Integrate own Gef in GMF [message #504692] |
Tue, 22 December 2009 03:48 |
Thomas Messages: 79 Registered: October 2009 |
Member |
I extended the gef framework for my own behaviors and now i have the problem to integrate it in gmf. How can i set the required references of gmf to my gef? Is it possible to do this so easy as i thougth?
I downloaded the sources of gef and generate a my.gef plugin. It seems to be working.
I downloaded the gmf sources too, because i need to update the dependancies. Instead of org.eclipse.gef i am using my.gef.
Is there something where i can get the sources for the GMF Project. I downloaded it from the CVS but i can´t compile it. I want to switch the org.eclipse.gef dependancies with my.my.gef.
Now a important question. What are the steps to generate the gmf plugins. I only need to update my.gef on org.eclipse.gmf.ui.diagrams (+.properties), org.eclipse.[something].gef. Do i need to generate the whole GMF Source Project as a new Plugin or just the 3 Projects?
Thomas
[Updated on: Wed, 23 December 2009 08:43] Report message to a moderator
FUDForum. Page generated in 0.03498 seconds
