Home » Modeling » M2T (model-to-text transformation) » [XPand] targetDef.proceed() fails
[XPand] targetDef.proceed() fails [message #503981] Wed, 16 December 2009 12:14 Go to next message
In Galileo, I want to use «targetDef.proceed()» to "call" the parent rule to proceed with the transformation, but I get an error when do the transformation:
Exception (Can't evaluate expression: retured value is OclInvalid:in aspects::xpt::diagram::commands::CreateNodeCommand, line 23) while generating code
My template code is:
«AROUND CreateNodeCommand FOR gmfgen::GenNode-»
«EXPAND xpt::Common::copyright FOR getDiagram().editorGen-»
package «getDiagram().editCommandsPackageName»;
«EXPAND xpt::Common::generatedClassComment»
public class «createCommandClassName» extends org.eclipse.gmf.runtime.emf.type.core.commands.EditElementCommand {
	«EXPAND getEClassToEdit-»
«ENDAROUND»
Could anybody help me please?
Thanks!!
Marc
[Updated on: Wed, 16 December 2009 12:18] by Moderator
Re: [XPand] targetDef.proceed() fails [message #504032 is a reply to message #503981] Wed, 16 December 2009 16:07 Go to previous messageGo to next message
Hello Marc,
are you using GMF's Xpand (fork?). Search the weg for the error message you posted resulted in org.eclipse.gmf.internal.xpand.ocl.ExpressionHelper. If so this should be a question asked in the GMF forum.
Re: [XPand] targetDef.proceed() fails [message #504187 is a reply to message #504032] Thu, 17 December 2009 05:47 Go to previous message
Thanks Christian, I'm waiting for a response in GMF.
Marc
Previous Topic:[Announce] M2T XPAND 0.8.0M4 is available
Next Topic:The Generator does not produce the correct results from the first time!?
Current Time: Sat Nov 08 14:03:15 EST 2025
Powered by FUDForum. Page generated in 0.03792 seconds
