Home » Eclipse Projects » Remote Application Platform (RAP) » TypeError: $0 is null
| TypeError: $0 is null [message #503732] |
Tue, 15 December 2009 09:44  |
we and our customers sometimes receive the java script errors listed below.
Sadly, we can not reproduce it following some special steps, it just happens
sometimes. Because of that we can not even provide a Snippet.
Is there any chance that you can still find a solution for this? If so, I
would file a bug for it.
Markus
Here is one Error:
Could not evaluate javascript response:
var wm = org.eclipse.swt.WidgetManager.getInstance();var w =
wm.findWidgetById( "w661" );w.doClose();wm.dispose( "w661" );wm.dispose(
"w673" );wm.dispose( "w664" );wm.dispose( "w663" );wm.dispose(
"w662" );wm.dispose( "w672" );wm.dispose( "w671" );wm.dispose(
"w670" );wm.dispose( "w669" );wm.dispose( "w668" );wm.dispose(
"w667" );wm.dispose( "w666" );wm.dispose( "w665" );var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "259" );
Or the folowing Error:
var req = org.eclipse.swt.Request.getInstance();req.setRequestCounter(
"80" );var wm = org.eclipse.swt.WidgetManager.getInstance();var w =
wm.findWidgetById( "w551" );w.doClose();wm.dispose( "w551" );wm.dispose(
"w563" );wm.dispose( "w554" );wm.dispose( "w553" );wm.dispose(
"w552" );wm.dispose( "w562" );wm.dispose( "w561" );wm.dispose(
"w560" );wm.dispose( "w559" );wm.dispose( "w558" );wm.dispose(
"w557" );wm.dispose( "w556" );wm.dispose( "w555" );var w =
wm.findWidgetById( "w229" );w.setItemCount( 65 );var w =
wm.findWidgetById( "w278" );w.setTexts( [ "", "Familienzuschlag", "0,00",
"0,00", "0,00", "0,00", "0,00", "0,00", "0,00", "0,00", "0,00", "0,00",
"0,00", "0,00", "0,00" ] );w.update();var w = wm.findWidgetById(
"w279" );w.setTexts( [ "", "Zulagen", "0,00", "0,00", "0,00", "0,00",
"0,00" ] );w.setSelection( false );w.update();var w = wm.findWidgetById(
"w280" );w.setTexts( [ "", "Summe Gesamtbez
| Re: TypeError: $0 is null [message #503937 is a reply to message #503743] |
Wed, 16 December 2009 09:37   |
Hi Ivan,
it happens in Firefox and IE. In IE the message of the error is a bit
different:
'null' ist Null oder kein Objekt
"54" );var wm = org.eclipse.swt.WidgetManager.getInstance();var w =
wm.findWidgetById( "w796" );w.doClose();wm.dispose( "w796" );wm.dispose(
"w808" );wm.dispose( "w799" );wm.dispose( "w798" );wm.dispose(
"w797" );wm.dispose( "w807" );wm.dispose( "w806" );wm.dispose(
"w805" );wm.dispose( "w804" );wm.dispose( "w803" );wm.dispose(
"w802" );wm.dispose( "w801" );wm.dispose( "w800" );var w = wm.newWidget(
"w809", "", false,
"org.eclipse.swt.widgets.Shell" );w.addToDocument();w.addState(
"rwt_BORDER" );w.addState( "rwt_APPLICATION_MODAL" );w.addState(
"rwt_TITLE" );w.setShowMinimize( false );w.setAllowMinimize(
false );w.setShowMaximize( true );w.setAllowMaximize(
true );w.setShowClose( true );w.setAllowClose( true );w.setResizable( true,
true, true, true );w.setParentShell( wm.findWidgetById(
"w2" ) );w.initialize();w.addEventListener( "changeWidth",
org.eclipse.swt.EventUtil.widgetResized );w.addEventListener(
"changeHeight",
org.eclipse.swt.EventUtil.widgetResized );w.addEventListener( "changeLeft",
