Regenerating model code [message #503745] |
Tue, 15 December 2009 15:33 |
Milan Milanovich Messages: 201 Registered: July 2009 |
regarding previous topic, I found a problem with regenerating model code. I.e., when I change my domain ecore model and want to generate model code again.
As far as I can see, the problem is when I click in genmodel to Generate Model Code,
it generates the code correctly, however nothing is added to plugin.xml (Extensions) or manifest.mf
(Exported packages).
How can I solve this problem?
btw- I'm using Eclipse Modeling Galileo + JDK6.
Thanks, Milan
[Updated on: Tue, 15 December 2009 15:51] Report message to a moderator
Re: Regenerating model code [message #503901 is a reply to message #503745] |
Wed, 16 December 2009 10:22 |
gary s thompson Messages: 92 Registered: July 2009 |
Member |
Milan Milanovich wrote on Tue, 15 December 2009 10:33 | Hi,
Hi Milan
my understanding is that manifest.mf and plugins.xml files cannot be merged to [emf can only merge to java files] i believe. So to regenerate them make a backup copy of them or delete them before you generate.
here is a quote from the emf book 2nd ed (about page 600) which discusses the topic in the context of regenerating an editor plugin as part of an rcp application but which is addressing the same problem as here I think
After saving the .gemodel file and generating the code, you will be able to run
the RCP application. Before jumping into it though, it is important to point out
that the value of the RCP property affects the contents of the generated plug-
in.xml and META-INF/MANIFEST.MF files in the editor plug-in. If you are
regenerating over an existing plug-in, you will need to delete these files because
EMF cannot merge changes into them. Note that the model, edit, and test plug-
ins are not affected at all by the RCP property.
regards
gary
Thanks, Milan
FUDForum. Page generated in 0.03757 seconds
