OpenJPA enhancer task works on cmd line, fails in Eclipse 3.5.1 [message #504249] |
Thu, 17 December 2009 16:05  |
(This is my third try at posting this. The first two never showed up. My attempts were yesterday, several hours apart, so I'm pretty sure I waited long enough.)
I have an app using JDK 1.6, Eclipse 3.5.1, and OpenJPA 1.2.1. OpenJPA has an "enhancer" task that modifies the bytecode of domain classes. My Ant build script to do this works perfectly fine from the command line. When I run it from Eclipse, however, it fails with the build output that follows this.
Following the build output is the relevant portion of my build.xml file. My persistence.xml file is in "src/java/META-INF/persistence.xml", which is covered in the classpath (this is mentioned as one of the possible causes in the error message).
What could I be doing wrong here?
Ant build from Eclipse:
enhance.classpath[<<workspacepath>>\DynamicContent\lib\openjpa-1.2.1.jar; <<workspacepath>>\DynamicContent\lib\geronimo-jpa_3.0_spec-1.0.jar; <<workspacepath>>\DynamicContent\lib\geronimo-jta_1.1_spec-1.1.jar; <<workspacepath>>\DynamicContent\lib\commons-lang-2.4.jar;< <workspacepath>>\DynamicContent\lib\commons-collections-3.2.1.jar; <<workspacepath>>\DynamicContent\lib\serp-1.13.1.jar;<<workspacepath >>\DynamicContent\src\java;<<workspacepath>>\DynamicContent\build\classes]
[java] ProductDerivations: 4
[java] 1. org.apache.openjpa.jdbc.conf.JDBCProductDerivation: OK
[java] 2.
org.apache.openjpa.persistence.PersistenceProductDerivation: OK
[java] 3.
org.apache.openjpa.persistence.jdbc.JDBCPersistenceProductDe rivation: OK
[java] 4. org.apache.openjpa.slice.ProductDerivation: OK
[openjpac] <openjpa-1.2.1-r752877:753278 fatal user error>
org.apache.openjpa.util.MetaDataException: MetaDataFactory could not be configured (conf.newMetaDataFactoryInstance() returned null). This might mean that no configuration properties were found. Ensure that you have a META-INF/persistence.xml file, that it is available in your classpath, or that the properties file you are using for configuration is available. If you are using Ant, please see the <properties> or <propertiesFile> attributes of the task's nested <config> element. This can also occur if your OpenJPA distribution jars are corrupt, or if your security policy is overly strict.
[openjpac] at
org.apache.openjpa.meta.MetaDataRepository.initializeMetaDat aFactory(MetaDataRepository.java:1567)
[openjpac] at
org.apache.openjpa.meta.MetaDataRepository.endConfiguration( MetaDataRepository.java:1558)
[openjpac] at
org.apache.openjpa.lib.conf.Configurations.configureInstance (Configurations.java:505)
[openjpac] at
org.apache.openjpa.lib.conf.Configurations.configureInstance (Configurations.java:430)
[openjpac] at
org.apache.openjpa.lib.conf.PluginValue.instantiate(PluginVa lue.java:103)
[openjpac] at
org.apache.openjpa.conf.MetaDataRepositoryValue.instantiate( MetaDataRepositoryValue.java:68)
[openjpac] at
org.apache.openjpa.lib.conf.ObjectValue.instantiate(ObjectVa lue.java:83)
[openjpac] at
org.apache.openjpa.conf.OpenJPAConfigurationImpl.newMetaData RepositoryInstance(OpenJPAConfigurationImpl.java:863)
[openjpac] at
org.apache.openjpa.ant.PCEnhancerTask.executeOn(PCEnhancerTa sk.java:88)
[openjpac] at
org.apache.openjpa.lib.ant.AbstractTask.execute(AbstractTask .java:172)
[openjpac] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
[openjpac] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[openjpac] at
[openjpac] at
[openjpac] at java.lang.reflect.Method.invoke(Method.java:585)
[openjpac] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
[openjpac] at org.apache.tools.ant.Task.perform(Task.java:348)
[openjpac] at org.apache.tools.ant.Target.execute(Target.java:357)
[openjpac] at
org.apache.tools.ant.Target.performTasks(Target.java:385)
[openjpac] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
[openjpac] at
org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
[openjpac] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
[openjpac] at
