| Executing rules ETL [message #510259] |
Tue, 26 January 2010 19:25  |
Hello Dimitrios.
I have concentrated on the example "org.eclipse.epsilon.examples.oo2db" to execute my rules ETL from the modelos.ecore.
I have created three files: UML.model, modeloOR.model and empty Trace.model that initially are emptinesses I have created the file "launch.xml" that is:
<target name="loadModels">
<epsilon.emf.register file="UML.ecore"/>
<epsilon.emf.register file="modeloOR.ecore"/>
<epsilon.emf.register file="SimpleTrace.ecore"/>
<epsilon.loadModel name="UML" type="EMF">
<parameter name="modelFile" file="models/UML.model"/>
<parameter name="metamodelUri" value="http://www.eclipse.org/uml2/2.1.0/UML"/>
<parameter name="readOnLoad" value="true"/>
<parameter name="storeOnDisposal" value="false"/>
</epsilon.loadModel>
<epsilon.loadModel name="modeloOR" type="EMF">
<parameter name="modelFile" file="models/modeloOR.model"/>
<parameter name="metamodelUri" value="http:///modeloOR.ecore"/>
<epsilon.loadModel name="Trace" type="EMF">
<parameter name="modelFile" file="models/Trace.model"/>
<parameter name="metamodelUri" value="SimpleTrace"/>
<parameter name="readOnLoad" value="false"/>
<parameter name="storeOnDisposal" value="true"/>
</target>
<target name="main" depends="loadModels">
<epsilon.etl src="Model.etl">
<model ref="UML"/>
<model ref="modeloOR"/>
<model ref="Trace"/>
</epsilon.etl>
And the exit that appears is:
"Buildfile: C:\......L\launch.xml
loadModels:
main:
[epsilon.etl - Model.etl] ETL
[epsilon.etl - Model.etl] Fin
BUILD SUCCESSFUL
Total time: 968 milliseconds
But in the files UML.model, modeloOR, Trace.model are empty , that is to say that does not execute anything...
Since I execute the file that contains the rules ETL from the file UML.ecore and modeloOR.ecore?
Thanks!!
| Re: Executing rules ETL [message #510266 is a reply to message #510259] |
Tue, 26 January 2010 19:59  |
I'm afraid I don't understand how this question relates to the oo2db
example.
Do you want your transformation to transform models/UML.model to
models/modeloOR.model? In this case, in modeloOR readOnLoad should be
false and storeOnDisposal should be true (it's the other way round now).
Now about the empty models, does UML.model contain anything *before* you
run the transformation? If not, it should as it is the source model of
the transformation.
If you're still having problems with this it'd be probably useful to
send me a zip file with your project.
Dimitris
c wrote:
> Hello Dimitrios.
> </target>
> <model ref="UML"/>
> </epsilon.etl>
> loadModels:
> main:
> BUILD SUCCESSFUL
> Thanks!!
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
FUDForum. Page generated in 0.04219 seconds
