Home » Newcomers » Newcomers » Custum editor: reserved words(How to ?)
Custum editor: reserved words [message #503472] Mon, 14 December 2009 06:33 Go to next message
I created, via a plugin in eclipse 3.5, a custom (multipage)editor for an exotic programming language.
I can't figure out how to create reservedwords that are highligted in my editor. Does anybody know how to do this ?
Thx.
Re: Custum editor: reserved words [message #503484 is a reply to message #503472] Mon, 14 December 2009 07:36 Go to previous messageGo to next message
Kitesurfer a écrit :
> Hello,
> Thx.
Hi Kitesurfer,
Try to take a look at DLTK framework. It's a very nice framework to make
editors plugin.
Otherwise, you can define a WordRule in your RuleBasedScanner.
David
Re: Custum editor: reserved words [message #503536 is a reply to message #503484] Mon, 14 December 2009 11:05 Go to previous messageGo to next message
I'd like to do it without an addtional framework. Do you perhaps have a working example of a WordRule in a RuleBasedScanner ?
Re: Custum editor: reserved words [message #503656 is a reply to message #503536] Tue, 15 December 2009 03:45 Go to previous messageGo to next message
Hi Kitesurfer,
Here is an example of what I have done in my plugin. You'll have to
adapt it a little to make it work in your project. I hope this can help you.
1- In your xxxTextEditor class (that extends TextEditor), initialize the
source viewer configuration, like this :
protected void initializeEditor()
super.initializeEditor();
setSourceViewerConfiguration(new XxxSourceViewerConfiguration(this));
2- add xxxSourceViewerConfiguration class that extends
SourceViewerConfiguration to your project.
3- in xxxSourceViewerConfiguration, override getPresentationReconciler
method, and initialize your code scanner in it :
public IPresentationReconciler getPresentationReconciler(ISourceViewer
sourceViewer)
PresentationReconciler reconciler = new PresentationReconciler();
XxxCodeScanner codescanner = new XxxCodeScanner();
DefaultDamagerRepairer dr = new DefaultDamagerRepairer(codescanner);
reconciler.setDamager(dr, IDocument.DEFAULT_CONTENT_TYPE);
reconciler.setRepairer(dr, IDocument.DEFAULT_CONTENT_TYPE);
4- add xxxCodeScanner class that extends RuleBasedScanner to your project
5- in xxxCodeScanner, initialize WordRule, like this :
public xxxCodeScanner()
ArrayList<IRule> rules = new ArrayList<IRule>();
rules.add(new WhitespaceRule(new IWhitespaceDetector()
public boolean isWhitespace(char c)
return (c == ' ' || c == '\t' || c == '\n' || c == '\r');
WordRule wordRule = new WordRule(new IWordDetector()
public boolean isWordPart(char c)
return (Character.isLetterOrDigit(c) || c == '_');
public boolean isWordStart(char c)
return (Character.isLetter(c) || c == '_');
Token instructionToken = new Token(...);
for (String keyword : AllYourKeywords)
wordRule.addWord(keyword, instructionToken);
rules.add(wordRule);
setRules(rules.toArray(new IRule[] {}));
David
Re: Custum editor: reserved words [message #503685 is a reply to message #503472] Tue, 15 December 2009 05:41 Go to previous messageGo to next message
http://www.realsolve.co.uk/site/tech/jface-text.php
This is tutorial about writing enhanced text editor
Re: Custum editor: reserved words [message #504647 is a reply to message #503685] Mon, 21 December 2009 11:22 Go to previous messageGo to next message
Michael Golovanov wrote on Tue, 15 December 2009 05:41
Thanks, this is a great example. It's a challenge to customize it ... so I started removing some stuff (at the end all the scanner classes and all the rules) ... but when I start the plugin (via run as eclipse application) all the functionality is still there ? ... the xml-tags and attributes are still scanned and colored, also for xml-comment.
Is this normal behaviour ? ... or do I have to do more then just delete the classes from the project and solve the errors ?
Re: Custum editor: reserved words [message #505242 is a reply to message #503685] Mon, 28 December 2009 16:09 Go to previous messageGo to next message
This tutorial/project doesn't work ... when I change the extension from 'xml' to 'xxx' and open a file with extension 'xxx' then I get an error.
Re: Custum editor: reserved words [message #505277 is a reply to message #505242] Tue, 29 December 2009 01:46 Go to previous messageGo to next message
>when I change the extension from 'xml' to 'xxx' and open a file with >extension 'xxx' then I get an error
Please write more details about how you do this
Can you show error stack trace?
Re: Custum editor: reserved words [message #505280 is a reply to message #505277] Tue, 29 December 2009 04:25 Go to previous messageGo to next message
I downloaded the project (had to do it twice to get it) from http://www.realsolve.co.uk/site/tech/jface-text.php
I imported (import existing project into workspace) the project in Eclipse 3.5 (Build id: 20090920-1017)
I changed the file plugin.xml : in xml-node "extension", "editor" I changed the xml-attribute "extensions" to "xxx" (old value was 'xml')
I save the whole project via "Save All"
I delete the directory "runtime-EclipseApplication" in my workspace-folder.
I right-click on the project and select "Run as", "Eclipse application"
In the new started eclipse I open a file called "plugin.xxx" (which is a copy of plugin.xml).
Then I get an editor-window with only the text "ERROR" (no error stack trace)
Re: Custum editor: reserved words [message #505448 is a reply to message #505280] Wed, 30 December 2009 13:57 Go to previous messageGo to next message
OK, you are right, this sample has error
I dont debug this sample yet, but find workarond.
In runned sample create new Generic Project and import your *.xxx file to this project. In my case this help - editor opened without critical errors.
PS Can you write more about exotic programming language syntax from first post?
[Updated on: Wed, 30 December 2009 09:02] by Moderator
Re: Custum editor: reserved words [message #505777 is a reply to message #505448] Mon, 04 January 2010 16:59 Go to previous message
Michael Golovanov wrote on Wed, 30 December 2009 13:57
Your workaround to "activate" the plugin works ... thanks. Strange that the plugin on an extension only works within a project (import an xxx-file, or link to an xxx-file) and doesn't work when just opening an xxx-file outside a project. Is this normal behaviour in Eclipse ?
The exotic programming language is the "Transaction Application Langauge" on an HP-system. It's looks a bit like C but has somewhat other syntax and definitly other keywords.
Previous Topic:Issue in installing WST Plugin
Next Topic:org.eclipse.team.ftp
Current Time: Thu Aug 21 04:48:04 EDT 2025
Powered by FUDForum. Page generated in 0.07751 seconds
