Re: SVG [message #503563 is a reply to message #503531] |
Mon, 14 December 2009 12:34 |
Ali Koudri Messages: 118 Registered: July 2009 |
Thx for the help, I tried and I got this error:
java.lang.NoClassDefFoundError: org/eclipse/gmf/runtime/lite/svg/SVGFigure
I have checked the dependency to the org.eclipse.gmf.runtime.lite.svg
plugin, it seems OK ! Plus, I have no error at compile time !
Best regards.
Le 14/12/2009 11:51, Aurelien Pupier a écrit :
> we succesfully used it in BonitaSoft Open Solutions Studio
> http://www.bonitasoft.com/
> You can look at the source code here : http://www.bonitasoft.org/websvn/
> And if you want some help on it, please precise what you have done and
> what is the result (error, stacktrace,...)
> Regards,
> Aurelien Pupier
Re: SVG [message #503590 is a reply to message #503563] |
Mon, 14 December 2009 20:18 |
Problem solved !
I think this actually a bug of eclipse. The problem comes from the fact
I generated an independant figure plugin and used the mirrored gmfgraph
model in the gmfmap model.
Thx four your help Aurelien,
Best regards.
> Best regards.
>> Hi,
>> Regards,
>> Aurelien Pupier
FUDForum. Page generated in 0.03844 seconds
