Home » Language IDEs » PHP Development Tools (PDT) » Log Writes (when connecting to PHPexe works but not when connecting to webserver)
Re: Log Writes [message #510370 is a reply to message #510293] |
Wed, 27 January 2010 06:29   |
hi Dave,
I appreciate your reply. Does Zend Studio has Zend Optimizer included? I'm not sure if I have Optimezer, anyway the following is my complete phpinfo dump:
PHP Logo
PHP Version 5.2.12
System Windows NT SERENITY 5.1 build 2600
Build Date Dec 16 2009 17:01:16
Configure Command cscript /nologo configure.js "--enable-snapshot-build" "--enable-debug-pack" "--with-snapshot-template=d:\php-sdk\snap_5_2\vc6\x86\template" "--with-php-build=d:\php-sdk\snap_5_2\vc6\x86\php_build" "--with-pdo-oci=D:\php-sdk\oracle\instantclient10\sdk,shared" "--with-oci8=D:\php-sdk\oracle\instantclient10\sdk,shared" "--without-pi3web"
Server API Apache 2.0 Handler
Virtual Directory Support enabled
Configuration File (php.ini) Path C:\WINDOWS
Loaded Configuration File C:\WINDOWS\php.ini
Scan this dir for additional .ini files (none)
additional .ini files parsed (none)
PHP API 20041225
PHP Extension 20060613
Zend Extension 220060519
Debug Build no
Thread Safety enabled
Zend Memory Manager enabled
IPv6 Support enabled
Registered PHP Streams php, file, data, http, ftp, compress.zlib
Registered Stream Socket Transports tcp, udp
Registered Stream Filters convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, zlib.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.2.0, Copyright (c) 1998-2009 Zend Technologies
with Xdebug v2.0.5, Copyright (c) 2002-2008, by Derick Rethans
PHP Credits
Configuration
PHP Core
Directive Local Value Master Value
allow_call_time_pass_reference On On
allow_url_fopen On On
allow_url_include Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors On On
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
error_append_string no value no value
error_log C:\PHP\log\php-errors.log C:\PHP\log\php-errors.log
error_prepend_string no value no value
error_reporting 6135 6135
expose_php On On
extension_dir C:\PHP\ext C:\PHP\ext
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .;C:\php5\pear .;C:\php5\pear
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc On On
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.force_extra_parameters no value no value
max_execution_time 30 30
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time 60 60
memory_limit 128M 128M
open_basedir no value no value
output_buffering no value no value
output_handler no value no value
post_max_size 8M 8M
precision 12 12
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv On On
register_globals Off Off
register_long_arrays On On
report_memleaks On On
report_zend_debug On On
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path no value no value
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.ze1_compatibility_mode Off Off
apache2handler
Apache Version Apache/2.2.14 (Win32) PHP/5.2.12
Apache API Version 20051115
Server Administrator ethereal1m@serenity.com
Hostname:Port serenity:0
Max Requests Per Child: 0 - Keep Alive: on - Max Per Connection: 100
Timeouts Connection: 300 - Keep-Alive: 5
Virtual Server No
Server Root C:/Program Files/Apache Software Foundation/Apache2.2
Loaded Modules core mod_win32 mpm_winnt http_core mod_so mod_actions mod_alias mod_asis mod_auth_basic mod_authn_default mod_authn_file mod_authz_default mod_authz_groupfile mod_authz_host mod_authz_user mod_autoindex mod_cgi mod_dir mod_env mod_include mod_isapi mod_log_config mod_mime mod_negotiation mod_setenvif mod_php5
engine 1 1
last_modified 0 0
xbithack 0 0
Apache Environment
Variable Value
HTTP_HOST serenity
HTTP_USER_AGENT Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.7) Gecko/20091221 Firefox/3.5.7 (.NET CLR 3.5.30729)
