[CDO] Does the Gastro sample work with current 3.0? [message #503951] |
Wed, 16 December 2009 15:36 |
Hi again,
I am using my Helios M4 Eclipse with the latest CDO nightly build from Hudson. When I run GastroTestClient1 I get the exception below. Is this because the example is not up to date with the 3.0 or am I missing something in my environment?
Many thanks,
Joel
[ERROR] Factory not found: org.eclipse.emf.cdo.sessions[cdo]
org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found: org.eclipse.emf.cdo.sessions[cdo]
at org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:193)
at org.eclipse.net4j.util.container.ManagedContainer.createElement(ManagedContainer.java:490)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:281)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:265)
at org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.doRun(OpenSessionAction.java:67)
at org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(LongRunningAction.java:185)
[Updated on: Wed, 16 December 2009 10:35] Report message to a moderator
Re: [CDO] Does the Gastro sample work with current 3.0? [message #503958 is a reply to message #503951] |
Wed, 16 December 2009 15:43 |
Hi Joel,
It's supposed to be up to date and runnable. I used it in many recent
presentations. I just checked that the needed
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionFactory is registered
by the org.eclipse.emf.cdo.net4j plugin. Did you deploy that one?
Cheers
/Eike
Joel Rosi-Schwartz schrieb:
> Hi again,
> missing something in my enverironment?
> Many thanks,
> Joel
> at
> org.eclipse.net4j.util.container.ManagedContainer.getFactory (ManagedContainer.java:193)
> at
> org.eclipse.net4j.util.container.ManagedContainer.createElem ent(ManagedContainer.java:490)
> at
> org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:281)
> at
> org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:265)
> at
> org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.do Run(OpenSessionAction.java:67)
> at
> org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:185)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Does the Gastro sample work with current 3.0? [message #503965 is a reply to message #503958] |
Wed, 16 December 2009 16:03 |
Yes it is installed, but the launch config "Add Required Plug-ins" did not select it nor did the "Validate Plug-ins" complain about it being missing. There is no explicit dependency in the testclient plug-in to this, but there is to one to org.eclipse.net4j.tcp, should that have pulled it in?
I added it manually and everything is working now.
Many thanks (again;-)
Joel
Eike Stepper wrote on Wed, 16 December 2009 15:43 | Hi Joel,
Re: [CDO] Does the Gastro sample work with current 3.0? [message #503970 is a reply to message #503965] |
Wed, 16 December 2009 11:16 |
> pulled it in?
This plugin was created when I decoupled CDO from Net4j transport. The
whole purpoe is that nothing in CDO points to that plugin. But I think
it makes sense for the testclient example to reference it. I'll change
that. Thx for the hint ;-)
Cheers
/Eike
> Joel
>> Hi Joel,
Cheers
/Eike
FUDForum. Page generated in 0.03904 seconds
