EclipseLink 2.0.0 OSGI Bundles RCP Plugin error in manifest [message #503730] |
Tue, 15 December 2009 09:38 |
Originally posted by: mail.thomashaertel.com
Hi all,
I am trying to add the new 2.0 release of eclipselink zu my rcp
application (eclipse-3.5.1-rcp install). When I add
org.eclipse.persistence.core or org.eclipse.persistence.jpa to my
manifest as a required plugin I get the following errors in the
manifest: "Unsatisfied version constraint" and in the plugin classes all
imports beginning with org.eclipse.* cannot be resolved.
I have seen that there is already a bug reported, which is markted as
fixed: https://bugs.eclipse.org/bugs/show_bug.cgi?id=265763
Does anyone has a solution for this problem?
thx.
Thomas Haertel
Re: EclipseLink 2.0.0 OSGI Bundles RCP Plugin error in manifest [message #503950 is a reply to message #503813] |
Wed, 16 December 2009 15:10 |
Hi Shaun,
thanks for your reply. I can't get it run with your instructions.
I took a fresh Eclipse 3.5.1 RCP installation an installed the
EclipseLink plugin from your link as a dropin in Eclipse. Then I
imported the example projects into a new workspace. To fix all the
errors in PDE I had to change the manifest in
org.eclipse.persistence.example.jpa.comics.model.annotated to the follwing:
Import-Package: javax.persistence;version="[1.99.0,2.0.0]"
The same change was made in the manifest from plugin
org.eclipse.persistence.example.jpa.comics.setup.
I made no changes in plugin
org.eclipse.persistence.example.jpa.rcp.comics. The plugin has as
required plugin org.eclipse.persistence.jpa which gives the same errors
as I wrote in my first post. Every class is markted with errors, because
the org.eclipse packages are not found. When I remove the dependency
these errors are gone, but then the classes PersistenceUnitProperties
and PersistenceProvider are not found.
I hope you can reproduce it.
regards,
Thomas
Am 15.12.2009 17:46, schrieb Shaun Smith:
> Hi Thomas,
> I checked the RCP example out of trunk in the EclipseLink SVN, updated
> the javax.persistence version requirement of the
> org.eclipse.persistence.example.jpa.comics.model.annotated bundle to
> minimum 2.0 and was able to run against the EclipseLink 2.0 bundles
> available for download as the
> http://www.eclipse.org/downloads/download.php?file=/rt/eclip selink/releases/2.0.0/eclipselink-plugins-2.0.0.v20091127-r5 931.zip
> When I changed my target in PDE to include EclipseLink 2.0 I got all
> kinds of errors but through reloading the target, restarting Eclipse,
> and cleaning all projects I was finally able to convince PDE that there
> wasn't a problem. Perhaps you're experiencing the same PDE issues I was
> seeing?
> The RCP example app ran fine once PDE was happy.
> --Shaun
Re: EclipseLink 2.0.0 OSGI Bundles RCP Plugin error in manifest [message #504468 is a reply to message #503950] |
Sat, 19 December 2009 21:20 |
Juergen Jessenig Messages: 6 Registered: July 2009 |
I got the same error here!
- Fresh install of Eclipse 3.5.1 (Eclipse for RCP/Plug-in Developers Build id: 20090920-1017)
- Downloaded EclipseLink 2.0.0 OSGI Bundles ZIP from http://www.eclipse.org/eclipselink/downloads/
- Added the expanded folder to the Target Platform settings (Preferences/Plug-In Development/Target Platform)
- Created a new Plugin-Project (Rich Client Application)
As soon as I add org.eclipse.persistence.core (2.0.0) or org.eclipse.persistence.jpa (2.0.0) the "Plug-In Dependencies" folder in the Package Explorer view disappears and all classes get a red cross, and when I mouseover the error symbols on the according lines of the MANIFEST.MF I get the error "Unsatisfied Version Constraint" on ALL required bundles...
The problem also appears when using the EclipseLink 1.2.0 Release - but it does not appear when using the 1.1.2 Release you get from the online update...
Help would be great ,-)
TIA, Juergen
[Updated on: Sat, 19 December 2009 16:31] Report message to a moderator
Re: EclipseLink 2.0.0 OSGI Bundles RCP Plugin error in manifest [message #504592 is a reply to message #504554] |
Mon, 21 December 2009 17:06 |
Shaun Smith Messages: 197 Registered: July 2009 |
I'm convinced this is a PDE problem, not EclipseLink 2.0. I opened Eclipse 3.4 with the EclipseLink in the dropins folder and had no errors when I added o.e.p.jpa to my required bundles.
In Eclipse 3.5 and 3.5.1 regardless of whether I put EclipseLink 2.0 in the dropins folder or augment my target environment with EclipseLink bundles I get the same "explosion" of errors when I add o.e.p.jpa to my required bundles.
I'll filed a bug against PDE but in the meantime it looks like you can either use import-package or Eclipse 3.4.
--Shaun
[Updated on: Mon, 21 December 2009 17:25] Report message to a moderator
Re: EclipseLink 2.0.0 OSGI Bundles RCP Plugin error in manifest [message #506511 is a reply to message #506221] |
Thu, 07 January 2010 18:54 |
Hi Shaun,
I tried to follow your instructions - without luck. Here'a step by step list what I did:
1. Download/Unpack fresh Eclipse RCP Package
2. Download/Unpack fresh EclipseLink 2.0.0 Plugins Package
3. Copy EclipseLink Plugins folder to eclipse root folder as "plugins_custom"
4. Adding the EclipseLink Plugin folder to the target environment (Preferences/Plug-in Development/Target Platform - Running Platform - Edit - Locations - Add - Directory)
5. Unchecking javax.activation, javax.transaction and javax.xml.stream (Preferences/Plug-in Development/Target Platform - Running Platform - Edit - Content)
6. Savig the preferences
7. Creating a new RCP Projects
8. Add javax.pesistence (2.0.0), org.eclipse.persistence.antlr (2.0.0), org.eclipse.persistence.asm (2.0.0), org.eclipse.persistence.core (2.0.0), org.eclipse.persistence.jpa (2.0.0) under Dependencies in the MANIFEST.MF from my RCP-Project.
As soon as I save the MANIFEST.MF file, the same error occurs - the Plugin-Dependencies Folder in the Package Explorer disappears, every class-file get's a red cross, and in the MANIFEST.MF section of the editor all packages show the "Unsatisfied version constraint" error...
I'm not very experienced as a RCP Developer, so... what am I doing wrong???
Kind regards,
Juergen
FUDForum. Page generated in 0.05300 seconds
