| Unable to update a feature [message #511018] |
Fri, 29 January 2010 09:50   |
Eclipse User  |
Hi!
We have a feature that we install from our own update site using the Buckmnster headless command install. In the case a new version of the builder is released, we would of course like to have it updated. This worked fine in Eclipse 3.4, but with 3.5 we get the followoing error:
Cannot complete the install because of a conflicting dependency.
[0]Software being installed: BD Web Service Client Builder 1.2.7 (my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.7)
[0]Software currently installed: BD Web Service Client Builder 1.2.6 (my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.6)
[0]Only one of the following can be installed at once:
[0.2]BD WS Stub Builder 1.2.7 (my.company.bd.dev.plugin.stubbuilder 1.2.7)
[0.2]BD WS Stub Builder 1.2.6 (my.company.bd.dev.plugin.stubbuilder 1.2.6)
[0]Cannot satisfy dependency:
[0.2]From: BD Web Service Client Builder 1.2.6 (my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.6)
[0.2]To: my.company.bd.dev.plugin.stubbuilder [1.2.6]
[0.2]From: BD Web Service Client Builder 1.2.7 (my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.7)
[0.2]To: my.company.bd.dev.plugin.stubbuilder [1.2.7]
buckminster failed with error code 1
Is the reason for this in any way related to the following bug for the director? https://bugs.eclipse.org/bugs/show_bug.cgi?id=279659
I wonder, since I thought what Buckminster is doing, is also what's possible in the Eclipse IDE. In there it's not a problem to update an existing feature and I have both versions of my.company.bd.dev.plugin.stubbuilderfeature in the plugins folder of my Eclipse 3.5 installation.
If it is related to the bug, are there any plans to make the headless Buckminster install command also handle an update? It's really essential to our CI build strategy.
Thanks.
/John
| Re: Unable to update a feature [message #511421 is a reply to message #511411] |
Mon, 01 February 2010 10:07    |
Eclipse User  |
On 02/01/2010 03:52 PM, John wrote:
> Anyways, I went on and tried to use both -uninstallIU and -installIU.
> The result is:
> director -r http://mysiteserver/update12/
> -d C:\Temp\bm35-home\buckminster -p Buckminster
> -u my.company.bd.dev.plugin.stubbuilderfeature.feature.group
> -i my.company.bd.dev.plugin.stubbuilderfeature.feature.group
> -vmargs -D"http.proxyHost=my.proxy.server" -D"http.proxyPort=80"
> -D"http.nonProxyHosts=mysiteserver"
> Installing my.company.bd.dev.plugin.stubbuilderfeature.feature.group 1.2.7.
> Uninstalling my.company.bd.dev.plugin.stubbuilderfeature.feature.group
> 1.2.6.
> An error occurred while uninstalling
> session context was:(profile=Buckminster,
>  phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Uninstall,
> operand=[R]my.company.bd.dev.plugin.builderruntime 1.2.6 -->
> [R]my.company.bd.dev.plugin.builderruntime 1.2.7,
>  action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac
> tions.UninstallBundleAction).
> Caused by: java.lang.NullPointerException
> Below I have included more log entries from the NPE above.
> I'm not sure what the problem is here or how to solve it.
> When looking at the Buckminster installation I can now see all the
> plugins from the feature for both the 1.2.6 and 1.2.7 versions in
> C:\Temp\bm35-home\buckminster\plugins.
> In the file C:\Temp\bm35-home\buckminster\artifacts.xml both versions
> are present for all the plugins in the feature.
> Do you have any suggestions for how I can proceed to solve this problem?
I suggest you file a bugzilla against rt/Equinox/p2 where you explain that you're trying to follow the uninstall/install
advice and include the stack-trace below. We will take it from there.
Thomas Hallgren
> Thanks.
> /John
> !ENTRY org.eclipse.equinox.p2.repository 4 0 2010-02-01 15:15:13.716
> !MESSAGE ProvisioningEventBus could not be obtained. Metadata caches may
> not be cleaned up properly.
> !ENTRY org.eclipse.equinox.p2.garbagecollector 4 0 2010-02-01 15:15:13.731
> !MESSAGE ProvisioningEventBus service could not be obtained,
> CoreGarbageCollector will not function properly.
> !ENTRY org.eclipse.equinox.p2.engine 4 4 2010-02-01 15:15:15.794
> !MESSAGE An error occurred while uninstalling
> !SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-02-01 15:15:15.794
> !MESSAGE session context was:(profile=Buckminster,
> ses.Uninstall, operand=[R]my.company.bd.dev.plugin.builderruntime 1.2.6
> --> [R]my.company.bd.dev.plugin.builderruntime 1.2.7,
> !MESSAGE !STACK 0
> at  org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManip
> ulator.loadDelegate(LazyManipulator.java:64)
> ulator.getConfigData(LazyManipulator.java:108)
> at  org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.U
>  ninstallBundleAction.uninstallBundle(UninstallBundleAction.j ava:74)
> ninstallBundleAction.execute(UninstallBundleAction.java:29)
> at  org.eclipse.equinox.internal.p2.engine.ParameterizedProvisio
> ningAction.execute(ParameterizedProvisioningAction.java:35)
> at  org.eclipse.equinox.internal.provisional.p2.engine.Phase.mai
> nPerform(Phase.java:129)
> at  org.eclipse.equinox.internal.provisional.p2.engine.Phase.per
> form(Phase.java:72)
> at  org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet.
> perform(PhaseSet.java:44)
> at  org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe
> rform(Engine.java:54)
> at  org.eclipse.equinox.internal.provisional.p2.director.PlanExe
> cutionHelper.executePlan(PlanExecutionHelper.java:41)
> cutionHelper.executePlan(PlanExecutionHelper.java:23)
> at  org.eclipse.equinox.internal.p2.director.app.DirectorApplica
> tion.planAndExecute(DirectorApplication.java:506)
>  tion.performProvisioningActions(DirectorApplication.java:492 )
> tion.run(DirectorApplication.java:708)
> tion.start(DirectorApplication.java:808)
> at  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
> eAppHandle.java:194)
> at  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
> .runApplication(EclipseAppLauncher.java:110)
> .start(EclipseAppLauncher.java:79)
> at  org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
> tarter.java:368)
> tarter.java:179)
> at  org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
| Re: Unable to update a feature [message #528596 is a reply to message #528413] |
Wed, 21 April 2010 04:39   |
Eclipse User  |
Hi Thomas!
I forgot to mention that in this case I have already 1.2.8 installed and this problem happens, when the version on the update site is also 1.2.8.
So what may have changed since I verified it last time is, that the version I had installed was 1.2.6 and the version on the update site was 1.2.7, so the update worked fine.
But now when there's nothing new it apparently results in an uninstall.
This has been working fine before, when I used the install action provided by Buckminster.
Thanks.
/John
| John wrote on Tue, 20 April 2010 14:42 |  Hi Thomas!
It's very strange. I'm sure I had it working with using the combination of -u and -i to make the director update a feature. But I have just realized that it doesn't seem to work anyways. I'm not sure what has happened in between, but when I try to perform the update I get the following:
director -r http://myserver/mysite/
-d C:\temp\bm-home\buckminster
-p Buckminster
-u my.company.myfeature.feature.group
-i my.company.myfeature.feature.group
Installing my.company.myfeature.feature.group 1.2.8.
Uninstalling my.company.myfeature.feature.group 1.2.8.
Operation completed in 1766 ms.
As you can see it claims to install and unistall the feature, and the result is, that it's no longer installed. What can be the problem here?
Thanks.
/John
FUDForum. Page generated in 0.08432 seconds