HTTP_ACCEPT text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
HTTP_ACCEPT_LANGUAGE en-us,en;q=0.5
HTTP_ACCEPT_ENCODING gzip,deflate
HTTP_ACCEPT_CHARSET ISO-8859-1,utf-8;q=0.7,*;q=0.7
HTTP_KEEP_ALIVE 300
HTTP_CONNECTION keep-alive
HTTP_COOKIE ZDEDebuggerPresent=php,phtml,php3
HTTP_CACHE_CONTROL max-age=0
PATH C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
SystemRoot C:\WINDOWS
COMSPEC C:\WINDOWS\system32\cmd.exe
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PHP
WINDIR C:\WINDOWS
SERVER_SIGNATURE no value
SERVER_SOFTWARE Apache/2.2.14 (Win32) PHP/5.2.12
SERVER_NAME serenity
SERVER_ADDR 192.168.1.2
SERVER_PORT 80
REMOTE_ADDR 192.168.1.2
DOCUMENT_ROOT C:/Program Files/Apache Software Foundation/Apache2.2/htdocs
SERVER_ADMIN ethereal1m@serenity.com
SCRIPT_FILENAME C:/Program Files/Apache Software Foundation/Apache2.2/htdocs/phpinfo.php
REMOTE_PORT 1171
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /info
SCRIPT_NAME /info
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /info HTTP/1.1
Host serenity
User-Agent Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.7) Gecko/20091221 Firefox/3.5.7 (.NET CLR 3.5.30729)
Accept text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language en-us,en;q=0.5
Accept-Encoding gzip,deflate
Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive 300
Connection keep-alive
Cookie ZDEDebuggerPresent=php,phtml,php3
Cache-Control max-age=0
HTTP Response Headers
X-Powered-By PHP/5.2.12
Keep-Alive timeout=5, max=100
Connection Keep-Alive
Transfer-Encoding chunked
Content-Type text/html
bcmath
BCMath support enabled
calendar
Calendar support enabled
com_dotnet
COM support enabled
DCOM support disabled
.Net support enabled
com.allow_dcom 0 0
com.autoregister_casesensitive 1 1
com.autoregister_typelib 0 0
com.autoregister_verbose 0 0
com.code_page no value no value
com.typelib_file no value no value
ctype
ctype functions enabled
date
date/time support enabled
"Olson" Timezone Database Version 2009.19
Timezone Database internal
Default timezone Asia/Krasnoyarsk
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone no value no value
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.7.3
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
filter
Input Validation and Filtering enabled
Revision $Revision: 288083 $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru gost adler32 crc32 crc32b haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support enabled
iconv implementation "libiconv"
iconv library version 1.11
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
json
json support enabled
json version 1.2.1
libxml
libXML support active
libXML Version 2.7.3
libXML streams enabled
odbc
ODBC Support enabled
Active Persistent Links 0
Active Links 0
ODBC library Win32
odbc.allow_persistent On On
odbc.check_persistent On On
odbc.default_cursortype Static cursor Static cursor
odbc.default_db no value no value
odbc.default_pw no value no value
odbc.default_user no value no value
odbc.defaultbinmode return as is return as is
odbc.defaultlrl return up to 4096 bytes return up to 4096 bytes
odbc.max_links Unlimited Unlimited
odbc.max_persistent Unlimited Unlimited
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 7.9 2009-04-11
pcre.backtrack_limit 100000 100000
pcre.recursion_limit 100000 100000
Reflection
Reflection enabled
Version $Id: php_reflection.c 290127 2009-11-01 15:12:34Z felipe $
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 On On
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly Off Off
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 100 100
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.hash_bits_per_character 4 4
session.hash_function 0 0
