Home » Language IDEs » Java Development Tools (JDT) » question on src folder in linux(the default project does not seem to make a src folder)
question on src folder in linux [message #506726] Sat, 09 January 2010 02:24 Go to next message
Hey guys,
I had a search for this but didn't seem to bring anything up except for people talking about open source projects which doesn't particularly relate. So I'm guessing this is something I'm doing wrong Embarrassed
When I create a new project under windows 7/vista it automatically creates "src" and "bin" folders in the project directory. then I just create a new package and away I go.
However under linux (specifically Mint 7) I do not get this, there's no src folder under the package view and also no src or bin folders in project directory in my home folder.
Test.java and Test.class are just sitting in the same folder.
Does this matter ? or
Is there settings to change this?
classpath is as follows:
<classpath>
   <classpathentry kind="src" path=""/>
   <classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
   <classpathentry kind="output" path=""/>
</classpath>
Re: question on src folder in linux [message #506729 is a reply to message #506726] Sat, 09 January 2010 02:43 Go to previous messageGo to next message
I found the settings for this under windows -> preferences -> java -> buldpath.
seems windows has it on by default ?
I'm fairly new to java so the question still stands: Does this matter ?
Or does the src / bin make it easier latter on when building jars to have them seperate.
Re: question on src folder in linux [message #506893 is a reply to message #506729] Mon, 11 January 2010 04:41 Go to previous message
> buldpath.
It's the same on all Platforms but stored in your workspace. You
probably changed it sometime ago or use an old workspace.
Dani
> have them seperate.
Previous Topic:Slim Java Editor
Next Topic:Grouping projects in folders
Current Time: Fri Oct 31 21:50:11 EDT 2025
Powered by FUDForum. Page generated in 0.04758 seconds
