Home » Language IDEs » PHP Development Tools (PDT) » Log Writes (when connecting to PHPexe works but not when connecting to webserver)
icon5.gif  Log Writes [message #510293] Wed, 27 January 2010 07:05 Go to next message
Ethereal1m Mising name is currently offline Ethereal1m Mising nameFriend
Member
Dear experts,
referring to http:// www.eclipse.org/forums/index.php?t=msg&th=161449&sta rt=0&, I uninstalled and reinstalled both PHP and Apache in order to see if logger is working. Interestingly after the re-installation, the logger writes when eclipse is debugging using php exe, however it doesn't write anything when it try to connect to the webserver.
I'm assuming Eclipse is not communicating with Apache at all. Is there any precaution on the Apache httpd.conf that I need to know?
ethereal1m
[Updated on: Wed, 27 January 2010 07:07]
Report message to a moderator
Re: Log Writes [message #510313 is a reply to message #510293] Wed, 27 January 2010 08:41 Go to previous messageGo to next message
Member
I just wondering how eclipse communicate with Apache web server i one machine. If xdebug config looks like this:
xdebug.remote_enable=1
xdebug.remote_host=127.0.0.1
xdebug.remote_port=9000
This means that Eclipse will have IP address 127.0.0.1 and port 9000 and try to connect to Apache server with localhost as the address and 80 as its port.
When I start debugging ,connecting to the webserver and I do netstat, I see:
TCP    Serenity:9000          Serenity:0             LISTENING
Where Serenity is the name of the machine. Is this correct? Should it say "ESTABLISHED" instead of "LISTENING"?
thanks,
ethereal1m
Re: Log Writes [message #510359 is a reply to message #510313] Wed, 27 January 2010 05:50 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
The eclipse IDE is listening on port 9000 waiting for xdebug to connect
to it. So when you invoke php on your apache web server with something like
http://localhost/phpinfo.php?XDEBUG_SESSION_START=ECLIPSE_DB GP
the XDEBUG_SESSION_START is seen by xdebug and it will attempt to
connect to the IDE once it establishes a socket connection it will send
the init string.
Can you post your full phpinfo() output when run on your webserver ?
this will show not only your xdebug config but also any other
extensions. As mentioned before the zend optimiser can stop xdebug from
working.
Dave Kelsey
> its port.
> see:
> thanks,
> ethereal1m
Re: Log Writes [message #510370 is a reply to message #510293] Wed, 27 January 2010 11:29 Go to previous messageGo to next message
Member
hi Dave,
I appreciate your reply. Does Zend Studio has Zend Optimizer included? I'm not sure if I have Optimezer, anyway the following is my complete phpinfo dump:
PHP Logo
PHP Version 5.2.12
System 	Windows NT SERENITY 5.1 build 2600
Build Date 	Dec 16 2009 17:01:16
Configure Command 	cscript /nologo configure.js "--enable-snapshot-build" "--enable-debug-pack" "--with-snapshot-template=d:\php-sdk\snap_5_2\vc6\x86\template" "--with-php-build=d:\php-sdk\snap_5_2\vc6\x86\php_build" "--with-pdo-oci=D:\php-sdk\oracle\instantclient10\sdk,shared" "--with-oci8=D:\php-sdk\oracle\instantclient10\sdk,shared" "--without-pi3web"
Server API 	Apache 2.0 Handler
Virtual Directory Support 	enabled
Configuration File (php.ini) Path 	C:\WINDOWS
Loaded Configuration File 	C:\WINDOWS\php.ini
Scan this dir for additional .ini files 	(none)
additional .ini files parsed 	(none)
PHP API 	20041225
PHP Extension 	20060613
Zend Extension 	220060519
