Re: [XPAND] Couldn't find Model [message #503332 is a reply to message #503329] |
Fri, 11 December 2009 17:58 |
Hello, vou get this error message cant find you Metamodel and therefore cannot verify that there is a MetaClass "mathset::Model". to tell Xpand where to find / search your MetaModel you have to do only two things
(1) tell xpand what kind of metamodel you are using. In Your case this would be EMF Metamodels (In your projects Properties go to the Xtend/Xpand section and verify if EMF MetaModels is selected (should be default)
(2) the (generated) .ecore file has to be on the classpath of your xpand project. therefor add a plugin-dependeny to your generator projects manifest file.
Twitter : @chrdietrich
FUDForum. Page generated in 0.03873 seconds