org.eclipse.swt.EventUtil.widgetMoved );w.addEventListener( "changeTop",
org.eclipse.swt.EventUtil.widgetMoved );w.setSpace( 548, 584, 303,
201 );w.setTabIndex( -1 );w.setCursor( "wait" );w.setCaption( "Berechnung
Kalkulation: Unbenannt 1" );w.setHasShellListener( true );w.setMinWidth(
80 );w.setMinHeight( 23 );var w = wm.newWidget( "w813", "w809", true,
"qx.ui.basic.Atom" );org.eclipse.swt.LabelUtil.initialize(
w );org.eclipse.swt.LabelUtil.setWrap( w, false );w.setSpace( 9, 32, 29,
32 );w.setZIndex(
300 );w.setTabIndex( -1 );org.eclipse.swt.LabelUtil.setImage( w,
"rwt-resources/resource/widget/rap/dialog/information.png" );var w =
wm.newWidget( "w814", "w809", true,
w );org.eclipse.swt.LabelUtil.setWrap( w, true );w.setSpace( 51, 520, 29,
15 );w.setZIndex(
299 );w.setTabIndex( -1 );org.eclipse.swt.LabelUtil.setText( w, "Operation
l
| Re: TypeError: $0 is null [message #503953 is a reply to message #503937] |
Wed, 16 December 2009 10:37   |
Hi Markus,
I've opened a bug about this issue:
297969: [Shell] JavaScript error when creating a dialog in certain
constellations
https://bugs.eclipse.org/bugs/show_bug.cgi?id=297969
I think that I found what is the reason for this error, but I need your
confirmation. The proposed patch is attached to the bug.
HTH,
Ivan
On 12/16/2009 16:37, Markus Kr�ger wrote:
> Hi Ivan,
> different:
> "w809", "", false,
> "changeHeight",
> 32 );w.setZIndex(
> 15 );w.setZIndex(
> l�uft..." );var w = wm.newWidget( "w817", "w809", true,
> "org.eclipse.swt.widgets.Composite" );w.setSpace( 9, 562, 67,
> 15 );w.setZIndex( 298 );w.setTabIndex( 1 );var w = wm.newWidget( "w815",
> "w817", true, "org.eclipse.swt.widgets.ProgressBar" );w.setFlag(
> 34078976 );w.setSpace( 0, 562, 0, 15 );w.setZIndex(
> 300 );w.setTabIndex( -1 );w.setVisibility( false );var w = wm.newWidget(
> "w816", "w817", true, "org.eclipse.swt.widgets.ProgressBar" );w.setFlag(
> 34078978 );w.setSpace( 0, 562, 0, 15 );w.setZIndex(
> 299 );w.setTabIndex( -1 );var w = wm.newWidget( "w818", "w809", true,
> w );org.eclipse.swt.LabelUtil.setWrap( w, true );w.setSpace( 9, 562, 88,
> 34 );w.setZIndex( 297 );w.setTabIndex( -1 );wm.setFont( w, [ "verdana",
> "arial", "sans-serif" ], 11, false, false );var w = wm.newWidget( "w819",
> "w809", true, "org.eclipse.rwt.widgets.Button", '"check"' );w.addState(
> "rwt_CHECK" );w.setSpace( 9, 562, 128, 21 );w.setZIndex(
> 296 );w.setTabIndex( 2 );wm.setToolTip( w, "Langwierige Operation nach
> M�glichkeit im Hintergrund ausf�hren" );w.setText( "Immer im Hintergrund
> ausf�hren" );w.setHorizontalChildrenAlign(
> "left" );w.setHasSelectionListener( true );var w = wm.newWidget( "w820",
> "w809", true, "org.eclipse.swt.widgets.Composite" );w.setSpace( 9, 562, 155,
> 1 );w.setZIndex( 295 );w.setTabIndex( -1 );var w = wm.newWidget( "w821",
> "w809", true, "org.eclipse.swt.widgets.Composite" );w.setSpace( 170, 401,
> 162, 25 );w.setZIndex( 294 );w.setTabIndex( -1 );wm.setFont( w, [ "verdana",
> "arial", "sans-serif" ], 11, false, false );var w = wm.newWidget( "w810",
> "w821", true, "org.eclipse.rwt.widgets.Button", '"push"' );w.addState(
