Re: Problem with Eclipse BPEL plugin and org.eclipse.jface [message #541581 is a reply to message #511507] |
Mon, 21 June 2010 15:30 |
On 2/1/2010 2:37 PM, gustavo.romerorz@gmail.com wrote:
> Hello
> Im working with Eclipse and Apache ODE (HelloWorld example). Im trying
> to set up de deploy params to the binding port in my ODE deploy
> descriptor with the Eclipse plug in and I got this error:
> Problems occurred when invoking code from plug-in: "org.eclipse.jface".
> stacktrace:
> java.lang.LinkageError: javax/wsdl/Binding
> at org.eclipse.bpel.apache.ode.deploy.ui.pages.ProcessPage$Port
> TypeLabelProvider.getColumnText(ProcessPage.java:648)
> at org.eclipse.jface.viewers.TableColumnViewerLabelProvider.upd
> ate(TableColumnViewerLabelProvider.java:70)
> at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
> at org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(A
> bstractTableViewer.java:399)
> at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun
> nable.run(StructuredViewer.java:481)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.runtime.Platform.run(Platform.java:888)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct
> uredViewer.java:2111)
> at org.eclipse.jface.viewers.AbstractTableViewer.internalRefres
> hAll(AbstractTableViewer.java:711)
> h(AbstractTableViewer.java:649)
> h(AbstractTableViewer.java:636)
> at org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV
> iewer.java:1457)
> at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti
> on(StructuredViewer.java:1392)
> on(StructuredViewer.java:1353)
> at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure
> dViewer.java:1455)
> at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:537)
> dViewer.java:1414)
> at org.eclipse.bpel.apache.ode.deploy.ui.pages.ProcessPage$Inte
> rfaceWidgetCellModifier.modify(ProcessPage.java:444)
> at org.eclipse.jface.viewers.ColumnViewer$2.setValue(ColumnView
> er.java:274)
> at org.eclipse.jface.viewers.EditingSupport.saveCellEditorValue
> (EditingSupport.java:113)
> at org.eclipse.jface.viewers.ColumnViewerEditor.saveEditorValue
> (ColumnViewerEditor.java:455)
> at org.eclipse.jface.viewers.ColumnViewerEditor.applyEditorValu
> e(ColumnViewerEditor.java:311)
> at org.eclipse.jface.viewers.ColumnViewerEditor$2.applyEditorVa
> lue(ColumnViewerEditor.java:153)
> at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 33)
> at org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce
> llEditor.java:331)
> at org.eclipse.jface.viewers.ComboBoxCellEditor.applyEditorValu
> eAndDeactivate(ComboBoxCellEditor.java:273)
> at org.eclipse.jface.viewers.ComboBoxCellEditor.focusLost(Combo
> BoxCellEditor.java:284)
> at org.eclipse.jface.viewers.ComboBoxCellEditor$4.focusLost(Com
> boBoxCellEditor.java:170)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe
> ner.java:137)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
> at org.eclipse.swt.custom.CCombo.handleFocus(CCombo.java:844)
> at org.eclipse.swt.custom.CCombo$3.handleEvent(CCombo.java:141)
> at org.eclipse.swt.widgets.Display.filterEvent(Display.java:119 1)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1002)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
> at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2583)
> at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2282)
> at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:457 3)
> at org.eclipse.swt.widgets.Table.WM_SETFOCUS(Table.java:5898)
> at org.eclipse.swt.widgets.Control.windowProc(Control.java:4014 )
> at org.eclipse.swt.widgets.Table.windowProc(Table.java:5521)
> at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589 )
> at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
> at org.eclipse.swt.widgets.Table.sendMouseDownEvent(Table.java: 3574)
> at org.eclipse.swt.widgets.Table.WM_LBUTTONDOWN(Table.java:5745 )
> at org.eclipse.swt.widgets.Control.windowProc(Control.java:3981 )
> at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
> at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
> at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault
> (Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work
> bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start
> (IDEApplication.java:113)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
> eAppHandle.java:194)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
> .runApplication(EclipseAppLauncher.java:110)
> .start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
> tarter.java:368)
> tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> Im thinking that's a version problem but I dont know which plugin (or
> jars) replace in order to fix it
> Help will be awesome =D
You might find more answers in the STP forum:
http://www.eclipse.org/forums/eclipse.stp . Off hand it looks like it
is not compatible with the javax.wsdl bundle that has been loaded into
the VM.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03191 seconds
