Home » Modeling » UML2 » How to convert a XSD schema file into UML class model?
How to convert a XSD schema file into UML class model? [message #506463] Thu, 07 January 2010 10:42 Go to next message
Assume I have an external XSD schema file
(or many XSD schema files which import each other).
How can I convert them to an UML class diagram in Eclipse?
Is there somewhere a quick tutorial for this?
Ben
Re: How to convert a XSD schema file into UML class model? [message #506488 is a reply to message #506463] Thu, 07 January 2010 11:35 Go to previous messageGo to next message
Hi Ben,
I don't think there is a direct way to do this. However, you can easily create an EMF model for the XSD and export that to UML. To do that:
- Open the New EMF Generator model wizard (File->New->Other...->EMF Generator Model)
- Choose a location and name for the GenModel (usually the place where you want your UML model to end up)
- On the next page choose "XML Schema" as import source
- Choose the Schema(s) to import on the next page
- The final page of the wizard shows you the EMF models that will be created and lets you edit their file names (they will be co-located
with teh Genmodel)
- finish the wizard
- you should end up with one or more *.ecore files for your schemas and an open editor showing your newly created Genmodel.
- From the editor's context menu choose "Export model...", "UML Model", a target directory and all models to convert (usually all would be a
good choice) and finish.
You should end up with UML models for your schemas and probably an ecore.uml with some Ecore infrastructure classes.
Hope that hepls,
Carsten
> Ben
Re: How to convert a XSD schema file into UML class model? [message #506510 is a reply to message #506488] Thu, 07 January 2010 13:53 Go to previous messageGo to next message
Hello Carsten,
thank you for the hints. Just a question anout the required plugins. If I access the software server
Galileo - http://download.eclipse.org/releases/galileo
then there are 4 entries for EMF:
- Modeling Framework
- Compare SDK
- Teneo Eclispelink
- EMF Hibernate
Which of these plugins do I need for the mentioned task?
What is necessary for the UML part I:
Only UML2 Tools SDK or UML2 Extender SDK?
Thank you
Ben
Re: How to convert a XSD schema file into UML class model? [message #506513 is a reply to message #506510] Thu, 07 January 2010 14:11 Go to previous messageGo to next message
Hi Ben,
From the Galileo Modeling category you will need
- Eclipse Modeling Framework SDK
- XML Schema Definition SDK
- UML2 Extender SDK
- UML2 Tools SDK if you want eclipse's UML2 diagram editors
The others you mentioned contain additional optional features for EMF:
> - Compare SDK
Model comparison framework for EMF
> - Teneo Eclispelink
> - EMF Hibernate
OR mapping and database persistence for EMF with EclipseLink and Hibernate respectively
Carsten
Re: How to convert a XSD schema file into UML class model? [message #506576 is a reply to message #506513] Fri, 08 January 2010 01:43 Go to previous messageGo to next message
Hello Carsten,
thank you again. One more question:
Is there somewhere a good and short tutorial on how to use the EMF und UML2 framework?
When I google for such a tutorial I get a list of hundreds of them but these artiles are either to comprehensiv e or outdated or describe only a small portion of the whole topic.
So a recommendation for a good, short, uptodate introduction from scratch would be fine.
I am particularly interested in creating UML class diagrams.
Lets say for creating a "hello world" class diagram.
Ben
Re: How to convert a XSD schema file into UML class model? [message #506654 is a reply to message #506576] Fri, 08 January 2010 09:20 Go to previous message
--------------050804020405030703020409
Content-Type: text/plain; charset=UTF-8; format=flowed
Ben,
This is what's available at Eclipse:
http://www.eclipse.org/modeling/emf/docs/
http://wiki.eclipse.org/index.php/MDT-UML2
http://wiki.eclipse.org/index.php/MDT-UML2TOOLS
Ben wrote:
> Hello Carsten,
> UML2 framework?
> scratch would be fine. I am particularly interested in creating UML
> class diagrams.
> Ben
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Ben,<br>
<br>
This is what's available at Eclipse:<br>
<blockquote><a href="http://www.eclipse.org/modeling/emf/docs/">http://www.eclipse.org/modeling/emf/docs/</a><br>
<a href="http://wiki.eclipse.org/index.php/MDT-UML2">http://wiki.eclipse.org/index.php/MDT-UML2</a><br>
<a href="http://wiki.eclipse.org/index.php/MDT-UML2TOOLS">http://wiki.eclipse.org/index.php/MDT-UML2TOOLS</a><br>
</blockquote>
<br>
Ben wrote:
<blockquote cite="mid:hi6k79$fh1$1@build.eclipse.org" type="cite">Hello
Carsten,
<br>
<br>
<br>
<br>
UML2 framework?
<br>
<br>
<br>
<br>
class diagrams.
<br>
<br>
<br>
Ben
<br>
<br>
</blockquote>
</body>
</html>
--------------050804020405030703020409--
Re: How to convert a XSD schema file into UML class model? [message #628163 is a reply to message #506488] Thu, 07 January 2010 13:53 Go to previous message
Hello Carsten,
- Compare SDK
- Teneo Eclispelink
- EMF Hibernate
Thank you
Ben
Re: How to convert a XSD schema file into UML class model? [message #628164 is a reply to message #628163] Thu, 07 January 2010 14:11 Go to previous message
Hi Ben,
- UML2 Extender SDK
> - Compare SDK
> - Teneo Eclispelink
> - EMF Hibernate
Carsten
Re: How to convert a XSD schema file into UML class model? [message #628165 is a reply to message #506513] Fri, 08 January 2010 01:43 Go to previous message
Hello Carsten,
Ben
Re: How to convert a XSD schema file into UML class model? [message #628166 is a reply to message #628165] Fri, 08 January 2010 09:20 Go to previous message
Ben,
Ben wrote:
> Hello Carsten,
> UML2 framework?
> class diagrams.
> Ben
<html>
<head>
</head>
Ben,<br>
<br>
</blockquote>
<br>
Carsten,
<br>
<br>
<br>
<br>
UML2 framework?
<br>
<br>
<br>
<br>
class diagrams.
<br>
<br>
<br>
Ben
<br>
<br>
</blockquote>
</body>
</html>
Previous Topic:How to convert a XSD schema file into UML class model?
Next Topic:Stereotypes are not correctly recognized
Current Time: Tue Nov 04 12:39:15 EST 2025
Powered by FUDForum. Page generated in 0.05385 seconds