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path C:\WINDOWS\temp C:\WINDOWS\temp
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies Off Off
session.use_trans_sid 0 0
SimpleXML
Simplexml support enabled
Revision $Revision: 289327 $
Schema support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, DirectoryIterator, DomainException, EmptyIterator, FilterIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RegexIterator, RuntimeException, SimpleXMLIterator, SplFileInfo, SplFileObject, SplObjectStorage, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Regex Library Bundled library enabled
Dynamic Library Support enabled
Internal Sendmail Support for Windows enabled
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,input=src,form=,fieldset= a=href,area=href,frame=src,input=src,form=,fieldset=
user_agent no value no value
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xdebug
xdebug support enabled
Version 2.0.5
Supported protocols Revision
DBGp - Common DeBuGger Protocol $Revision: 1.125.2.6 $
GDB - GNU Debugger protocol $Revision: 1.87 $
PHP3 - PHP 3 Debugger protocol $Revision: 1.22 $
xdebug.auto_trace Off Off
xdebug.collect_includes On On
xdebug.collect_params 0 0
xdebug.collect_return Off Off
xdebug.collect_vars Off Off
xdebug.default_enable On On
xdebug.dump.COOKIE no value no value
xdebug.dump.ENV no value no value
xdebug.dump.FILES no value no value
xdebug.dump.GET no value no value
xdebug.dump.POST no value no value
xdebug.dump.REQUEST no value no value
xdebug.dump.SERVER no value no value
xdebug.dump.SESSION no value no value
xdebug.dump_globals On On
xdebug.dump_once On On
xdebug.dump_undefined Off Off
xdebug.extended_info On On
xdebug.idekey no value no value
xdebug.manual_url http://www.php.net http://www.php.net
xdebug.max_nesting_level 100 100
xdebug.profiler_aggregate Off Off
xdebug.profiler_append Off Off
xdebug.profiler_enable Off Off
xdebug.profiler_enable_trigger Off Off
xdebug.profiler_output_dir /tmp /tmp
xdebug.profiler_output_name cachegrind.out.%p cachegrind.out.%p
xdebug.remote_autostart Off Off
xdebug.remote_enable On On
xdebug.remote_handler dbgp dbgp
xdebug.remote_host 127.0.0.1 127.0.0.1
xdebug.remote_log C:\PHP\log\remote.log C:\PHP\log\remote.log
xdebug.remote_mode req req
xdebug.remote_port 9000 9000
xdebug.show_exception_trace Off Off
xdebug.show_local_vars Off Off
xdebug.show_mem_delta Off Off
xdebug.trace_format 0 0
xdebug.trace_options 0 0
xdebug.trace_output_dir /tmp /tmp
xdebug.trace_output_name trace.%c trace.%c
xdebug.var_display_max_children 128 128
xdebug.var_display_max_data 512 512
xdebug.var_display_max_depth 3 3
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.7.3
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
zlib
ZLib Support enabled
Stream Wrapper support compress.zlib://
Stream Filter support zlib.inflate, zlib.deflate
Compiled Version 1.2.3
Linked Version 1.2.3
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
Environment
Variable Value
ALLUSERSPROFILE C:\Documents and Settings\All Users
CommonProgramFiles C:\Program Files\Common Files
COMPUTERNAME SERENITY
ComSpec C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK NO
ICINCHOME C:\instantclient_10_2\sdk\include
ICLIBHOME C:\instantclient_10_2\sdk\lib
NUMBER_OF_PROCESSORS 1
ORACLE_SID XE
OS Windows_NT
Path C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
PROCESSOR_ARCHITECTURE x86
PROCESSOR_IDENTIFIER x86 Family 15 Model 2 Stepping 9, GenuineIntel
PROCESSOR_LEVEL 15
PROCESSOR_REVISION 0209
sqlpath c:\documents and settings\nia\desktop
SWORD_PATH C:\Program Files\CrossWire\The SWORD Project
SystemDrive C:
TEMP C:\WINDOWS\TEMP
TMP C:\WINDOWS\TEMP
TNS_ADMIN C:\oraclexe\app\oracle\product\10.2.0\server\NETWORK\ADMIN
USERPROFILE C:\Documents and Settings\LocalService
