Home » Modeling » EMF » [CDO] CDO Model Corruption
[CDO] CDO Model Corruption [message #511688] |
Tue, 02 February 2010 09:39  |
I imported two models on a CDO 2.0 server. Those models (let us call them A and B) are consistent
with two different metamodels MMA and MMB (A with MMA, B with MMB). Some EClasses of MMA and MMB
have the same name.
When i execute my program (a client of the CDO server), I get the following error popup:
An error has occurred. See error log for mode details.
org.eclipse.net4j.signal.RemoteException.
java.lang.ClassCastException : java.lang.Boolean cannot be cast to java.lang.String
If I launch the navigator view, and then load the model, I get the following error:
A protocol problem occurred in CDOSession after 1 attempt.
This error occurs regularly, with a ratio of about one out of ten times. Once I get this
problem, it seems like the only way to fix it is to delete my database and restart the CDO server.
So I have two questions:
1. Could the fact that I have 2 meta model which define a class with the same names cause problems on CDO?
(note that this happen even if the property "QualifiedName" is set to "true").
If so, is there a workaround for this problem? Did I forget to configure something?
For refrence, here is a excerpt from my cdo-server.xml :
<store type="db">
<mappingStrategy type="horizontal">
<property name="qualifiedNames" value="true"/>
<property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
<dbAdapter name="postgresql"/>
<dataSource class="org.postgresql.ds.PGSimpleDataSource"
url="jdbc:postgresql://localhost:5432/cdo"
databaseName="cdo"
user="postgres"
password="XX"/>
</store>
Here is the stack trace I get at runtime :
[ERROR] [Ljava.lang.StackTraceElement;
java.lang.ClassNotFoundException: [Ljava.lang.StackTraceElement;
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:483)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
org.eclipse.net4j.signal.RemoteException: java.lang.ClassCastException: java.lang.Boolean cannot be cast to java.lang.String
at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteEx ception(RequestWithConfirmation.java:128)
at org.eclipse.net4j.signal.SignalProtocol.handleRemoteExceptio n(SignalProtocol.java:494)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicatin g(RemoteExceptionIndication.java:53)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indicati on.java:55)
Caused by: java.lang.ClassCastException: java.lang.Boolean cannot be cast to java.lang.String
at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$25.wri teValue(CDOTypeImpl.java:590)
at org.eclipse.emf.cdo.internal.common.io.CDODataOutputImpl.wri teCDOFeatureValue(CDODataOutputImpl.java:271)
at org.eclipse.emf.cdo.spi.common.revision.AbstractCDORevision. writeValues(AbstractCDORevision.java:661)
Gaëtan.
Re: [CDO] CDO Model Corruption [message #511826 is a reply to message #511688] |
Wed, 03 February 2010 01:48   |
Hi Gaëtan,
Comments below...
Gaetan schrieb:
> have the same name.
It would probably help to give us the complete stack trace.
> java.lang.String
> following error: A protocol problem occurred in CDOSession after 1
> attempt.
Generally yes.
> "true").
Then no, this should enable you to store models with the same EClass name.
> For refrence, here is a excerpt from my cdo-server.xml : <store
> type="db">
> </mappingStrategy>
> databaseName="cdo"
> user="postgres"
> password="XX"/>
> </store>
Ah, here it is ;-)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> java.lang.String
> on.java:55)
The trace indicates a problem with custom EDataTypes. IIRC we fixed
several issues in this area. Can you please try in this order:
1) Checkout the latest sources from the 2.0 maintenance branch and try
with those (Let me know if you need pointers)
2) Checkout HEAD or use yesterdays M5 build from the helios repository
and try with CDO 3.0
If that shows that your particular issue has not yet been solved, we'll
investigate further.
Cheers
/Eike
Re: [CDO] CDO Model Corruption [message #514042 is a reply to message #511688] |
Fri, 12 February 2010 04:41   |
Eike, Victor,
Thanks for your answer.
