Re: How to avoid word wrap on colon [message #509532 is a reply to message #509461] |
Fri, 22 January 2010 17:28 |
Reinhard,
I do not know of an easy way around this, but you could try putting the
same date field in two separate data items in the same column. Then on
the first format the date time field to only show date and the second
one to only show time.
Jason
Reinhard wrote:
> Hello guys,
> BIRT supports word wrapping, BUT.... word will be wrapped not only if
> spaces follows, even if word contains signs like . , : ; and so on. My
> table cell contains date and time and it looks like
> 22.01.2009 15:
> 06:37
> I want to get the date on the one line and the time on anoter. Is there
> a possibility to avoid a wrap on colon and allow it only on spaces?
> PS: I'm using BIRT 2.5.1. (if that does matter)
Re: How to avoid word wrap on colon [message #513834 is a reply to message #509532] |
Thu, 11 February 2010 13:13 |
Reinhard Messages: 31 Registered: July 2009 |
Member |
Thanks for your quick response, Jason.
This workarround is a nice idea, but.... if my date is 2/9/10 and time is 15:34:56 and the column is tight enough, then I have the same problem. Date wouldn't wrap and time would.
Is there a possibility for quick fix, I need it only for Date Time column or is there a possibility to enforce wrap on space in custom date time format in style.
Jason Weathersby wrote on Fri, 22 January 2010 12:28 | Reinhard,
Jason
Reinhard wrote:
> Hello guys,
> 22.01.2009 15:
> 06:37
Re: How to avoid word wrap on colon [message #513904 is a reply to message #513834] |
Thu, 11 February 2010 11:08 |
Reinhard,
Can you open a bug for this? You may be able to get a better work around.
Jason
>> Reinhard,
>> the same date field in two separate data items in the same column.
>> Then on the first format the date time field to only show date and the
>> second one to only show time.
>> Jason
>> Reinhard wrote:
>> > Hello guys,
>> if > spaces follows, even if word contains signs like . , : ; and so
>> on. My > table cell contains date and time and it looks like
>> > > 22.01.2009 15:
>> > 06:37
>> there > a possibility to avoid a wrap on colon and allow it only on
>> spaces?
FUDForum. Page generated in 0.04483 seconds