Debug Build 	no
Thread Safety 	enabled
Zend Memory Manager 	enabled
IPv6 Support 	enabled
Registered PHP Streams 	php, file, data, http, ftp, compress.zlib
Registered Stream Socket Transports 	tcp, udp
Registered Stream Filters 	convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, zlib.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.2.0, Copyright (c) 1998-2009 Zend Technologies
    with Xdebug v2.0.5, Copyright (c) 2002-2008, by Derick Rethans
PHP Credits
Configuration
PHP Core
Directive	Local Value	Master Value
allow_call_time_pass_reference	On	On
allow_url_fopen	On	On
allow_url_include	Off	Off
always_populate_raw_post_data	Off	Off
arg_separator.input	&	&
arg_separator.output	&	&
asp_tags	Off	Off
auto_append_file	no value	no value
auto_globals_jit	On	On
auto_prepend_file	no value	no value
browscap	no value	no value
default_charset	no value	no value
default_mimetype	text/html	text/html
define_syslog_variables	Off	Off
disable_classes	no value	no value
disable_functions	no value	no value
display_errors	On	On
display_startup_errors	Off	Off
doc_root	no value	no value
docref_ext	no value	no value
docref_root	no value	no value
enable_dl	On	On
error_append_string	no value	no value
error_log	C:\PHP\log\php-errors.log	C:\PHP\log\php-errors.log
error_prepend_string	no value	no value
error_reporting	6135	6135
expose_php	On	On
extension_dir	C:\PHP\ext	C:\PHP\ext
file_uploads	On	On
highlight.bg	#FFFFFF	#FFFFFF
highlight.comment	#FF8000	#FF8000
highlight.default	#0000BB	#0000BB
highlight.html	#000000	#000000
highlight.keyword	#007700	#007700
highlight.string	#DD0000	#DD0000
html_errors	On	On
ignore_repeated_errors	Off	Off
ignore_repeated_source	Off	Off
ignore_user_abort	Off	Off
implicit_flush	Off	Off
include_path	.;C:\php5\pear	.;C:\php5\pear
log_errors	On	On
log_errors_max_len	1024	1024
magic_quotes_gpc	On	On
magic_quotes_runtime	Off	Off
magic_quotes_sybase	Off	Off
mail.force_extra_parameters	no value	no value
max_execution_time	30	30
max_file_uploads	20	20
max_input_nesting_level	64	64
max_input_time	60	60
memory_limit	128M	128M
open_basedir	no value	no value
output_buffering	no value	no value
output_handler	no value	no value
post_max_size	8M	8M
precision	12	12
realpath_cache_size	16K	16K
realpath_cache_ttl	120	120
register_argc_argv	On	On
register_globals	Off	Off
register_long_arrays	On	On
report_memleaks	On	On
report_zend_debug	On	On
safe_mode	Off	Off
safe_mode_exec_dir	no value	no value
safe_mode_gid	Off	Off
safe_mode_include_dir	no value	no value
sendmail_from	no value	no value
sendmail_path	no value	no value
serialize_precision	100	100
short_open_tag	On	On
SMTP	localhost	localhost
smtp_port	25	25
sql.safe_mode	Off	Off
track_errors	Off	Off
unserialize_callback_func	no value	no value
upload_max_filesize	2M	2M
upload_tmp_dir	no value	no value
user_dir	no value	no value
variables_order	EGPCS	EGPCS
xmlrpc_error_number	0	0
xmlrpc_errors	Off	Off
y2k_compliance	On	On
zend.ze1_compatibility_mode	Off	Off
apache2handler
Apache Version 	Apache/2.2.14 (Win32) PHP/5.2.12
Apache API Version 	20051115
Server Administrator 	ethereal1m@serenity.com
Hostname:Port 	serenity:0
Max Requests 	Per Child: 0 - Keep Alive: on - Max Per Connection: 100
Timeouts 	Connection: 300 - Keep-Alive: 5
Virtual Server 	No
Server Root 	C:/Program Files/Apache Software Foundation/Apache2.2