Following your advice, I have checked out the latest CDO versions from CVS, and I have ran my code on:
- CDO 2.0 (the latest 2.0 maintenance branch version on CVS) with Mysql and Postgres,
- CD0 3.0 (the latest version Head branch) with Mysql and Postgres,
I still very regularly reproduce the error I am struggling with, either on CDO 2.0 or 3.0:
- on the CDO server I get:
java.lang.Integer cannot be cast to java.lang.String
java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$25.writeValue(CDOTypeImpl.java:589)
at org.eclipse.emf.cdo.internal.common.io.CDODataOutputImpl.writeCDOFeatureValue(CDODataOutputImpl.java:296)
at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.writeValues(BaseCDORevision.java:640)
at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.write(BaseCDORevision.java:182)
at org.eclipse.emf.cdo.internal.common.io.CDODataOutputImpl.writeCDORevision(CDODataOutputImpl.java:211)
at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.writeRevision(RevisionInfo.java:183)
at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.writeResult(RevisionInfo.java:134)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevisionsIndication.responding(LoadRevisionsIndication.java:186)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:119)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:96)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:281)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOReadIndication.execute(CDOReadIndication.java:36)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:238)
at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
- on the CDO client I get:
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:483)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:399)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:87)
at org.eclipse.net4j.util.io.ExtendedIOUtil$ClassLoaderClassResolver.resolveClass(ExtendedIOUtil.java:231)
at org.eclipse.net4j.util.io.ExtendedIOUtil$3.resolveClass(ExtendedIOUtil.java:163)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readArray(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.defaultReadFields(Unknown Source)
at java.io.ObjectInputStream.readSerialData(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:177)
at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:131)
at org.eclipse.net4j.util.io.ExtendedDataInputStream.readObject(ExtendedDataInputStream.java:46)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:46)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:55)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:311)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:49)
org.eclipse.net4j.signal.RemoteException: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:128)
at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:495)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:53)
Caused by: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
... 5 more
Do you have any hint which would help me solving this?
BTW, both links to developpers PSF file on http://wiki.eclipse.org/CDO_Source_Installation seems broken ("unknown location" error on viewcvs page).
Gaëtan.
Re: [CDO] CDO Model Corruption [message #514060 is a reply to message #514042] |
Fri, 12 February 2010 00:44   |
Am 12.02.2010 10:41, schrieb Gaetan:
> Eike, Victor,
> CVS, and I have ran my code on: - CDO 2.0 (the latest 2.0
> - on the CDO server I get: java.lang.Integer cannot be cast to
> java.lang.String
> java.lang.String
> at
> org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$25.wri teValue(CDOTypeImpl.java:589)
> at
> org.eclipse.emf.cdo.internal.common.io.CDODataOutputImpl.wri teCDOFeatureValue(CDODataOutputImpl.java:296)
Can you set a breakpoint here and tell which feature is causing the problem?
Cheers
/Eike
> at
> org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.writ eValues(BaseCDORevision.java:640)
> at
> org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.writ e(BaseCDORevision.java:182)
> at
> org.eclipse.emf.cdo.internal.common.io.CDODataOutputImpl.wri teCDORevision(CDODataOutputImpl.java:211)
> at
> org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.writeRe vision(RevisionInfo.java:183)
> at
> org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.writeRe sult(RevisionInfo.java:134)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevis ionsIndication.responding(LoadRevisionsIndication.java:186)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServer Indication.responding(CDOServerIndication.java:119)
> at
> org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOu tput(IndicationWithResponse.java:96)
> at
> org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:65)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOReadIn dication.execute(CDOReadIndication.java:36)
> at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
> - on the CDO client I get: [Ljava.lang.StackTraceElement;
> at
> at
> at
> at
> at
> org.eclipse.net4j.util.io.ExtendedIOUtil$ClassLoaderClassRes olver.resolveClass(ExtendedIOUtil.java:231)
> at
> org.eclipse.net4j.util.io.ExtendedIOUtil$3.resolveClass(Exte ndedIOUtil.java:163)
> at
> org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(Extended IOUtil.java:177)
> at
> org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(Extended IOUtil.java:131)
> at
> org.eclipse.net4j.util.io.ExtendedDataInputStream.readObject (ExtendedDataInputStream.java:46)
> at
> org.eclipse.net4j.signal.RemoteExceptionIndication.indicatin g(RemoteExceptionIndication.java:46)
> at
> at org.eclipse.net4j.signal.Indication.execute(Indication.java: 49)
> java.lang.String
> at
> at
> org.eclipse.net4j.signal.SignalProtocol.handleRemoteExceptio n(SignalProtocol.java:495)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 5 more
> Gaëtan.
