Home » Modeling » EMF » [CDO] Adding to CDO server properties programmatically
[CDO] Adding to CDO server properties programmatically [message #509761] Mon, 25 January 2010 05:29 Go to next message
I have an application where the database connection details either are
retrieved from a project file or entered by the user at start up. In this
case I'm missing the possibility to add teneo and database properties
programmatically before creating the repository. I do have and use a
cdo-server.xml but would need to be able to add additional properties before
the creation (instantiation) of the repository.
Currently I use the following code while starting the server:
RepositoryConfigurator repositoryConfigurator = new RepositoryConfigurator(
IPluginContainer.INSTANCE);
// Here I would need to add some properties not defined in the config file
IRepository[] repositories = repositoryConfigurator.configure(configFile);
Maybe there is already a solution to this problem that I haven't discovered
yet?
Cheers
Bjoern
Re: [CDO] Adding to CDO server properties programmatically [message #509772 is a reply to message #509761] Mon, 25 January 2010 06:00 Go to previous messageGo to next message
Hi Bjoern,
Unfortunately the RepositoryConfigurator mechanism is somewhat crude. I
would like to come up with a better mechanism in the future. Ideally
using something established like the Spring framework.
I think that all <property name="..." value=".."/> elements in the
config file are passed to the repository. A store implementation can
access them from there.
DTH?
Cheers
/Eike
> yet?
> Cheers
> Bjoern
Re: [CDO] Adding to CDO server properties programmatically [message #509787 is a reply to message #509772] Mon, 25 January 2010 07:37 Go to previous messageGo to next message
Hi Eike,
Not really. Adding the properties as <property name="..." value=".."/> in the cdo.server.xml is what I do right now. This will, however, not do in the actual application, as the database settings are coming from another source.
I can of course programmatically open the cdo-server.xml and patch it to include the database properties before I pass the file to the RepositoryConfigurator. But I had hoped there would be another "cleaner" way to add to those properties.
Cheers
Bjoern
Re: [CDO] Adding to CDO server properties programmatically [message #509795 is a reply to message #509787] Mon, 25 January 2010 07:51 Go to previous messageGo to next message
--------------070807090008020104060904
Content-Type: text/plain; charset=UTF-8
> Hi Eike,
The offender seems to be at the end of
RepositoryConfigurator.configure(File):
| CDOServerUtil.addRepository(container, repository);|
The addRepository() method implicitely activates the repository. We
could add a boolean parameter to control that and make the
RepositoryConfigurator configurable with that value. Would that help?
Cheers
/Eike
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
<blockquote cite="mid:hjk3a9$bo7$1@build.eclipse.org" type="cite">Hi
Eike,
<br>
<br>
Not really. Adding the properties as &lt;property name="..."
value=".."/&gt;  in the cdo.server.xml is what I do right now. This
settings are coming from another source. <br>
"cleaner" way to add to those properties. <br>
</blockquote>
RepositoryConfigurator.configure(File):<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff">      </font><font
color="#000000">CDOServerUtil.addRepository</font><font color="#000000">(</font><font
color="#000000">container, repository</font><font color="#000000">)</font><font
color="#000000">;</font></code> </td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<!-- ======================================================== --><br>
<br>
RepositoryConfigurator configurable with that value. Would that help?<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
</body>
</html>
--------------070807090008020104060904--
Re: [CDO] Adding to CDO server properties programmatically [message #509806 is a reply to message #509795] Mon, 25 January 2010 08:28 Go to previous messageGo to next message
Hello Eike,
Yes, I think this would help. In this case I would have the possibility to get the repository from the RepositoryConfigurator and add the database properties before activation. I gather I then explicitly have to call CDOServerUtil.addRepository(container, repository) in order to activate, right?
Cheers
Björn
Re: [CDO] Adding to CDO server properties programmatically [message #509904 is a reply to message #509806] Mon, 25 January 2010 08:00 Go to previous messageGo to next message
> Hello Eike,
Please file an enhancement request. Attaching a simple patch would make
it quicker ;-)
> activate, right?
No, just LifecycleUtil.activate(repository);
Cheers
/Eike
Re: [CDO] Adding to CDO server properties programmatically [message #510011 is a reply to message #509904] Tue, 26 January 2010 03:14 Go to previous message
Filed enhancement request: Bug 300770
Cheers
Bjoern
"Eike Stepper" <stepper@esc-net.de> schrieb im Newsbeitrag news:hjklsi$fhu$1@build.eclipse.org...
>> Hello Eike,
> it quicker ;-)
>> activate, right?
> Cheers
> /Eike
Previous Topic:Custom Store Developing
Next Topic:Which EEnum field to use for i18n?
Current Time: Wed Nov 05 04:37:37 EST 2025
Powered by FUDForum. Page generated in 0.06729 seconds