Loaded Modules 	core mod_win32 mpm_winnt http_core mod_so mod_actions mod_alias mod_asis mod_auth_basic mod_authn_default mod_authn_file mod_authz_default mod_authz_groupfile mod_authz_host mod_authz_user mod_autoindex mod_cgi mod_dir mod_env mod_include mod_isapi mod_log_config mod_mime mod_negotiation mod_setenvif mod_php5
engine	1	1
last_modified	0	0
xbithack	0	0
Apache Environment
Variable	Value
HTTP_HOST 	serenity
HTTP_USER_AGENT 	Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.7) Gecko/20091221 Firefox/3.5.7 (.NET CLR 3.5.30729)
HTTP_ACCEPT 	text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
HTTP_ACCEPT_LANGUAGE 	en-us,en;q=0.5
HTTP_ACCEPT_ENCODING 	gzip,deflate
HTTP_ACCEPT_CHARSET 	ISO-8859-1,utf-8;q=0.7,*;q=0.7
HTTP_KEEP_ALIVE 	300
HTTP_CONNECTION 	keep-alive
HTTP_COOKIE 	ZDEDebuggerPresent=php,phtml,php3
HTTP_CACHE_CONTROL 	max-age=0
PATH 	C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
SystemRoot 	C:\WINDOWS
COMSPEC 	C:\WINDOWS\system32\cmd.exe
PATHEXT 	.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PHP
WINDIR 	C:\WINDOWS
SERVER_SIGNATURE 	no value
SERVER_SOFTWARE 	Apache/2.2.14 (Win32) PHP/5.2.12
SERVER_NAME 	serenity
SERVER_ADDR 	192.168.1.2
SERVER_PORT 	80
REMOTE_ADDR 	192.168.1.2
DOCUMENT_ROOT 	C:/Program Files/Apache Software Foundation/Apache2.2/htdocs
SERVER_ADMIN 	ethereal1m@serenity.com
SCRIPT_FILENAME 	C:/Program Files/Apache Software Foundation/Apache2.2/htdocs/phpinfo.php
REMOTE_PORT 	1171
GATEWAY_INTERFACE 	CGI/1.1
SERVER_PROTOCOL 	HTTP/1.1
REQUEST_METHOD 	GET
QUERY_STRING 	no value
REQUEST_URI 	/info
SCRIPT_NAME 	/info
HTTP Headers Information
HTTP Request Headers
HTTP Request 	GET /info HTTP/1.1
Host 	serenity
User-Agent 	Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.7) Gecko/20091221 Firefox/3.5.7 (.NET CLR 3.5.30729)
Accept 	text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language 	en-us,en;q=0.5
Accept-Encoding 	gzip,deflate
Accept-Charset 	ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive 	300
Connection 	keep-alive
Cookie 	ZDEDebuggerPresent=php,phtml,php3
Cache-Control 	max-age=0
HTTP Response Headers
X-Powered-By 	PHP/5.2.12
Keep-Alive 	timeout=5, max=100
Connection 	Keep-Alive
Transfer-Encoding 	chunked
Content-Type 	text/html
bcmath
BCMath support 	enabled
calendar
Calendar support 	enabled
com_dotnet
COM support	enabled
DCOM support	disabled
.Net support	enabled
com.allow_dcom	0	0
com.autoregister_casesensitive	1	1
com.autoregister_typelib	0	0
com.autoregister_verbose	0	0
com.code_page	no value	no value
com.typelib_file	no value	no value
ctype
ctype functions 	enabled
date
date/time support 	enabled
"Olson" Timezone Database Version 	2009.19
Timezone Database 	internal
Default timezone 	Asia/Krasnoyarsk
date.default_latitude	31.7667	31.7667
date.default_longitude	35.2333	35.2333
date.sunrise_zenith	90.583333	90.583333
date.sunset_zenith	90.583333	90.583333
date.timezone	no value	no value
dom
DOM/XML 	enabled
DOM/XML API Version 	20031129
libxml Version 	2.7.3
HTML Support 	enabled
XPath Support 	enabled
XPointer Support 	enabled
Schema Support 	enabled
RelaxNG Support 	enabled
filter
Input Validation and Filtering 	enabled
Revision 	$Revision: 288083 $
filter.default	unsafe_raw	unsafe_raw
filter.default_flags	no value	no value
ftp
FTP support 	enabled
hash
hash support 	enabled
Hashing Engines 	md2 md4 md5 sha1 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru gost adler32 crc32 crc32b haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support 	enabled
iconv implementation 	"libiconv"
iconv library version 	1.11
iconv.input_encoding	ISO-8859-1	ISO-8859-1
