Aggregator NPE when building repo with Maven [message #510222] |
Tue, 26 January 2010 08:44  |
we're using the Aggregator to generate Maven-conformant Repositories
with the Option Maven Result.
At the end of the build, while adding maven metadata we get an NPE
Build failed! Exception was java.lang.NullPointerException:
org.eclipse.buckminster.aggregator.engine.maven.MavenManager .getVersionString(MavenManager.java:228)
org.eclipse.buckminster.aggregator.engine.maven.MavenManager .saveXMLs(MavenManager.java:382)
org.eclipse.buckminster.aggregator.engine.maven.MavenManager .saveMetadata(MavenManager.java:242)
org.eclipse.buckminster.aggregator.engine.MirrorGenerator.ru n(MirrorGenerator.java:868)
org.eclipse.buckminster.aggregator.engine.Builder.runMirrori ng(Builder.java:1206)
at org.eclipse.buckminster.aggregator.engine.Builder.run(Builde r.java:693)
org.eclipse.buckminster.aggregator.presentation.AggregatorAc tionBarContributor$BuildRepoAction$1.run(AggregatorActionBar Contributor.java:278)
We use Buckminster Aggregator Editor 1.0.0.r11086.
Thanks in advance.
Marko
Re: Aggregator NPE when building repo with Maven [message #510397 is a reply to message #510300] |
Wed, 27 January 2010 07:41   |
I found and (hopefully) fixed the problem. Unfortunately, for some reason, I am unable to rebuild the update site right now (some problems at build.eclipse.org). I'll try later.
Filip
Filip Hrbek napsal(a):
> Hi Marko,
> sorry for the confusion - I had the p2 repos (not maven repos) you map
> in my mind :-)
> So your answer is galileo + your own (private) repos.
> I'll let you know when I find something.
> Filip
> Marko Espig napsal(a):
>> Hi Filip,
>> thanks for your quick response. I'm not using any public maven repos.
>> I only map galileo p2 and some own p2 repos, and mirror the bundles to
>> produce a Maven repo, like mentioned in the Aggregator Example.
>> I like to consume the generated repo in nexus.
>> When the build is almost complete, the build process is logging
>> "Writing maven metadata" and then the NPE occours.
>> Kind regards
>> Marko
>>> I will look into this and let you know tomorrow.
>>> Is the maven repository you map anything that is public? If so, please
>>> post it here so that I could debug easier.
>>> Thanks.
>>> Kind regards
>>> Filip
>>> exquisitus napsal(a):
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>>>> Thanks in advance.
>>>> Regards
>>>> Marko
Re: Aggregator NPE when building repo with Maven [message #510877 is a reply to message #510740] |
Thu, 28 January 2010 18:00  |
Hi Filip,
I have tried it, it works as expected now.
Thank's, I appreciate your immediate assistance.
Marko
Am 28.01.2010 15:08, schrieb Filip Hrbek:
> This problem has been fixed. The fixed version (Buckminster Aggregator
> Editor 1.0.0.r11118) is available on our update site:
> http://download.eclipse.org/tools/buckminster/updates-3.5
> Please try again and let me know if you succeed or not.
> Filip
>> Hi Filip,
>> Kind regards
>> Marko
>>> Thanks.
>>> Kind regards
>>> Filip
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thanks in advance.
>>>> Regards
>>>> Marko
FUDForum. Page generated in 0.24688 seconds
