Re: [Acceleo] Exception in template query [message #508861 is a reply to message #508809] |
Wed, 20 January 2010 15:01 |
--------------010901040908060009030909
Hi Sebastien,
Looks like a bug alright, though I wonder what could possibly trigger
this when the template has two parameters... Could you raise a bugzilla
with the sample model and template?
Laurent Goubet
Obeo
Sebastien Roy wrote:
> Hello,
> I have the following code :
> [for (importValue : String | c.attribute.type.getTypeImport(c).trim())]
> import [importValue/];
> [/for]
> [template public getTypeImport(t : Type, c : Class)]
> [/template]
> That lead to the following exception :
> java.lang.reflect.InvocationTargetException
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
> ssorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
> thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchO
> peration.run(AcceleoLaunchOperation.java:105)
> at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginL
> aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 192)
> aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 109)
> at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchD
> elegate.launch(AcceleoLaunchDelegate.java:52)
> at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L
> aunchConfiguration.java:853)
> aunchConfiguration.java:703)
> at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D
> ebugUIPlugin.java:866)
> at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu
> gin.java:1069)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by: java.lang.StackOverflowError
> at java.lang.reflect.Method.copy(Method.java:143)
> at java.lang.reflect.ReflectAccess.copyMethod(ReflectAccess.jav a:118)
> at sun.reflect.ReflectionFactory.copyMethod(ReflectionFactory.j ava:282)
> at java.lang.Class.searchMethods(Class.java:2656)
> at java.lang.Class.getMethod0(Class.java:2670)
> at java.lang.Class.getMethod(Class.java:1603)
> at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.getJavaMeth
> odFor(EcoreEvaluationEnvironment.java:151)
> odFor(EcoreEvaluationEnvironment.java:1)
> at org.eclipse.ocl.AbstractEvaluationEnvironment.callOperation(
> AbstractEvaluationEnvironment.java:177)
> at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperati
> on(EcoreEvaluationEnvironment.java:89)
> at org.eclipse.acceleo.engine.internal.environment.AcceleoEvalu
> ationEnvironment.callOperation(AcceleoEvaluationEnvironment. java:238)
> on(EcoreEvaluationEnvironment.java:1)
> at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp(
> EvaluationVisitorImpl.java:192)
> at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua
> tionVisitor.visitOperationCallExp(AcceleoEvaluationVisitor.j ava:943)
> at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera
> tionCallExpImpl.java:399)
> EvaluationVisitorImpl.java:161)
> at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(Ab
> stractEvaluationVisitor.java:246)
> at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(E
> valuationVisitorDecorator.java:156)
> tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 376)
> tionVisitor.visitExpression(AcceleoEvaluationVisitor.java:87 2)
> tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:473)
> tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 357)
> tionVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.ja va:770)
> tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 355)
> tionVisitor.visitAcceleoTemplateInvocation(AcceleoEvaluation
> Visitor.java:805)
> tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 366)
> tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:491)
> The exception is not thrown when the called template has only one
> argument :
> [for (importValue : String | c.attribute.type.getTypeImport().trim())]
> [/for]
> [template public getTypeImport(t : Type)]
> [/template]
> That looks like a bug, doesn't it ?
> Sebastien
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010901040908060009030909--
Re: [Acceleo] Exception in template query [message #508898 is a reply to message #508809] |
Wed, 20 January 2010 16:23 |
Sebastien Roy Messages: 51 Registered: November 2009 |
Member |
Well, the bug is not 100% reproducible.
After some changes, in the template content and in the way it is called, i haven't go any error.
The expression
c.attribute.type.MyCalledTemplate(c)
is similar to
c.attribute.type->collect(MyCalledTemplate(self,c))
I will create a test template in order to try to reproduce this problem independently from the rest of my code.
regards
[Updated on: Wed, 20 January 2010 17:36] Report message to a moderator
Re: [Acceleo] Exception in template query [message #509081 is a reply to message #509052] |
Thu, 21 January 2010 10:58 |
--------------040201060802090907070705
Sebastien,
I tend to dislike bugs that come up randomly ... I hope we'll find a
sure-fire way to trigger this in order to fix the underlying issue.
For now, glad that it works as expected.
Laurent Goubet
Obeo
> I'm sorry, but I didn't succeeded in reproducing the bug in a simple
> test example.
> It should be linked to the specific model and code context I had at
> this time.
> Sorry
> Sebastien
--------------040201060802090907070705--
FUDForum. Page generated in 0.04080 seconds