org.eclipse.ant.internal.ui.antsupport.EclipseDefaultExecuto r.executeTargets(EclipseDefaultExecutor.java:32)
[openjpac] at
org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
[openjpac] at
org.eclipse.ant.internal.ui.antsupport.InternalAntRunner.run (InternalAntRunner.java:423)
[openjpac] at
org.eclipse.ant.internal.ui.antsupport.InternalAntRunner.mai n(InternalAntRunner.java:137)
Relevant part of build.xml:
<project name="DynamicContent" default="build" basedir=".">
<property file="build-dyncontent.properties"/>
<path id="enhance.classpath">
<pathelement location="${openjpa.jar}"/>
<pathelement location="${jpa.jar}"/>
<pathelement location="${jta.jar}"/>
<pathelement location="${commons-lang.jar}"/>
<pathelement location="${commons-collections.jar}"/>
<pathelement location="${serp.jar}"/>
<pathelement location="src/java"/>
<pathelement location="build/classes"/>
</path>
<path id="build.classpath">
<pathelement location="${jackson-mapper.jar}"/>
<pathelement location="${jackson-core-asl.jar}"/>
<pathelement location="${jackson-jaxrs.jar}"/>
<pathelement location="${jackson-xc.jar}"/>
<pathelement location="${aspectjrt.jar}"/>
<pathelement location="${aspectjweaver.jar}"/>
<pathelement location="${commons-logging.jar}"/>
<pathelement location="${commons-beanutils.jar}"/>
<pathelement location="${cxf.jar}"/>
<pathelement location="${jaxb-api.jar}"/>
<pathelement location="${jaxb-impl.jar}"/>
<pathelement location="${jsr311-api.jar}"/>
<pathelement location="${spring.jar}"/>
<pathelement location="${cglib.jar}"/>
<pathelement location="${wsdl4j.jar}"/>
<pathelement location="${XmlSchema.jar}"/>
</path>
<path id="test.classpath">
<pathelement location="${derby.jar}"/>
<pathelement location="${junit.jar}"/>
<pathelement location="build/testclasses"/>
<path refid="build.classpath"/>
</path>
<target name="build"
depends="compile,enhance-classes,assemble-war,assemble-ear" >
</target>
<target name="compile">
<delete dir="build"/>
<mkdir dir="build/classes"/>
<javac destdir="build/classes" debug="true" failonerror="true">
<src path="src/java"/>
<classpath refid="build.classpath"/>
</javac>
</target>
<taskdef classpathref="enhance.classpath" name="openjpac" classname="org.apache.openjpa.ant.PCEnhancerTask"/>
<target name="enhance-classes">
<pathconvert property="echo.enhance.classpath" refid="enhance.classpath"/>
<echo
message="enhance.classpath[${echo.enhance.classpath}]"/>
<java
classname="org.apache.openjpa.lib.conf.ProductDerivations">
<classpath refid="enhance.classpath"/>
</java>
<openjpac directory="build/enhancedClasses"
enforcepropertyrestrictions="true">
<fileset dir="src/java">
<include name="**/domain/*.java"/>
</fileset>
</openjpac>
</target>
</project>
Re: OpenJPA enhancer task works on cmd line, fails in Eclipse 3.5.1 [message #504268 is a reply to message #504249] |
Thu, 17 December 2009 20:08   |
> follows this.
My guess would be a path problem. Check the launch configuration for
your ant script in Eclipse. Make sure the Working Directory on the JRE
tab points to the correct location.
> [java] 2.
> [java] 3.
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> Method)
> [openjpac] at
> ssorImpl.java:39)
> [openjpac] at
> [openjpac] at
> Utils.java:106)
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> [openjpac] at
> </path>
> </path>
> </path>
> </target>
> </javac>
> </target>
> <echo
> <java
> </java>
> </fileset>
> </openjpac>
> </target>
> </project>
Re: OpenJPA enhancer task works on cmd line, fails in Eclipse 3.5.1 [message #504271 is a reply to message #504268] |
Thu, 17 December 2009 20:35  |
Well, that wasn't it, but that made me look at something that seemed suspicious, so I was able to figure it out. For some reason that I don't understand, the run configuration for the script didn't include the project, so it didn't have any of the classpath of the project. I didn't see any way to add the "project", so I had to manually add all the jars for the project. Once I did that, Ant targets ran fine from Eclipse.
FUDForum. Page generated in 0.03781 seconds
