Home » Language IDEs » ServerTools (WTP) » Managing external libs for webapp
Managing external libs for webapp [message #504667] |
Tue, 22 December 2009 01:05 |
David Kerber Messages: 100 Registered: July 2009 |
I had asked this question on the newcomer group, and the referred me to
the wtp group for more information. The only suggestion I got over
there was to drop everything in WEB-INF/lib.
I have been using Eclipse for 3 years or so for maintaining a medium-
sized tomcat webapp; using 3.5.2 right now on tc 5.5.25 and 6.0.20.
I've always been able to get deployments to work, but sometimes it takes
a bit of trial and error to do so, so I'm looking for a reference that
might help me get things working the first time.
My app uses a utility jar that we have written, plus a half-dozen or so
3rd-party libs. Some of these libs are referenced only in the utility
jar project, some only in the webapp, and some in both. The issue is
where to set up the external libraries in my webapp in the project
properties, things like commons-net, activation.jar. mail.jar, jakarta-
oro, etc, so that when I deploy my app to a new system, all the required
external libs will be available for the webapp.
It doesn't make sense to me why (for example), I need to put jakarta-oro
in both the libraries tab of the build path dialog, and in the Java EE
module dependencies, while others like standard.jar and jstl.jar work
fine when they are only in the libraries tab, and not in the Java EE
module dependencies.
Can somebody point me to a reference that explains what each of these
external library locations are for, when to use each of them, and when
to use the "order and export" tab? I'd greatly appreciate it.
Thanks!
D
Re: Managing external libs for webapp [message #504725 is a reply to message #504667] |
Tue, 22 December 2009 10:48 |
Philippe Marschall Messages: 121 Registered: July 2009 |
Use Maven to manage the dependencies with the right scopes (eg. provided
for jstl) and let it generate the WTP projects. Never worry again about
setting up a WTP project or keeping your release build in synch with
your WTP setup.
Cheers
Philippe
Re: Managing external libs for webapp [message #504780 is a reply to message #504667] |
Tue, 22 December 2009 16:10 |
Everything in the WEB-INF/lib folder is automatically on your Java
Build Path _and_ deployed in your application. The Java Build Path
property page is used for specifying anything further required you
build your application, while you specify anything needed at runtime
(and thus needing to be deployed as well) using the Java EE Module
Dependencies page.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Managing external libs for webapp [message #504817 is a reply to message #504780] |
Tue, 22 December 2009 19:07 |
In article <hgqr1j$l6o$1@build.eclipse.org>, nitind@us.ibm.com says...
so
> Dependencies page.
It sounds like you're saying that the Java EE Module Dependencies page
will essentially duplicate the effect of copying to the WEB-INF/lib
folder.
So am I interpreting this correctly when I understand that the preferred
method of including those external libs is just to copy them into the
WEB-INF/lib folder, and not mess with anything in the build path dialog?
D
Current Time: Sat Apr 27 02:17:12 GMT 2024
Powered by FUDForum. Page generated in 0.03141 seconds
