Re: Unable to update a feature [message #511034 is a reply to message #511018] |
Fri, 29 January 2010 15:39 |
Hi John,
Did you try using both -uninstallIU and -installIU at the same time as the Pascal suggests?
Regarding the Buckminster headless installer. My preference would be to drop it completely. We have the director now and
today, our installer is just a very thin wrapper for it. The reason we have kept it so far is to retain backward
compatibility. It doesn't bring any additional functionality.
- thomas
On 01/29/2010 03:50 PM, John wrote:
> Hi!
> We have a feature that we install from our own update site using the
> Buckmnster headless command install. In the case a new version of the
> builder is released, we would of course like to have it updated. This
> worked fine in Eclipse 3.4, but with 3.5 we get the followoing error:
> Cannot complete the install because of a conflicting dependency.
> [0]Software being installed: BD Web Service Client Builder 1.2.7
> (my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.7)
> [0]Software currently installed: BD Web Service Client Builder 1.2.6
> (my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.6)
> [0]Only one of the following can be installed at once:
> [0.2]BD WS Stub Builder 1.2.7 (my.company.bd.dev.plugin.stubbuilder 1.2.7)
> [0.2]BD WS Stub Builder 1.2.6 (my.company.bd.dev.plugin.stubbuilder 1.2.6)
> [0]Cannot satisfy dependency:
> [0.2]From: BD Web Service Client Builder 1.2.6
> [0.2]To: my.company.bd.dev.plugin.stubbuilder [1.2.6]
> [0.2]From: BD Web Service Client Builder 1.2.7
> [0.2]To: my.company.bd.dev.plugin.stubbuilder [1.2.7]
> buckminster failed with error code 1
> Is the reason for this in any way related to the following bug for the
> director? https://bugs.eclipse.org/bugs/show_bug.cgi?id=279659
> I wonder, since I thought what Buckminster is doing, is also what's
> possible in the Eclipse IDE. In there it's not a problem to update an
> existing feature and I have both versions of
> my.company.bd.dev.plugin.stubbuilderfeature in the plugins folder of my
> Eclipse 3.5 installation.
> If it is related to the bug, are there any plans to make the headless
> Buckminster install command also handle an update? It's really essential
> to our CI build strategy.
> Thanks.
> /John
Re: Unable to update a feature [message #511196 is a reply to message #511194] |
Sat, 30 January 2010 22:39 |
Hi John,
On 01/30/2010 11:12 PM, John wrote:
> Does an uninstall not remove the plugins? Does it just update
> artifacts.xml or some metadata?
Everything that you pass on the command line is put into a change request and passed to the p2 planner. If the planner
detects both an uninstall and an install of the same IU, it will process that as an update. The old and no longer
referenced artifacts (plugins) are probably not physically removed immediately but they will be garbage collected
eventually.
When we implement an -updateIU for the director, I expect it to query for the current version and then do exactly what
you do when passing the -uninstallIU and -installIU on the command line.
Thomas Hallgren
Re: Unable to update a feature [message #511421 is a reply to message #511411] |
Mon, 01 February 2010 15:07 |
On 02/01/2010 03:52 PM, John wrote:
> Anyways, I went on and tried to use both -uninstallIU and -installIU.
> The result is:
> director -r http://mysiteserver/update12/
> -d C:\Temp\bm35-home\buckminster -p Buckminster
> -u my.company.bd.dev.plugin.stubbuilderfeature.feature.group
> -i my.company.bd.dev.plugin.stubbuilderfeature.feature.group
> -vmargs -D"http.proxyHost=my.proxy.server" -D"http.proxyPort=80"
> -D"http.nonProxyHosts=mysiteserver"
> Installing my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.7.
> Uninstalling my.company.bd.dev.plugin.stubbuilderfeature.feature.group
> 1.2.6.
> An error occurred while uninstalling
> session context was:(profile=Buckminster,
> phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Uninstall,
> operand=[R]my.company.bd.dev.plugin.builderruntime 1.2.6 -->
> [R]my.company.bd.dev.plugin.builderruntime 1.2.7,
> action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac
> tions.UninstallBundleAction).
> Caused by: java.lang.NullPointerException
> Below I have included more log entries from the NPE above.
> I'm not sure what the problem is here or how to solve it.
> When looking at the Buckminster installation I can now see all the
> plugins from the feature for both the 1.2.6 and 1.2.7 versions in
> C:\Temp\bm35-home\buckminster\plugins.
> In the file C:\Temp\bm35-home\buckminster\artifacts.xml both versions
> are present for all the plugins in the feature.
> Do you have any suggestions for how I can proceed to solve this problem?
I suggest you file a bugzilla against rt/Equinox/p2 where you explain that you're trying to follow the uninstall/install
advice and include the stack-trace below. We will take it from there.
Thomas Hallgren
> Thanks.
> /John
> !ENTRY org.eclipse.equinox.p2.repository 4 0 2010-02-01 15:15:13.716
> !MESSAGE ProvisioningEventBus could not be obtained. Metadata caches may
> not be cleaned up properly.
> !ENTRY org.eclipse.equinox.p2.garbagecollector 4 0 2010-02-01 15:15:13.731
> !MESSAGE ProvisioningEventBus service could not be obtained,
> CoreGarbageCollector will not function properly.
> !ENTRY org.eclipse.equinox.p2.engine 4 4 2010-02-01 15:15:15.794
> !MESSAGE An error occurred while uninstalling
> !SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-02-01 15:15:15.794
> !MESSAGE session context was:(profile=Buckminster,
> ses.Uninstall, operand=[R]my.company.bd.dev.plugin.builderruntime 1.2.6
> --> [R]my.company.bd.dev.plugin.builderruntime 1.2.7,
> !MESSAGE !STACK 0
> at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManip
> ulator.loadDelegate(LazyManipulator.java:64)
> ulator.getConfigData(LazyManipulator.java:108)
> at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.U
> ninstallBundleAction.uninstallBundle(UninstallBundleAction.j ava:74)
> ninstallBundleAction.execute(UninstallBundleAction.java:29)
> at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisio
> ningAction.execute(ParameterizedProvisioningAction.java:35)
> at org.eclipse.equinox.internal.provisional.p2.engine.Phase.mai
> nPerform(Phase.java:129)
> at org.eclipse.equinox.internal.provisional.p2.engine.Phase.per
> form(Phase.java:72)
> at org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet.
> perform(PhaseSet.java:44)
> at org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe
> rform(Engine.java:54)
> at org.eclipse.equinox.internal.provisional.p2.director.PlanExe
> cutionHelper.executePlan(PlanExecutionHelper.java:41)
> cutionHelper.executePlan(PlanExecutionHelper.java:23)
> at org.eclipse.equinox.internal.p2.director.app.DirectorApplica
> tion.planAndExecute(DirectorApplication.java:506)
> tion.performProvisioningActions(DirectorApplication.java:492 )
> tion.run(DirectorApplication.java:708)
> tion.start(DirectorApplication.java:808)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
> eAppHandle.java:194)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
> .runApplication(EclipseAppLauncher.java:110)
> .start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
> tarter.java:368)
> tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
FUDForum. Page generated in 0.05341 seconds