iconv.internal_encoding	ISO-8859-1	ISO-8859-1
iconv.output_encoding	ISO-8859-1	ISO-8859-1
json
json support 	enabled
json version 	1.2.1
libxml
libXML support 	active
libXML Version 	2.7.3
libXML streams 	enabled
odbc
ODBC Support	enabled
Active Persistent Links 	0
Active Links 	0
ODBC library 	Win32
odbc.allow_persistent	On	On
odbc.check_persistent	On	On
odbc.default_cursortype	Static cursor	Static cursor
odbc.default_db	no value	no value
odbc.default_pw	no value	no value
odbc.default_user	no value	no value
odbc.defaultbinmode	return as is	return as is
odbc.defaultlrl	return up to 4096 bytes	return up to 4096 bytes
odbc.max_links	Unlimited	Unlimited
odbc.max_persistent	Unlimited	Unlimited
pcre
PCRE (Perl Compatible Regular Expressions) Support 	enabled
PCRE Library Version 	7.9 2009-04-11
pcre.backtrack_limit	100000	100000
pcre.recursion_limit	100000	100000
Reflection
Reflection	enabled
Version 	$Id: php_reflection.c 290127 2009-11-01 15:12:34Z felipe $
session
Session Support 	enabled
Registered save handlers 	files user
Registered serializer handlers 	php php_binary wddx
session.auto_start	Off	Off
session.bug_compat_42	On	On
session.bug_compat_warn	On	On
session.cache_expire	180	180
session.cache_limiter	nocache	nocache
session.cookie_domain	no value	no value
session.cookie_httponly	Off	Off
session.cookie_lifetime	0	0
session.cookie_path	/	/
session.cookie_secure	Off	Off
session.entropy_file	no value	no value
session.entropy_length	0	0
session.gc_divisor	100	100
session.gc_maxlifetime	1440	1440
session.gc_probability	1	1
session.hash_bits_per_character	4	4
session.hash_function	0	0
session.name	PHPSESSID	PHPSESSID
session.referer_check	no value	no value
session.save_handler	files	files
session.save_path	C:\WINDOWS\temp	C:\WINDOWS\temp
session.serialize_handler	php	php
session.use_cookies	On	On
session.use_only_cookies	Off	Off
session.use_trans_sid	0	0
SimpleXML
Simplexml support	enabled
Revision 	$Revision: 289327 $
Schema support 	enabled
SPL
SPL support	enabled
Interfaces 	Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes 	AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, DirectoryIterator, DomainException, EmptyIterator, FilterIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RegexIterator, RuntimeException, SimpleXMLIterator, SplFileInfo, SplFileObject, SplObjectStorage, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Regex Library 	Bundled library enabled
Dynamic Library Support 	enabled
Internal Sendmail Support for Windows 	enabled
assert.active	1	1
assert.bail	0	0
assert.callback	no value	no value
assert.quiet_eval	0	0
assert.warning	1	1
auto_detect_line_endings	0	0
default_socket_timeout	60	60
safe_mode_allowed_env_vars	PHP_	PHP_
safe_mode_protected_env_vars	LD_LIBRARY_PATH	LD_LIBRARY_PATH
url_rewriter.tags	a=href,area=href,frame=src,input=src,form=,fieldset=	a=href,area=href,frame=src,input=src,form=,fieldset=
user_agent	no value	no value
tokenizer
Tokenizer Support 	enabled
wddx
WDDX Support	enabled
WDDX Session Serializer 	enabled
xdebug
xdebug support	enabled
Version 	2.0.5
Supported protocols	Revision
DBGp - Common DeBuGger Protocol 	$Revision: 1.125.2.6 $
GDB - GNU Debugger protocol 	$Revision: 1.87 $
PHP3 - PHP 3 Debugger protocol 	$Revision: 1.22 $
xdebug.auto_trace	Off	Off
xdebug.collect_includes	On	On
xdebug.collect_params	0	0
xdebug.collect_return	Off	Off
xdebug.collect_vars	Off	Off
xdebug.default_enable	On	On
xdebug.dump.COOKIE	no value	no value
