Home » Eclipse Projects » Remote Application Platform (RAP) » Custom GMap Marker in the GMap Custom widget
Custom GMap Marker in the GMap Custom widget [message #510247] |
Tue, 26 January 2010 22:01 |
hanxi.zhang@gmail.com Messages: 3 Registered: January 2010 Location: Ottawa |
Hi Community,
I was playing with the Gmap custom widget example, and trying to
use custom gmap markers (instead of the default red balloon)
in the GMap.js in the org.eclipse.rap.demo.GMap project, instead of
simply creating the marker by:
var marker = new GMarker( point );
I tried to do the following:
var myIcon = new GIcon();
myIcon.image = 'markers/image.png';
myIcon.printImage = 'markers/printImage.gif';
myIcon.mozPrintImage = 'markers/mozPrintImage.gif';
myIcon.iconSize = new GSize(100,20);
myIcon.shadow = 'markers/shadow.png';
myIcon.transparent = 'markers/transparent.png';
myIcon.shadowSize = new GSize(110,20);
myIcon.printShadow = 'markers/printShadow.gif';
myIcon.iconAnchor = new GPoint(50,20);
myIcon.infoWindowAnchor = new GPoint(50,0);
myIcon.imageMap = [99,0,99,1,99,2,99,3,99,4,99,5,99,6,99,7,99,8,99,9,99,10,99, 11,99,12,98,13,97,14,96,15,95,16,93,17,92,18,91,19,0,19,0,18 ,0,17,0,16,0,15,0,14,0,13,0,12,0,11,0,10,0,9,0,8,0,7,2,6,3,5 ,5,4,7,3,8,2,10,1,12,0];
//and finally
var marker = new GMarker( point, {icon:myIcon, draggable : true} );
The images files for the custom widget are created off the http://www.powerhut.co.uk/googlemaps/custom_markers.php web site.
I tried the custom widget in a native html/javascript file, works fine. But in the custom RAP widget example, the custom marker won't showup.
I suspect that qooxdoo cannot located the needed image files. I treid to put those image files under org.eclipse.rap.demo.GMap/markers folder, but no luck. Maybe I have to add those new image files into the org.eclipse.rap.rwt.q07 jar file? If so under what directory?
Many thanks for your comments.
Hanxi
Re: Custom GMap Marker in the GMap Custom widget [message #510311 is a reply to message #510247] |
Wed, 27 January 2010 08:23 |
Stefan Messages: 316 Registered: July 2009 |
I suppose you have to register these Images at the http service to make
them accessible for the browser. You can do so using the extension point
org.eclipse.equinox.http.registry.resources
Stefan.
hanxi.zhang@gmail.com schrieb:
> Hi Community,
> myIcon.imageMap =
> //and finally
> Hanxi
Current Time: Fri Apr 26 11:19:45 GMT 2024
Powered by FUDForum. Page generated in 0.03417 seconds
