Axis2 1.5.1, Web Service, Tomcat 6.0 [message #506711] |
Fri, 08 January 2010 22:26 |
Jens-Peter Giersch Messages: 2 Registered: January 2010 |
Hello, all,
I want to create a bottom-up web service using Eclipse 3.5 (Galileo).
I already have registered my Tomcat 6.0.20 to Windows -> Preferences -> Server -> Runtime environment.
In the server pane for this server I configured "Use Tomcat installation (takes control of Tomcat installation)" because I want Eclipse to use an existing Tomcat service.
I also registered Axis 1.5.1 successfully in Windows -> Preferences -> Web Services -> Axis2 Preferences
When using the wizard for bottom-up web services I enter the correct data for Tomcat, Axis2 and Dynamic web project, click next and I get this error message:
"Unable to add the follwing facets to project WebServiceProject: Axis2 Web Services Extensions, Axis2 Web Services Core."
So I went into the Web Project Properties: Project -> Properties -> Project Facets.
The checkbox "Axis2 Web Services" checkbox is unchecked. There is an error message in the lower right section of the window specifying "Runtime "Apache Tomcat 6.0" is invalid. The name is already in use. Specify a different name."
If I try to check this checkbox there still occurs the error mentioned above. Either way I cannot click OK, only Cancel.
Does anyone of you have an idea what I did wrong or has a suggestion how I can get my web service running using Axis2, wizards and Tomcat?
Best regards
Jens-Peter
org.eclipse.wst.common.project.facet.core.FacetedProjectFram eworkException: Failed while installing Axis2 Web Services Core 1.1.
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.callDelegate(FacetedProject.java:1497)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modifyInternal(FacetedProject.java:438)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.mergeChangesInternal(FacetedProject.java:1171)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.access$2(FacetedProject.java:1107)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject$1.run(FacetedProject.java:321)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modify(FacetedProject.java:336)
at org.eclipse.jst.ws.internal.consumption.ui.common.FacetOpera tionDelegate$1.run(FacetOperationDelegate.java:62)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: org.eclipse.core.runtime.CoreException: The Axis2 facets cannot be installed since the Axis2 runtime location has not been set.
Go to the Web Services preference page and set the Axis2 runtime location under Axis2 Preferences.
==> I ALREADY DID THIS MORE THEN FOUR TIMES!!!
at org.eclipse.jst.ws.axis2.facet.deligate.Axis2CoreFacetInstal lDelegate.execute(Axis2CoreFacetInstallDelegate.java:50)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.callDelegate(FacetedProject.java:1467)
... 8 more
Caused by: java.io.FileNotFoundException: C:\Program Files (x86)\Apache Software Foundation\Tomcat 6.0\webapps\webapp (Das System kann die angegebene Datei nicht finden)
==> Translated: "System cannot find the file mentioned"
Question: What does it make search there, and for which file? Where do I have to configure this???
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at org.eclipse.jst.ws.axis2.core.utils.FileUtils.copy(FileUtils .java:158)
at org.eclipse.jst.ws.axis2.core.utils.FileUtils.copyDirectory( FileUtils.java:151)
at org.eclipse.jst.ws.axis2.facet.utils.Axis2WebappUtils.copyAx is2War(Axis2WebappUtils.java:94)
at org.eclipse.jst.ws.axis2.facet.commands.Axis2WebservicesServ erCommand.executeOverride(Axis2WebservicesServerCommand.java :84)
at org.eclipse.jst.ws.axis2.facet.deligate.Axis2CoreFacetInstal lDelegate.execute(Axis2CoreFacetInstallDelegate.java:43)
... 9 more
[Updated on: Fri, 08 January 2010 22:32] Report message to a moderator
Axis2 1.5.1, Web Service, Tomcat 6.0 [message #506745 is a reply to message #506711] |
Sat, 09 January 2010 11:39 |
Hi, everyone interested,
the problem described above vanished.
I did the following things:
1. Changed the rights to "Full access" for the group "Main users" (I am using Windows 7, NTFS).
Building the web service did not succeed with the error message mentioned above.
2. Changed the name of the registered server from the default name "Apache Tomcat 6.0" to "Apache Tomcat 6.0.20". I did this because I remembered the other error message regarding "The name is already in use."
Building the web service still did not succeed with the error message mentioned above.
3. I reregistered Axis2 in Windows -> Preferences -> Web Services -> Axis2 Preferences. I restored the default configuration, applied, closed, opened, reentered the path to the Axis2 WAR file and clicked ok.
The webservice was built without batting an eyelid. I think I heard a silent chuckle...
So the error might stem from these two steps:
1. Rights on files
2. Problems with the registration of the server
Up to now I tend to say the problem's cause was an access problem...
<edit>
Wrongo. I reregistered the Tomcat server, and Axis2 did not respond anymore despite the WAR path did not change. After reregistering Axis2 everything worked fine again.
</edit>
Perhaps someone already saw something like that before (with Tomcat, Axis2 etc. of course)?
Thanx for reading my request!
Jens-Peter
[Updated on: Sat, 09 January 2010 07:06] Report message to a moderator
FUDForum. Page generated in 0.04008 seconds
