.run (PeriodicRecovery.java:412)
 (101) Listener:4712
 RUNNABLE
 5
 (102) PooledInvokerAcceptor#0-4448
 RUNNABLE
 5
 org.jboss.invocation.pooled.server.PooledInvoker.run(PooledI nvoker.java:262)
 (103) RMI TCP Accept-4444
 RUNNABLE
 5
 (104) RMI TCP Accept-4447
 RUNNABLE
 5
 (105) PooledInvokerAcceptor#0-4445
 RUNNABLE
 5
 (106) ContainerBackgroundProcessor[StandardEngine[jboss.web]]
 TIMED_WAITING
 5
 org.apache.catalina.core.ContainerBase$ContainerBackgroundPr ocessor.run(ContainerBase.java:1590)
 (107) WorkManager(2)-1
 WAITING
 5
 java.util.concurrent.PriorityBlockingQueue.take(PriorityBloc kingQueue.java:220)
 org.jboss.resource.adapter.mail.inflow.NewMsgsWorker.run(New MsgsWorker.java:76)
 org.jboss.resource.work.WorkWrapper.execute(WorkWrapper.java :205)
 org.jboss.util.threadpool.BasicTaskWrapper.run(BasicTaskWrap per.java:260)
 (108) DefaultQuartzScheduler_Worker-0
 TIMED_WAITING
 5
 org.quartz.simpl.SimpleThreadPool.getNextRunnable(SimpleThre adPool.java:428)
 org.quartz.simpl.SimpleThreadPool.access$000(SimpleThreadPoo l.java:47)
 org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThr eadPool.java:518)
 (109) DefaultQuartzScheduler_Worker-1
 TIMED_WAITING
 5
 (110) DefaultQuartzScheduler_Worker-2
 TIMED_WAITING
 5
 (111) DefaultQuartzScheduler_Worker-3
 TIMED_WAITING
 5
 (112) DefaultQuartzScheduler_Worker-4
 TIMED_WAITING
 5
 (113) DefaultQuartzScheduler_Worker-5
 TIMED_WAITING
 5
 (114) DefaultQuartzScheduler_Worker-6
 TIMED_WAITING
 5
 (115) DefaultQuartzScheduler_Worker-7
 TIMED_WAITING
 5
 (116) DefaultQuartzScheduler_Worker-8
 TIMED_WAITING
 5
 (117) DefaultQuartzScheduler_Worker-9
 TIMED_WAITING
 5
 (118) DefaultQuartzScheduler_QuartzSchedulerThread
 TIMED_WAITING
 5
 org.quartz.core.QuartzSchedulerThread.run(QuartzSchedulerThr ead.java:394)
 (119) IdleRemover
 TIMED_WAITING
 5
 org.jboss.resource.connectionmanager.IdleRemover$IdleRemover Runnable.run(IdleRemover.java:167)
 (121) Thread-13
 TIMED_WAITING
 5
 org.jboss.messaging.core.impl.memory.SimpleMemoryManager$Mem oryRunnable.run(SimpleMemoryManager.java:126)
 (124) Scheduler main thread
 WAITING
 5
 org.jgroups.util.Queue.peek(Queue.java:399)
 org.jgroups.util.Scheduler.run(Scheduler.java:76)
 (125) FD_SOCK server socket acceptor,10.1.1.1:47891
 RUNNABLE
 5
 (127) FD_SOCK pinger,MessagingPostOffice-CTRL,10.1.1.1:47891
 RUNNABLE
 5
 (129) Timer-1,10.1.1.1:7900
 TIMED_WAITING
 5
 (130) FD_SOCK server socket acceptor,null
 RUNNABLE
 5
 (131) ReceiverThread
 RUNNABLE
 5
 org.jgroups.protocols.MPING.run(MPING.java:365)
 (132) DiagnosticsHandler,10.1.1.1:7900
 RUNNABLE
 5
 (133) ConnectionTable.AcceptorThread,10.1.1.1:7900
 RUNNABLE
 5
 org.jgroups.blocks.ConnectionTable.run(ConnectionTable.java: 239)
 (134) Timer-2,10.1.1.1:7900
 TIMED_WAITING
 5
 (135) ConnectionTable.Connection.Receiver [10.1.1.1:7900 - 10.1.1.2:40560],10.1.1.1:7900
 RUNNABLE
 5
 java.io.BufferedInputStream.fill(BufferedInputStream.java:21 8)
 java.io.BufferedInputStream.read(BufferedInputStream.java:23 7)
 java.io.DataInputStream.readInt(DataInputStream.java:370)
 org.jgroups.blocks.BasicConnectionTable$Connection.run(Basic ConnectionTable.java:659)
 (139) Timer-3,10.1.1.1:7900
 TIMED_WAITING
 5
 (140) Incoming-1,10.1.1.1:7900
 WAITING
 5
 (141) Timer-4,10.1.1.1:7900
 TIMED_WAITING
 5
 (142) FD_SOCK pinger,MessagingPostOffice-DATA,10.1.1.1:7900
 RUNNABLE
 5
 (144) Incoming-2,10.1.1.1:7900
 WAITING
 5
 (145) Incoming-3,10.1.1.1:7900
 WAITING
 5
 (146) Incoming-4,10.1.1.1:7900
 WAITING
 5
 (147) Timer-1
 TIMED_WAITING
 5
 (148) Incoming-5,10.1.1.1:7900
 WAITING
 5
 (149) Incoming-6,10.1.1.1:7900
 WAITING
 5
 (150) Timer-2
 TIMED_WAITING
 5
 (151) control: Socket[addr=/10.1.1.2,port=12850,localport=37398]
 Current Time: Fri Oct 31 03:01:36 EDT 2025
 Powered by FUDForum . Page generated in 0.04519 seconds |
