Home » Eclipse Projects » Remote Application Platform (RAP) » Widget Disposed Exception with RAP 1.3M4
Widget Disposed Exception with RAP 1.3M4 [message #511908] |
Wed, 03 February 2010 07:03  |
hi, i got the following problem:
i have a login composite for a rap app created and it is loaded before the main windows is shown:
public int login() {
refresh();
if (login.open() == Dialog.OK) {
String username = login.getUsername();
String password = login.getPassword();
if (UserManagement.getInstance().authenticate(new LoginRequest(new UserBean(username, password), RWT.getRequest().getRemoteAddr()))) {
Shell shell = new Shell(PlatformUI.createDisplay(), SWT.NO_TRIM | SWT.ON_TOP);
WorkbenchAdvisor advisor = new ApplicationWorkbenchAdvisor();
Remote.getInstance().addActiveUser(UserManagement.getInstanc e().getActiveUser().getUserId(), shell.getDisplay());
UserManagement.getInstance().addUserSession(UserManagement.g etInstance().getActiveUser());
PlatformUI.createAndRunWorkbench(shell.getDisplay(), advisor);
} else {
// show errormessage
it worked fine with RAP 1.3 M3 but now i wanted to switch to M$ to use drag & drop but on the red codeline im getting the following ecxeption::
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2687)
at org.eclipse.swt.SWT.error(SWT.java:2607)
at org.eclipse.swt.SWT.error(SWT.java:2578)
at org.eclipse.swt.widgets.Widget.error(Widget.java:892)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:828)
at org.eclipse.swt.widgets.Widget.getData(Widget.java:208)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(W orkbench.java:1074)
at org.eclipse.ui.internal.services.ActivePartSourceProvider.ge tCurrentState(ActivePartSourceProvider.java:248)
at org.eclipse.ui.internal.services.ExpressionAuthority.addSour ceProvider(ExpressionAuthority.java:89)
at org.eclipse.ui.internal.services.EvaluationService.addSource Provider(EvaluationService.java:75)
at org.eclipse.ui.internal.Workbench$38.runWithException(Workbe nch.java:1607)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:115)
at org.eclipse.swt.widgets.Display$2.run(Display.java:909)
at org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 460)
at org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:907)
at org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices( Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1300)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2317)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 06)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:424)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.jface.internal.databinding.realmadapter.RealmAda pter.run(RealmAdapter.java:44)
at org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault( RealmAdapterHook.java:48)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:427)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at acsa.versand.run.ApplicationContext.showWorkbech(Application Context.java:92)
any idea what changed since M3 to cause this?
thx, Edin
Re: Widget Disposed Exception with RAP 1.3M4 [message #511925 is a reply to message #511908] |
Wed, 03 February 2010 07:47   |
Hi Edin,
I'm not aware of any changes in this area and how a disposed shell could
be the Displays active shell. Are you able to build a small entrypoint
to reproduce this? I already tried to reproduce it but without any
success. You may even want to check against CVS HEAD if this is still an
issue.
If you can reproduce it, please open a bug report with a snippet. Thanks!
Ben
> refresh();
> } else {
> orkbench.java:1074)
> nch.java:1607)
> (Realm.java:332)
> bench.java:427)
> ava:157)
> Context.java:92)
> thx, Edin
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Widget Disposed Exception with RAP 1.3M4 [message #519559 is a reply to message #519551] |
Tue, 09 March 2010 05:18   |
Ralf,
make sure your widget is not disposed, i.e. Text#isDisposed returns false.
HTH
Rüdiger
On 09.03.2010 10:55, R. Heydenreich wrote:
> ededagic schrieb:
>> Hello,
>> today i set the target platform to the new M5, and now it seems to work.
>> So i think there is no need more to check whether it was a bug or not,
>> now its away.
>> Greetings, Edin
> I get the same problem with RAP 1.3.0M5. The Exception is:
> at org.eclipse.swt.SWT.error(SWT.java:2841)
> at org.eclipse.swt.SWT.error(SWT.java:2761)
> at org.eclipse.swt.SWT.error(SWT.java:2732)
> at org.eclipse.swt.widgets.Widget.error(Widget.java:954)
> at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:890)
> at org.eclipse.swt.widgets.Text.getText(Text.java:169)
> at de.myapp.list.MyDialog.getReason(MyDialog.java:80)
> MyDialog is a class which extends MessageDialog, and getReason is a
> getter for the private field "reason". If I call this method, the
> exception occurs. In RAP 1.2.2 this worked. Any ideas?
> TIA,
> Ralf.
Re: Widget Disposed Exception with RAP 1.3M4 [message #519631 is a reply to message #519559] |
Tue, 09 March 2010 04:44   |
Rüdiger Herrmann schrieb:
> Ralf,
This is not the case, isDisposed() returns true. But how can I achieve
that the widget isn't disposed if I press the OK button?
TIA,
Ralf.
>> ededagic schrieb:
>>> Hello,
>>> now its away.
>>> Greetings, Edin
>> TIA,
>> Ralf.
Re: Widget Disposed Exception with RAP 1.3M4 [message #519734 is a reply to message #519631] |
Tue, 09 March 2010 09:32   |
Ralf,
you'd rather want to preserve the value of the text widget before the
dialog gets disposed of, e.g. in okPressed().
HTH
Rüdiger
>> Ralf,
> TIA,
> Ralf.
>>> ededagic schrieb:
>>>> Hello,
>>>> now its away.
>>>> Greetings, Edin
>>> Hi,
>>> TIA,
>>> Ralf.
Rüdiger Herrmann
http://eclipsesource.com
Re: Widget Disposed Exception with RAP 1.3M4 [message #519841 is a reply to message #519734] |
Tue, 09 March 2010 21:50  |
> Ralf,
> HTH
Ah, ok, this works. Thanks a lot.
Ralf.
> Rüdiger
>>> Ralf,
>>> false.
>> TIA,
>> Ralf.
>>>> ededagic schrieb:
>>>>> Hello,
>>>>> work.
>>>>> not,
>>>>> now its away.
>>>>> Greetings, Edin
>>>> Hi,
>>>> TIA,
>>>> Ralf.
Current Time: Sun Sep 07 03:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.04149 seconds
