Multi Plugin Project Problems with Menu [message #511470] |
Mon, 01 February 2010 16:41 |
Good day,
I seem to be having a little problem with telling how I want my Menu Items sorted in the MenuBar. I created a multi project Plugin Project. And I spread my function and views/perspectives over the plugins. Giving each project its own Menu Contribution to the org.eclipse.ui.main.menu. But now it seems to set the menu items at random on generation. I tried adding ?after=other.menu.id.
This how ever does not seem to work if I put it a menu item of the menu:org.eclipse.ui.main.menu (menuContribution).
if i try to the plugin menuContribution
menu:this.plug-in.menu.item?after=other.menu.id
The menu item completely disappears.
Does the plug-in that is having a refer 2 a other plug-in.menu.id have 2 know it. Do I need to add that plug-in to the Imported Packages. Because that would sort of defeat for me the purpose separating modular functions/perspectives in separate project.
If I eny one can shed some lights on this that would be great.
hm. I've lost a machine.. literally _lost_. it responds to ping, it works completely, I just can't figure out where in my apartment it is.
Re: Multi Plugin Project Problems with Menu [message #511593 is a reply to message #511492] |
Tue, 02 February 2010 08:30 |
Wim Jongman wrote on Mon, 01 February 2010 12:39 | Hi Martijn,
You talk about menu items in the menu bar but do you mean menus? A menu must
have at least one menu item otherwise it will not show.
Best Regards,
Wim Jongman
-- Southern DOS: Y'all reckon? (Yep/Nope)
(Eclipse Old Skool Quote Service)
Hi Wim,
The menu has items. It shows if i do not use the ?after=other.menu.id action. But then I got this russian rullet going for the menu items showing. Whitch I ofcourse do not want.
FUDForum. Page generated in 0.04993 seconds