Re: [CDO] CDO Model Corruption [message #514071 is a reply to message #514042] |
Fri, 12 February 2010 06:00   |
Hi Gaetan,
see some comments below:
> on CDO 2.0 or 3.0:
> java.lang.String
> java.lang.String
> at
That seems odd, could you provide information about your model?
Eike is working to automate all the source installation using
Buckminster, so the old development scripts have been deprecated.
You can still access that PSF file through:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/deprecated/develop/setup/psf/pserver/.boots trap.psf?root=Modeling_Project&view=co
but soon a new tutorial for source installation will be published.
Re: [CDO] CDO Model Corruption [message #514122 is a reply to message #514074] |
Fri, 12 February 2010 08:52   |
Eike, Victor,
As you suggested, I have set a "ClassCastException" breakpoint in the server code, which led to the following observation.
The model feature where the problem occurs is of an Integer type, but the CDO code handling it directly casts from Object to String :
public void writeValue(CDODataOutput out, Object value) throws IOException
out.writeString((String)value);
Replacing this code by the following one fixed my problem:
out.writeString(String.valueOf(value));
Is my analysis correct? If so, would you be so kind as to consider patching CDO branches with this fix?
Gaëtan.
Re: [CDO] CDO Model Corruption [message #514169 is a reply to message #514122] |
Fri, 12 February 2010 11:50   |
Am 12.02.2010 14:52, schrieb Gaetan:
> Eike, Victor,
The question is, why does CDO choose this partuclar CDOType. Which one
is it exactly? STRING or CUSTOM?
Please also paste in here the part of your ecore file that defines this
feature.
Cheers
/Eike
> IOException
> IOException
No, the problem is elsewhere.
Cheers
/Eike
Re: [CDO] CDO Model Corruption [message #514198 is a reply to message #514184] |
Fri, 12 February 2010 14:02   |
Am 12.02.2010 18:46, schrieb Gaetan:
>> Eike, Victor,
> Preview of my model:
> <parent xsi:type="XX:Element">
> <source xsi:type="XX:IntType" value="0"/> <target xsi:type="XX:XXType"
> name="XX"/>
> </parent>
> Preview of my meta model:
> <eClassifiers xsi:type="ecore:EClass" name="IntType">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="value"
> ordered="false" unique="false" lowerBound="1" eType="/1/Integer"/>
I talked to Ed and we think that looks strange. Do you have more than
one top-level EPackage in your ecore resource?
Please try again with standard models, i.e. one top-level package per
model, ideally no nested packages (but CDO should support the latter).
Cheers
/Eike
> </eClassifiers>
> <ecore:EPackage name="PrimitiveTypes" nsURI="XXPrimitiveTypes"
> nsPrefix="XX">
> <eClassifiers xsi:type="ecore:EDataType" name="Integer"
> instanceClassName="int"/>
> </ecore:EPackage>
> Gaëtan.
Re: [CDO] CDO Model Corruption [message #515980 is a reply to message #515960] |
Mon, 22 February 2010 06:54  |
Gaëtan,
Yes, they're definitely a bad idea.
Eike Stepper wrote:
> Hi Gaëtan,
> Nothing in EMF creates models with multiple root packages. I think
> they're just bad practice.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 22.02.2010 10:59, schrieb Gaetan:
>> Eike,
>> Indeed, modifying our metamodel so that only one EPackage was at its
>> root fixed our problem.
>> We would be interested in understanding in greater details what you
>> mean by "standard models", though. Are models with multiple root
>> packages erroneous from an EMF point of view? Or are they simply bad
>> practices that you chose not to support in CDO?
>> We had noticed that those metamodels were hard to use in genmodel
>> tools, but EMF manipulates XMI models conforming to them just fine.
>> Regards,
>> Gaëtan.
Current Time: Wed Sep 10 22:16:01 EDT 2025
Powered by FUDForum. Page generated in 0.04519 seconds
