Re: View Icons [message #505739 is a reply to message #505629] |
Mon, 04 January 2010 17:53 |
Jon Buck Messages: 29 Registered: July 2009 |
Hey Wim,
Thanks for your reply, yes the view icons are defined within the views
configuration within the plugin.xml, now when the app loads I have a
number of views that are stacked and only the active view displays it's
icon, the other tabs do not. Looking at eclipse ide all of the view tabs
are showing their icons all the time regardless of whether they are
active or not therefore I would like to know how this is acheived...
Jon
On 1/3/2010 4:09 PM, Wim Jongman wrote:
> Hi Jon,
> They should always appear. When do you set the icon for the view? Do you
> specify this in the manifest?
> Best regards,
> Wim Jongman
>> Hi All,
>> I am hoping this is a simple one :) basically I would like to know how
>> you show the icons that appear on the view tabs all the time, currently
>> the icons only show when the view is selected...
>> Thanks
>> Jon
Re: View Icons [message #506060 is a reply to message #505739] |
Tue, 05 January 2010 17:42 |
Wim Jongman Messages: 423 Registered: July 2009 |
Hi John,
The icons should be visible by default. How do you populate your perspective?
Do you use the perspectiveextension extension point?
Wim
> Hey Wim,
> Thanks
> Jon
>> Hi Jon,
>> Best regards,
>> Wim Jongman
>>> Hi All,
>>> Thanks
>>> Jon
Re: View Icons [message #506081 is a reply to message #506060] |
Wed, 06 January 2010 02:23 |
Hey Wim,
Right, the perspective loads a default view and then I use the
perspectiveextension to populate the rest of the view...
Jon
On 1/5/2010 4:37 PM, Wim Jongman wrote:
> Hi John,
> Best regards,
> Wim
>> Hey Wim,
>> Thanks
>> Jon
>>> Hi Jon,
>>> Best regards,
>>> Wim Jongman
>>>> Hi All,
>>>> Thanks
>>>> Jon
FUDForum. Page generated in 0.03218 seconds
