Re: gmf diagram file stops writing to model xml file (diagram is a RCP app and also Eclipse plugin) [message #507305 is a reply to message #507045] |
Tue, 12 January 2010 21:30 |
Vineet Messages: 19 Registered: July 2009 |
so at this point I an hoping someone will find this useful.....
The problem is not between the RCP and plugin version. The problem is how the diagram file is opened.
In the RCP version, since there is no project explorer, the only way to open the file is through "File->Open" menu.
In the Eclipse plugin version, I could open the diagram file either using the "File->Open" or simply double clicking on the file through project explorer view.
If the diagram file is opened using the "File->Open" sequence, then everything works. If it is opened by double clicking the diagram file, it somehow seems to get "disconnected" from the backing model file and does not write to it.
Now I am 125% sure that this was not happening in previous versions of GMF (I just upgraded to 2.2, hence all this). I have my diagram editor running in the previous version and everything works irrespective of how the diagram file is opened.
[Updated on: Tue, 12 January 2010 22:00] Report message to a moderator
FUDForum. Page generated in 0.03848 seconds