VS90COMNTOOLS C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools\
windir C:\WINDOWS
AP_PARENT_PID 2080
PHP Variables
Variable Value
_REQUEST["ZDEDebuggerPresent"] php,phtml,php3
_COOKIE["ZDEDebuggerPresent"] php,phtml,php3
_SERVER["HTTP_HOST"] serenity
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.7) Gecko/20091221 Firefox/3.5.7 (.NET CLR 3.5.30729)
_SERVER["HTTP_ACCEPT"] text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_COOKIE"] ZDEDebuggerPresent=php,phtml,php3
_SERVER["HTTP_CACHE_CONTROL"] max-age=0
_SERVER["PATH"] C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
_SERVER["SystemRoot"] C:\WINDOWS
_SERVER["COMSPEC"] C:\WINDOWS\system32\cmd.exe
_SERVER["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PHP
_SERVER["WINDIR"] C:\WINDOWS
_SERVER["SERVER_SIGNATURE"] no value
_SERVER["SERVER_SOFTWARE"] Apache/2.2.14 (Win32) PHP/5.2.12
_SERVER["SERVER_NAME"] serenity
_SERVER["SERVER_ADDR"] 192.168.1.2
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] 192.168.1.2
_SERVER["DOCUMENT_ROOT"] C:/Program Files/Apache Software Foundation/Apache2.2/htdocs
_SERVER["SERVER_ADMIN"] ethereal1m@serenity.com
_SERVER["SCRIPT_FILENAME"] C:/Program Files/Apache Software Foundation/Apache2.2/htdocs/phpinfo.php
_SERVER["REMOTE_PORT"] 1171
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /info
_SERVER["SCRIPT_NAME"] /info
_SERVER["PHP_SELF"] /info
_SERVER["REQUEST_TIME"] 1264591676
_SERVER["argv"]
Array
_SERVER["argc"] 0
_ENV["ALLUSERSPROFILE"] C:\Documents and Settings\All Users
_ENV["CommonProgramFiles"] C:\Program Files\Common Files
_ENV["COMPUTERNAME"] SERENITY
_ENV["ComSpec"] C:\WINDOWS\system32\cmd.exe
_ENV["FP_NO_HOST_CHECK"] NO
_ENV["ICINCHOME"] C:\instantclient_10_2\sdk\include
_ENV["ICLIBHOME"] C:\instantclient_10_2\sdk\lib
_ENV["NUMBER_OF_PROCESSORS"] 1
_ENV["ORACLE_SID"] XE
_ENV["OS"] Windows_NT
_ENV["Path"] C:\oraclexe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program files\common files\autodesk shared\;c:\program files\jzip;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC;C:\instantclient_10_2;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\include;C:\oraclexe\app\oracle\product\10.2.0\server\OCI\lib\MSVC\vc71;C:\Program Files\GNU\GnuPG;;C:\Program Files\Apache Software Foundation\Apache2.2\bin;C:\PHP;C:\Program Files\TSE\Regular Expression Component Library Vc9\Dll;C:\Program Files\CMake 2.8\bin;C:\Program Files\pcre-8.00\lib\Debug;C:\PHP\ext\;C:\PHP
_ENV["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PHP
_ENV["PROCESSOR_ARCHITECTURE"] x86
_ENV["PROCESSOR_IDENTIFIER"] x86 Family 15 Model 2 Stepping 9, GenuineIntel
_ENV["PROCESSOR_LEVEL"] 15
_ENV["PROCESSOR_REVISION"] 0209
_ENV["ProgramFiles"] C:\Program Files
_ENV["sqlpath"] c:\documents and settings\nia\desktop
_ENV["SWORD_PATH"] C:\Program Files\CrossWire\The SWORD Project
_ENV["SystemDrive"] C:
_ENV["SystemRoot"] C:\WINDOWS
_ENV["TEMP"] C:\WINDOWS\TEMP
_ENV["TMP"] C:\WINDOWS\TEMP
_ENV["TNS_ADMIN"] C:\oraclexe\app\oracle\product\10.2.0\server\NETWORK\ADMIN
_ENV["USERPROFILE"] C:\Documents and Settings\LocalService
_ENV["VS90COMNTOOLS"] C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools\
_ENV["windir"] C:\WINDOWS
_ENV["AP_PARENT_PID"] 2080
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
best regards,
ethereal1m
Re: Log Writes [message #510488 is a reply to message #510396] |
Wed, 27 January 2010 11:00  |
Hi Dave,
thanks for the reply. I double check my firewall settings and add an exception to port 9000 still doesn't solve the problem.
And I cannot see anything running with port 9000 open other than Eclipse xdebug. I will try your suggestion by sniffing the traffic ysing WireShark.
Current Time: Tue Aug 12 12:51:19 EDT 2025
Powered by FUDForum. Page generated in 0.04125 seconds