xdebug.dump.ENV	no value	no value
xdebug.dump.FILES	no value	no value
xdebug.dump.GET	no value	no value
xdebug.dump.POST	no value	no value
xdebug.dump.REQUEST	no value	no value
xdebug.dump.SERVER	no value	no value
xdebug.dump.SESSION	no value	no value
xdebug.dump_globals	On	On
xdebug.dump_once	On	On
xdebug.dump_undefined	Off	Off
xdebug.extended_info	On	On
xdebug.idekey	no value	no value
xdebug.manual_url	http://www.php.net	http://www.php.net
xdebug.max_nesting_level	100	100
xdebug.profiler_aggregate	Off	Off
xdebug.profiler_append	Off	Off
xdebug.profiler_enable	Off	Off
xdebug.profiler_enable_trigger	Off	Off
xdebug.profiler_output_dir	/tmp	/tmp
xdebug.profiler_output_name	cachegrind.out.%p	cachegrind.out.%p
xdebug.remote_autostart	Off	Off
xdebug.remote_enable	On	On
xdebug.remote_handler	dbgp	dbgp
xdebug.remote_host	127.0.0.1	127.0.0.1
xdebug.remote_log	C:\PHP\log\remote.log	C:\PHP\log\remote.log
xdebug.remote_mode	req	req
xdebug.remote_port	9000	9000
xdebug.show_exception_trace	Off	Off
xdebug.show_local_vars	Off	Off
xdebug.show_mem_delta	Off	Off
xdebug.trace_format	0	0
xdebug.trace_options	0	0
xdebug.trace_output_dir	/tmp	/tmp
xdebug.trace_output_name	trace.%c	trace.%c
xdebug.var_display_max_children	128	128
xdebug.var_display_max_data	512	512
xdebug.var_display_max_depth	3	3
xml
XML Support 	active
XML Namespace Support 	active
libxml2 Version 	2.7.3
xmlreader
XMLReader 	enabled
xmlwriter
XMLWriter 	enabled
zlib
ZLib Support 	enabled
Stream Wrapper support 	compress.zlib://
Stream Filter support 	zlib.inflate, zlib.deflate
Compiled Version 	1.2.3
Linked Version 	1.2.3
zlib.output_compression	Off	Off
zlib.output_compression_level	-1	-1
zlib.output_handler	no value	no value
Additional Modules
Module Name
Environment
Variable	Value
ALLUSERSPROFILE 	C:\Documents and Settings\All Users
CommonProgramFiles 	C:\Program Files\Common Files
COMPUTERNAME 	SERENITY
ComSpec 	C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK 	NO
ICINCHOME 	C:\instantclient_10_2\sdk\include
ICLIBHOME 	C:\instantclient_10_2\sdk\lib
NUMBER_OF_PROCESSORS 	1
ORACLE_SID 	XE
OS 	Windows_NT
Path 	C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
PROCESSOR_ARCHITECTURE 	x86
PROCESSOR_IDENTIFIER 	x86 Family 15 Model 2 Stepping 9, GenuineIntel
PROCESSOR_LEVEL 	15
PROCESSOR_REVISION 	0209
sqlpath 	c:\documents and settings\nia\desktop
SWORD_PATH 	C:\Program Files\CrossWire\The SWORD Project
SystemDrive 	C:
TEMP 	C:\WINDOWS\TEMP
TMP 	C:\WINDOWS\TEMP
TNS_ADMIN 	C:\oraclexe\app\oracle\product\10.2.0\server\NETWORK\ADMIN
USERPROFILE 	C:\Documents and Settings\LocalService
VS90COMNTOOLS 	C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools\
windir 	C:\WINDOWS
AP_PARENT_PID 	2080
PHP Variables
Variable	Value
_REQUEST["ZDEDebuggerPresent"]	php,phtml,php3
_COOKIE["ZDEDebuggerPresent"]	php,phtml,php3
_SERVER["HTTP_HOST"]	serenity
_SERVER["HTTP_USER_AGENT"]	Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.7) Gecko/20091221 Firefox/3.5.7 (.NET CLR 3.5.30729)
_SERVER["HTTP_ACCEPT"]	text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
_SERVER["HTTP_ACCEPT_LANGUAGE"]	en-us,en;q=0.5
_SERVER["HTTP_ACCEPT_ENCODING"]	gzip,deflate
_SERVER["HTTP_ACCEPT_CHARSET"]	ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_KEEP_ALIVE"]	300
_SERVER["HTTP_CONNECTION"]	keep-alive
_SERVER["HTTP_COOKIE"]	ZDEDebuggerPresent=php,phtml,php3
_SERVER["HTTP_CACHE_CONTROL"]	max-age=0
_SERVER["PATH"]	C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
_SERVER["SystemRoot"]	C:\WINDOWS
