Re: Dynamic loading of files conforming to arbitrary DSLs [message #512022 is a reply to message #511676] |
Wed, 03 February 2010 16:45 |
Christoph Elsner Messages: 5 Registered: February 2010 |
Hi Sven,
thanks for your reply. It's good to know that I do not have to generate an API for the metamodel.
My question was meant in an even more general (and maybe more naive) sense:
Is it possible to parse a file conforming to a XText DSL without generating any file at all (no grammar, no <Lang>RuntimeModule.java, no <Lang>StandaloneSetup.java, no Internal<Lang>Parser.java ...)
This would be a kind of "dynamic" parser then, which *interprets* the XText grammar instead of generating java/ANTLR code for parsing.
However, as I've seen now both ANTLR and the new XText alternative are "parser generators", not "grammar interpreters". So, finally, it seems I won't get around running a parser generator and jump into the generated code via reflection. Do you think so as well?
Christoph
Sven Efftinge wrote on Tue, 02 February 2010 04:12 | Xtext can work with dynamic emf models.
However, there are some generated convenience classes (e.g.
ProposalProvider) which refer to the generated Java clases.
But those components are not mandatory.
Sven
Re: Dynamic loading of files conforming to arbitrary DSLs [message #512163 is a reply to message #512022] |
Thu, 04 February 2010 04:32 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Christoph Elsner schrieb:
> Hi Sven,
Yes, those components are generated.
You could generate and compile at runtime and load the generated code
via URLClassLoader. But I don't know how well that would perform.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
FUDForum. Page generated in 0.03121 seconds
