Re: Eclipse without connection any repository [message #505126 is a reply to message #505107] |
Sun, 27 December 2009 07:30 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------010207030302040404060005
Content-Type: text/plain; charset=UTF-8; format=flowed
The foundation newsgroup isn't for asking technical questions it's for
asking about the operations of the Eclipse organization. Please use the
platform or newcomers newsgroup for technical questions about the
platform. Your problem sounds a little like this one:
< http://www.eclipse.org/forums/index.php?t=msg&th=159863& amp;start=0&>
trompeteandos wrote:
> Sorry for my english.
> I've installed my operating system (Debian Squeeze)
> Then i've installed sun-java6-jdk and I've dowloaded eclipse from
> eclipse.org site.
> When I run eclipse, all appears ok, but when I clicked on Help ->
> Install new Software... and select....Galileo -
> http://download.eclipse.org/releases/galileo for example I receive
> the next message:
> Unable to read repository at
> http://download.eclipse.org/releases/galileo/content.xml
> La red es inaccesible
> The log file appears:
> No repository found at http://download.eclipse.org/releases/galileo
> EXCEPTION STACK TRACE:
> org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception:
> at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR
> epositoryManager.fail(AbstractRepositoryManager.java:380)
> epositoryManager.loadRepository(AbstractRepositoryManager.ja va:606)
> at org.eclipse.equinox.internal.p2.metadata.repository.Metadata
> RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
> RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
> at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr
> ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 88)
> at org.eclipse.equinox.internal.provisional.p2.ui.QueryableMeta
> dataRepositoryManager.doLoadRepository(QueryableMetadataRepo
> sitoryManager.java:55)
> at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo
> sitoryManager.loadRepository(QueryableRepositoryManager.java :195)
> sitoryManager.loadAll(QueryableRepositoryManager.java:108)
> at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryH
> andler$2.run(PreloadingRepositoryHandler.java:71)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> SESSION DATA: eclipse.buildId=M20090917-0800
> java.version=1.6.0_0
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=es_ES
> Framework arguments: -product org.eclipse.epp.package.php.product
> Command-line arguments: -os linux -ws gtk -arch x86 -product
> So, What it's the problem that I can't connect and install new software?
> It's happend even if I add new repository...zend pdt for example.
> Thank you.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
the platform or newcomers newsgroup for technical questions about the
platform. Your problem sounds a little like this one:<a
href="http://www.eclipse.org/forums/index.php?t=msg&th=159863&start=0&"><br>
</a>
<blockquote><a
href="http://www.eclipse.org/forums/index.php?t=msg&th=159863&start=0&">http://www.eclipse.org/forums/index.php?t=msg&th=159863&start=0&</a><br>
</blockquote>
<br>
<blockquote cite="mid:hh64lm$g43$1@build.eclipse.org" type="cite">Sorry
for my english.
<br>
<br>
<br>
eclipse.org site.
<br>
<br>
<a class="moz-txt-link-freetext" href="http://download.eclipse.org/releases/galileo">http://download.eclipse.org/releases/galileo</a> for example I receive the
next message:
<br>
<br>
<a class="moz-txt-link-freetext" href="http://download.eclipse.org/releases/galileo/content.xml">http://download.eclipse.org/releases/galileo/content.xml</a>.
<br>
<br>
<br>
<br>
<br>
No repository found at <a class="moz-txt-link-freetext" href="http://download.eclipse.org/releases/galileo">http://download.eclipse.org/releases/galileo</a>.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
software?
<br>
<br>
<br>
<br>
Thank you.
<br>
<br>
</blockquote>
</body>
</html>
--------------010207030302040404060005--
Ed Merks
FUDForum. Page generated in 0.03454 seconds
