Home » Modeling » M2T (model-to-text transformation) » Howto run MWE workflow programmatically with classpath?
icon9.gif  Howto run MWE workflow programmatically with classpath? [message #509935] Mon, 25 January 2010 14:42
After trying and searching around for hours, maybe someone here can help me.
I'm using 8.0.0M4 release, I have an TMF DSL which uses the classpath for resolving imports (this is provided by TMF).
I can run the workflow using "run as workflow" just fine. Now I tried to create a custom builder that launches the workflow and here I'm stuck.
I can start the workflow but as the classpath is only the classpath from the plugin and not from the project where the workflow is defined, it fails when it should resolve an URL with "classpath:/somefile.dsl"
Thanks for any ideas.
Previous Topic:bug with xpand 0.8M4 and XSD adapter?
Next Topic:[xpand] dynamic expansion of template
Current Time: Mon Nov 03 16:28:03 EST 2025
Powered by FUDForum. Page generated in 0.53647 seconds
