Home » Eclipse Projects » Eclipse Platform » Is it possible to create Patch file with Eclipse Team API?
Is it possible to create Patch file with Eclipse Team API? [message #510224] Tue, 26 January 2010 08:54 Go to next message
Originally posted by: fxulusoy.yahoo.com
I would like to create patch files based on diff. We need functionality
like that of the "create patch" menu entry of the SVN/CVS plugins
without installing them. Is it possible to do that with Eclipe Team API
or compare API? Is there any other better way to do that?
Thanks.
Re: Is it possible to create Patch file with Eclipse Team API? [message #510704 is a reply to message #510224] Thu, 28 January 2010 06:31 Go to previous messageGo to next message
I'm afraid the answer is "no". Creating a patch takes place in CVS internals. You can check what's happening there by looking at GenerateDiffFileAction.java. But as I said it's an internal class, there is no API to create a patch. An effort had been made to address this issue, but unfortunately we had to abort it. The compare API can only be used to apply a patch.
Re: Is it possible to create Patch file with Eclipse Team API? [message #510842 is a reply to message #510704] Thu, 28 January 2010 14:07 Go to previous message
Hi Tomasz,
Then, we will do it via CVS/SVN.
Thanks for your reply.
Best Regards
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.team.cv s.ui/src/org/eclipse/team/internal/ccvs/ui/actions/GenerateD iffFileAction.java?revision=1.27&view=markup
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=71374 had been made to
Previous Topic:How to programmatically create ParameterizedCommand
Next Topic:API for eclipse.ini
Current Time: Wed Nov 05 14:37:55 EST 2025
Powered by FUDForum. Page generated in 0.03526 seconds