> "rwt_PUSH" );w.setSpace( 0, 164, 0, 25 );w.setZIndex( 300 );w.setTabIndex(
> 5 );wm.setFont( w, [ "verdana", "arial", "sans-serif" ], 11, false,
> false );w.setCursor( "default" );w.setText( "Im Hintergrund
> ausf�hren" );w.setHasSelectionListener( true );var w = wm.findWidgetById(
> "w809" );w.setDefaultButton( wm.findWidgetById( "w810" ) );var w =
> wm.newWidget( "w811", "w821", true, "org.eclipse.rwt.widgets.Button",
> '"push"' );w.addState( "rwt_PUSH" );w.setSpace( 171, 108, 0,
> 25 );w.setZIndex( 299 );w.setTabIndex( 6 );wm.setFont( w, [ "verdana",
> "arial", "sans-serif" ], 11, false, false );w.setCursor(
> "default" );w.setText( "Abbrechen" );w.setHasSelectionListener( true );var w
> = wm.newWidget( "w812", "w821", true, "org.eclipse.rwt.widgets.Button",
> '"push"' );w.addState( "rwt_PUSH" );w.setSpace( 286, 108, 0,
> 25 );w.setZIndex( 298 );w.setTabIndex( 7 );wm.setFont( w, [ "verdana",
> "default" );w.setText( "Details>>" );w.setHasSelectionListener( true );var
> w = wm.findWidgetById( "w2" );w.setActiveControl( wm.findWidgetById(
> "w318" ) );org.eclipse.swt.WidgetManager.getInstance().focus( "w318" );
> Starting the application from within eclipse I never get the error, so debug
> mode does not help. It seems to only occur when deployed to tomcat.
> You can test it on http://pak.ion.ag There is a green "play" button that
> calculates some values and displays them in the table below.
> Now, if you keep clicking the button a lot of times and quite fast, then the
> error occurs. But it also happens with "normal" user behavior.
> Hope that helps a bit.
> Markus
> "Ivan Furnadjiev"<ivan@eclipsesource.com> schrieb im Newsbeitrag
> news:hg8a1d$f79$1@build.eclipse.org...
>> Hi Markus,
>> to debug it, based on posted javascript error is almost impossible. You
>> can try to reproduce and post the error with debug mode switched on. In
>> this case the javascript error is "more" informative.
>> But, in any case, more information is needed like browser, is
>> JFace/Workbench used, is the table ( for me it looks like a table disposal
>> in the javascript error) in dialog or not. Any additional information
>> will help.
>> Best,
>> Ivan
| Re: TypeError: $0 is null [message #503957 is a reply to message #503953] |
Wed, 16 December 2009 10:48   |
I'll check it and keep you informed.
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:hgausm$gg7$1@build.eclipse.org...
> Hi Markus,
> constellations
> HTH,
> Ivan
> On 12/16/2009 16:37, Markus Kr?ger wrote:
>> Hi Ivan,
>> different:
>> "w809", "", false,
>> true,
>> "changeHeight",
>> "changeLeft",
>> 32 );w.setZIndex(
>> 15 );w.setZIndex(
>> "Operation
>> l?uft..." );var w = wm.newWidget( "w817", "w809", true,
>> M?glichkeit im Hintergrund ausf?hren" );w.setText( "Immer im Hintergrund
>> ausf?hren" );w.setHorizontalChildrenAlign(
>> 155,
>> "verdana",
>> ausf?hren" );w.setHasSelectionListener( true );var w = wm.findWidgetById(
>> true );var w
>> true );var
>> debug
>> the
>> Regards,
>> Markus
>>> Hi Markus,
>>> disposal
>>> will help.
>>> Best,
>>> Ivan
Current Time: Sun Nov 02 21:52:59 EST 2025
Powered by FUDForum. Page generated in 0.07638 seconds