_SERVER["COMSPEC"]	C:\WINDOWS\system32\cmd.exe
_SERVER["PATHEXT"]	.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PHP
_SERVER["WINDIR"]	C:\WINDOWS
_SERVER["SERVER_SIGNATURE"]	no value
_SERVER["SERVER_SOFTWARE"]	Apache/2.2.14 (Win32) PHP/5.2.12
_SERVER["SERVER_NAME"]	serenity
_SERVER["SERVER_ADDR"]	192.168.1.2
_SERVER["SERVER_PORT"]	80
_SERVER["REMOTE_ADDR"]	192.168.1.2
_SERVER["DOCUMENT_ROOT"]	C:/Program Files/Apache Software Foundation/Apache2.2/htdocs
_SERVER["SERVER_ADMIN"]	ethereal1m@serenity.com
_SERVER["SCRIPT_FILENAME"]	C:/Program Files/Apache Software Foundation/Apache2.2/htdocs/phpinfo.php
_SERVER["REMOTE_PORT"]	1171
_SERVER["GATEWAY_INTERFACE"]	CGI/1.1
_SERVER["SERVER_PROTOCOL"]	HTTP/1.1
_SERVER["REQUEST_METHOD"]	GET
_SERVER["QUERY_STRING"]	no value
_SERVER["REQUEST_URI"]	/info
_SERVER["SCRIPT_NAME"]	/info
_SERVER["PHP_SELF"]	/info
_SERVER["REQUEST_TIME"]	1264591676
_SERVER["argv"]
Array
_SERVER["argc"]	0
_ENV["ALLUSERSPROFILE"]	C:\Documents and Settings\All Users
_ENV["CommonProgramFiles"]	C:\Program Files\Common Files
_ENV["COMPUTERNAME"]	SERENITY
_ENV["ComSpec"]	C:\WINDOWS\system32\cmd.exe
_ENV["FP_NO_HOST_CHECK"]	NO
_ENV["ICINCHOME"]	C:\instantclient_10_2\sdk\include
_ENV["ICLIBHOME"]	C:\instantclient_10_2\sdk\lib
_ENV["NUMBER_OF_PROCESSORS"]	1
_ENV["ORACLE_SID"]	XE
_ENV["OS"]	Windows_NT
_ENV["Path"]	C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
_ENV["PATHEXT"]	.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PHP
_ENV["PROCESSOR_ARCHITECTURE"]	x86
_ENV["PROCESSOR_IDENTIFIER"]	x86 Family 15 Model 2 Stepping 9, GenuineIntel
_ENV["PROCESSOR_LEVEL"]	15
_ENV["PROCESSOR_REVISION"]	0209
_ENV["ProgramFiles"]	C:\Program Files
_ENV["sqlpath"]	c:\documents and settings\nia\desktop
_ENV["SWORD_PATH"]	C:\Program Files\CrossWire\The SWORD Project
_ENV["SystemDrive"]	C:
_ENV["SystemRoot"]	C:\WINDOWS
_ENV["TEMP"]	C:\WINDOWS\TEMP
_ENV["TMP"]	C:\WINDOWS\TEMP
_ENV["TNS_ADMIN"]	C:\oraclexe\app\oracle\product\10.2.0\server\NETWORK\ADMIN
_ENV["USERPROFILE"]	C:\Documents and Settings\LocalService
_ENV["VS90COMNTOOLS"]	C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools\
_ENV["windir"]	C:\WINDOWS
_ENV["AP_PARENT_PID"]	2080
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
best regards,
ethereal1m
Re: Log Writes [message #510396 is a reply to message #510370] Wed, 27 January 2010 12:39 Go to previous messageGo to next message
I can't see anything obvious in your configuration that is wrong. If
there is no entry in the log, either xdebug is not attempting to remote
debug, a firewall is blocking port 9000 or something other than the IDE
is listening on port 9000. You could try WireShark to see if your web
server process attempts to connect on port 9000. I can't think of
anything else at this time. Sorry
Dave Kelsey
On 27/01/10 11:29, Ethereal1m wrote:
> hi Dave,
> phpinfo dump:
><snip>
Re: Log Writes [message #510488 is a reply to message #510396] Wed, 27 January 2010 16:00 Go to previous message
Member
Hi Dave,
thanks for the reply. I double check my firewall settings and add an exception to port 9000 still doesn't solve the problem.
And I cannot see anything running with port 9000 open other than Eclipse xdebug. I will try your suggestion by sniffing the traffic ysing WireShark.
Previous Topic:running xdebug to webserver in a same machine
Next Topic:Does Eclipse PDT has a bug ?
Current Time: Sat Mar 25 13:58:44 GMT 2023
Powered by FUDForum. Page generated in 0.01807 seconds
