| Problem with indirect (lazy) mappings [message #510706] |
Thu, 28 January 2010 06:33  |
Hi all, thanks in advance for your help.
I have checked the documentation from EclipseLink to configure the persistent unit in a static way so that I can load associated objects in a lazy way. However I am not being able to get through. This is the content of my persistence.xml file
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="JPAIncidencias" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>java:/comp/env/jdbc/SistemaIncidencias</jta-data-source>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="eclipselink.session.customizer" value="utils.JPAEclipseLinkSessionCustomizer"/>
<property name="eclipselink.logging.level" value="FINEST"/>
<property name="eclipselink.weaving" value="static"/>
<property name="eclipselink.weaving.lazy" value="true"/>
<property name="eclipselink.weaving.changetracking" value="true"/>
<property name="eclipselink.weaving.fetchgroups" value="true"/>
<property name="eclipselink.weaving.internal" value="true"/>
<property name="eclipselink.weaving.eager" value="false"/>
</properties>
</persistence-unit>
</persistence>
I am setting the entities in the following way:
Class A -> B (OneToMany)
public class A{
private ArrayList toB;
//getter and setter
public class B{
private A toA;
//getter and setter
and in the orm.xml got the following
<entity class="package.A">
<table name="aa">
</table>
<one-to-many fetch="LAZY" name="toB" target-entity="package.B" mapped-by="toA">
</one-to-many>
</entity>
<entity class="package.B">
<table name="bb">
</table>
<many-to-one name="toA">
<join-column name="A_ID" referenced-column-name="ID"/>
</many-to-one>
</entity>
from B to A is eager by default, and from A to B lazy by default.
If possible would like to keep using ArrayList, but any [EclipseLink]List class arranged for maintaining indirection that works in not a very problematic way (regarding maintainance) will do fine. I used static weaving 'cause from the documentation I knew that it should only be defined once in the persistence.xml file.
Any hints on what I am doing wrong?
Thank you very much in advance.
Carlos
| Re: Problem with indirect (lazy) mappings [message #510734 is a reply to message #510706] |
Thu, 28 January 2010 08:56  |
The JPA specification requires that collection attributes be either a Collection, Set, List or Map type, allowing providers to put in their own implementions transparently for lazy relations. EclipseLink does not strictly enforce this, which is why your collection type being ArrayList will work as long as it is not lazy. In order to be portable, you will need to change the toB type to be List, allowing EclipseLink to put its own IndirectList type when populating managed entities and still allowing your model to use ArrayList.
If you do not want to use the java.util.List and prefer a concrete type be specified, you would need to mark it as Transient and then use a customizer to create the mapping with native EclipseLink api.
Best Regards,
Chris
FUDForum. Page generated in 0.03071 seconds
