Re: Cannot enter URL for new location [message #506858 is a reply to message #506665] |
Mon, 11 January 2010 07:47 |
Yuriy Malchenko Messages: 7 Registered: July 2009 |
Hi!
I have 64-bit openSUSE 11.2 as well, and I'm having the exact same problem (although I use subclipse). The URL field is grayed out, either I choose to use pure java connector or JNI (I added "-Djava.library.path=/usr/lib64" to eclipse.ini, so it loads successfully). It happens with a fresh new unzipped eclipse (jee/php) and a new workspace (as well as with some existing ones).
Also, I have one existing workspace on which it works fine, I'm able to input an URL and create a repository location. But if I use that eclipse "instance" with another workspace (or the new one) - the field is grayed out again.
P.S.
I just faced another issue - both input fields in the Find dialog (ctrl+f) are disabled, too. So this might be not the subversion-related issue.
(Un)setting GDK_NATIVE_WINDOWS does not affect.
[Updated on: Mon, 11 January 2010 08:50] Report message to a moderator
FUDForum. Page generated in 0.04311 seconds
