JMerger Example and Standalone Use [message #507550] |
Wed, 13 January 2010 14:48  |
I am new to JMerger. I saw I nice example of using the now deprecated version (org.eclipse.emf.codegen.jmerge.JMerger) on:
http://www.ibm.com/developerworks/library/os-ecemf3/
But I need an example for the newer version (org.eclipse.emf.codegen.merge.java.JMerger). Are there any available?
Also I am trying to understand if the newer JMerger can be used outside the Eclipse/EMF environment. I tried with the deprecated version but I ran into many dependency issues. After I finally got all the jars I needed to run JMerger it appeared that a NullPointerException indicated that some deep environment dependency on Eclipse prevented reuse outside.
Thanks for your help!
Re: JMerger Example and Standalone Use [message #507572 is a reply to message #507567] |
Wed, 13 January 2010 16:02  |
Comments below.
Paul Elder wrote:
> I'm cross posting this to the EMF newsgroup, as JMerger lives within EMF.
> Ed, we await your wise response.
I hope this one counts. :-P
> Paul
> vvernon wrote:
>> Hello,
The org.eclipse.emf.examples.jet.article2.codege example is updated to
use the non-deprecated merger.
I think the one that uses the AST facade, the default, does work stand
alone because it's JDT dependencies also work stand alone.
>> issues.
Yes, JDT's JDOM doesn't work stand alone.
Yes, I think so. But I seem to recall that the AST-based version did
work stand alone.
FUDForum. Page generated in 0.06623 seconds
