Home » Eclipse Projects » Eclipse Platform » Large Text Files Editor(Editor for handling large text files (>1GIG))
Large Text Files Editor [message #508377] |
Mon, 18 January 2010 10:36  |
It is known that eclipse default text editor lack of support to read huge files.
It reads the entire file into a string buffer and then creates a document out of it.
My question is if there is a text editor in Eclipse that support paging of file? meaning -
a user opens a huge file, but only the part that he currently sees is loaded into the memory, and he doesn't feel that only part of the file is loaded.
If not, I would like some tips for where to get started in writing such editor my self. I have good knowledge of PDE and wrote a few plugins, but this problem seems to be more complicated.
Moreover, the files I want to be able to open are not in the local workspace, but outside of it, so I am using IFileStore as a resource, FileStoreEditorInput as an IEditorInput and TextFileDocumentProvider as provider
Thanks a lot !
[Updated on: Mon, 18 January 2010 10:39] by Moderator
Re: Large Text Files Editor [message #509294 is a reply to message #509106] |
Thu, 21 January 2010 16:15   |
Thanks for replying. Now I know that there is no such editor.
Lets assume I want it only for reading purposes (for example big system log files).
I started implementing, but as long as I keep digging, I realize that probably one of the major design decisions of eclipse, was that a file can be loaded into a String.
The entire API is based on that fact. From the high level of SourceViewer, to the low level of ILineTrucker.
For exmaple, the VerticalNumberRuler, relies on the fact that the file is loaded to a String, and then it calculates the number of lines in the document, and assigns enough space for the digit to fit in the column.
So when scrolling down, I need to load dynamically new content to the document, but then it still "thinks" that it displays rows starting at index 0, and I need to make it think that it displays higher lines.
So I took care of it. But then the VerticalNumberRuler assigned less space for characters, because it just counts number of lines in the document, in the assumption that they start at line 0. and lines 0-10 requires less space for digits than lines 100-110.
How would you handle this case?
Another thing among many- the search mechanism just searches in the current Document that is loaded, and not in the entire file. for making it search in the paged file, this mechanism also needs to be changed.
So I am pretty lost here...Since String is not extensible, it looks like the solution is to write an entire new implementation, in parallel to the current one, for the EditorPart. and that's probably a work for the Eclipse developers.
On the other hand I still try to think if I can just place a few "hacks" in key locations in order to solve it.
Help me !
Re: Large Text Files Editor [message #509410 is a reply to message #509294] |
Fri, 22 January 2010 06:47   |
Comments below.
bnoam@il.ibm.com wrote:
> system log files).
Perhaps a text widget isn't a good design for that. Some type of lazy
list/tree view might be better.
> can be loaded into a String. The entire API is based on that fact.
Yes, it pretty much expects to load the whole thing.
> column.
I'm doubting you can...
> changed.
Starts to sound like an uphill battle...
I doubt it.
> Help me !
If there were obvious things to point out I'm sure someone would do
that, but these are hard problems that I doubt anyone else has solved...
Current Time: Wed Sep 24 04:59:53 EDT 2025
Powered by FUDForum. Page generated in 0.07877 seconds
